SIP IP Phone to SCCP
Jawad Ahmad
Hello all,
I'm facing a problem in our network, using SCCP and SIP IP phones. Problem is we can call from SCCP to SIP Phone and from Mobile to SIP phone working. But when we dial from SIP to SCCP or mobile its not working. How I can fix this issue.
SCCP Phones are 8941,8945.
SIP phones are 3905.
please find attached file, Running config of CME and debugs.
Suresh Hudda
Can you give "no digit collect kpml" command under voice register pool and check once.
Suresh
I found a few problems with your configuration. Here's what I see:
1. Your SIP phone (Voice register pool) is set up to use G711ulaw, but all your dial-peers are G711alaw. Additionally, your transcoders are shutdown.
voice register pool  1
 busy-trigger-per-button 2
 id mac 8890.8D73.9FDB
 type 3905
 number 1 dn 400
 cor incoming Local-Calls default
 dtmf-relay rtp-nte sip-notify
 username 400 password 400
 codec g711ulaw
dial-peer voice 10 voip
 session protocol sipv2
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711alaw
 no vad
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8
 codec g729r8
 maximum sessions 5
 associate application SCCP
 shutdown
Please enable your transcoders or fix your codec, whichever you want to use. The transcoders would be my preferred route, that way you don't break anything with CUE.
no shut
Lastly, I'm afraid your debugs provided are incomplete, if you still have issues after this please post a full "Debug ccsip messages" as well as "debug voip ccapi inout".
FG
I tried with change the codecs but it was not working.  Even  can not make a intrasite calls like 5846 to 7389.
I will no shut the transcoder and share the result.
