04-08-2012 07:54 AM - edited 03-16-2019 10:31 AM
Dear Friends,
I would like to integerate SIP between Cisco 2911 Router and Nortel CS1000 and would appreciate if someone can help me on this. Below is the network set up details:
The Call Flow is as follows:
Incoming Call Dailed from Mobile to Nortel Phone:
Outgoing Call Dailed from Nortel Phone to Mobile:
I would appreciate if someone can help me on this. Any documentation would be appreciated.
Abbas Mirza
Solved! Go to Solution.
04-08-2012 08:19 AM
Abbas,
Checkout the Configuration guides listed at following portal known as " Cisco Interoperability Portal "
Search for " Nortel " & you should find plenty of docs. The portal might not have the config guides for the latest version of Nortel CS but the procedure/logic should remain almost the same. e.g. This doc might be the most appropriate one for you, check out http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns835/684016.pdf
Hope it helps ?
GP.
Pls rate helpful posts by clicking on stars below the post !!
04-08-2012 08:19 AM
Abbas,
Hope it helps ?
GP.
04-14-2012 11:24 PM
Hi Gajanan Pande,
I have configured the Nortel PABx and Cisco router with the document you had provided and i am able to get incoming calls on the Nortel Telephone set through the SIP circuit, although I am not able to make outgoing calls. I hope you can help me on this too. The document doesnt say much about the outgoing calls.
Abbas Mirza
04-15-2012 01:49 AM
Abbas,
That is very much on Nortel side to enable outgoing calling. We guys would not know it, Sorry. If they also work on Partition/CSS mechanism then, I would ensure proper config on that part first.
Let's hope someone with Nortel knowledge on this forum would help you, else please approach Nortel or their similar forum if any for Nortel part of config.
GP.
04-08-2012 08:20 AM
install a FXO card on 2911 gateway.
Create an extension 600 for eample, on nortel gateway and connect it on FXO port of 2911.
create a dial-peer on 2911 to forward destination pattern of 5XXX to the FXO port.
when an incoming call will come on 2911 it will forward it on the FXO port as per he dial-peer.
04-15-2012 11:03 PM
How and what you have configured for outgoing calls @nortel side?
Have you used NRS for SIP integration?
When you say outgoing calls fail, what exactly happens? Can you see where exactly call is failing, i.e, the phone is hitting the SIP trunk at all or is it blocked @phone itself, you can see this in packet capture or CLI management (LD 80). If it is getting struck at phone then you can try raising phone's access right(give it UNR) or change NCOS level. If it is getting struck at trunk then try bypassing NRS SS.
04-16-2012 01:42 AM
Hi Kailash,
Yes i have configured the NRS for SIP integeration.
Regarding outgoing call failing, i am not getting the line itself. When i use the outgoing steering code suppose 76 to make outgoing call, i am not getting any dialtone. So i guess it is blocked at the phone itself.
Kailash, i am not an expert in Nortel so i would appreciate if you have any document related this or if there are any Nortel Forums please pass it on to me. This would help me much.
Abbas Mirza
04-16-2012 02:00 AM
Hi Abbas,
you can try AVAYA support forums for assistance on nortel CS1K side.
If you are not getting dial tone, it doesn't mean that outgoing is blocked; it may also be the case that tone and cadence configuration is missing in CS1K side.
To be sure that outgoing call is rejected; phone should display "RELEASE AND TRY AGAIN".
Kailash
04-16-2012 04:38 AM
Hi Kailash,
This is what is appearing on the Nortel Phone.
So i guess the outgoing call is rejected from the Nortel System.
I will check some other parameters and see if things work.
Incase you find anything let me know.
Appreciate your support.
Abbas Mirza
