SIP Integration CISCO & Avaya
abhasjain
HI,
CIsco CUCM & AVAYA PBX is connected over LAN network. Is it possible to integrate CUCM 7.0 & AVAYA PBX using IP SIP ? If yes how?
Abhas Jain
paolo bevilacqua
Yes, it is possible. The best way to do it is by hiring a reputable consultant, or UC certified Cisco partner.
david-lima
Level 4
Level 4
Hi Abhas, take a look to this document.
I hope this helps you a little bit more.
Good luck.
David
Hi David,
thanks a lot...for very useful doc
Regadrs,
Abhas Jain
