Which trunk would be most suited to the following application:
A UCM 7 cluster in London and a Call Manager Express enabled router in India? The IP connectivity will pass through a couple of Firewalls so all protocols will need to be specified.
Because the remote system is not going to be managed by ourselves, I was thinking a SIP trunk might be the best option. However, would an intercluster trunk be a better solution?
For CME the options are either configure them as an H323 GW or configure a SIP trunk to them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
