SIP IP Phone 9971 does'nt get dial tone and can't upgrade to the latest Fimware
cameroun
hi,
I have Cisco CME 2901.
The Ios vesion is 15.3(3)M2
The CME version is 10.0.
The IP phone 9971 Firmwares are:
dkern9971.100609R2-9-2-2SR1-9.sebn
kern9971.9-2-2SR1-9.sebn
rootfs9971.9-2-2SR1-9.sebn
sboot9971.031610R1-9-2-2SR1-9.sebn
sip9971.9-2-2SR1-9.loads
skern9971.022809R2-9-2-2SR1-9.sebn
But the problem is the internal call between  the IP Phones don't run. for exemple ip phone with dn 100 unable to call the ip phone with the dn 102. when i issue the call, nothing happen.
and more, the IP Phone are registered correctly.
on the phone, theses status messages are displayed:
File Not Found: United_States/g4-tones.xml
File Not Found: Sip_English_States/gd-sip.jar
the commands debugs , nothing happen
Attached are the resultes of the show commands.
Do i upgrade my IOS?
I've really need helps please
Ekin Gumus
hey,
can u try this?
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729br8
 codec preference 4 g729r8
then;
voice register pool  1
 id mac "mac adress"
 session-transport tcp
 type 9971
 number 1 dn 1
 dtmf-relay rtp-nte
 username brk3 password 1234
 codec g711ulaw or voice class codec 1
 no vad
 camera
 video
then please let me know if it is solved or no
m.elmaaroufi
Hi Cameroun,
I got the same issue but this time with CUCM 9.1!
If you resolved this issue please share!
Med
Ekin Gumus
hey,
can u try this?
voice class codec 1
then;
 id mac "mac adress"
 type 9971
 number 1 dn 1
 dtmf-relay rtp-nte
 no vad
 camera
 video
Hi Ekin,
and thank you for your answer, I have a CUCM 9.1.2!
