02-04-2015 02:09 PM - edited 03-17-2019 01:51 AM
Hello - we are looking at adding a SIP Gateway at one of our branches with SRST. The phones will be using SCCP for their protocol. Are there some good documents I could reference as a template for this configuration? Obviously this has to be built in the CM and in the IOS but looking for some type of document that steps you through for what needs to be configured on both ends when adding a branch. Understanding that the dial peers and IP's will change if we decide to add more sites but trying to get to a somewhat cookie cutter cofiguration if that is possible.
02-05-2015 05:30 AM
first of all advise about your current Call manager version, Voice Gateway model, SRST version you have.
to create SRST for SCCP phones you need to configure telephony-service with SRST mode.
Anas
don't forget to rate the helpful posts
02-05-2015 01:53 PM
CUCM = 10.0.1
VG = 2921
SRST = 10.0
02-08-2015 11:48 AM
One more question, what kind of GW you have MGCP/SIP/H.323 and what kind of Phones you have, SCCP or SIP?
I am in a similar situation, however I have is MGCP GW with SIP Phones.
02-08-2015 04:21 PM
SIP GW
SCCP phones
02-08-2015 07:09 PM
Ed,
Check these links.
https://supportforums.cisco.com/blog/12108326/implementing-sip-gateways-cucm
cciev.ciscovoicetech.com/call-manager-and-sip-gateway-configuration/
https://supportforums.cisco.com/discussion/10936096/srst-sip-and-sccp-endpoints
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_overview.html
~Abhi
