Walkthrough Wednesdays
1254
Highlighted
Beginner
SIP outbound on 2921 gateway
All,
We are running call manager 7 and have an 2921 set up as an h323 gateway.  We are connected to our provider via SIP trunks.  For some reason I fail immediately to fast busy on outbound dialing.  It's hitting the correct dial-peer just can't seem to make it out.  Here is the debug ccsip all.  Any ideas would be appreciated.  We also notice on inbound calls it rings but upon answering we get dead air but the calling party continues to hear it ring.
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x406930E8) with key=[951] to table
Apr  1 12:35:18: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Apr  1 12:35:18: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Apr  1 12:35:18: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Apr  1 12:35:18: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Apr  1 12:35:18: //864/000000000000/SIP/State/sipSPIChangeState: 0x406930E8 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 176
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_process_event:
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_mode_sip_sip_md:
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_mode_sip_sip_ed:
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Apr  1 12:35:18: //864/000000000000/SIP/Info/sip_iwf_h323_set_mode_hdlr:
Apr  1 12:35:18: //864/000000000000/SIP/Info/sip_iwf_h323_set_mode_hdlr: Setting SPI mode to SIP-H323
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_h323_container
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_h323_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Apr  1 12:35:18: //864/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200000
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 0, Event Id: 96
Apr  1 12:35:18: //864/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_h323_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_PEER_DO
Apr  1 12:35:18: //864/000000000000/SIP/Info/sip_iwf_h323_peer_do_hdlr:
Apr  1 12:35:18: //864/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200000
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 74.124.39.222 target_port : 5060
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [5]
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 360 to table
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1 and offer-all is = FALSE
Apr  1 12:35:18: //864/80403DA55000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=863
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_iwf_process_event:
Apr  1 12:35:18: //864/80403DA55000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_h323_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sip_iwf_h323_init_call_setup_hdlr:
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sip_iwf_h323_copy_channelInfo_to_sdp:
callid 864, channels 0x0 caps 0x0
Apr  1 12:35:18: //864/80403DA55000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 66.60.235.98
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x406930E8 key=5B12EB66-9A2911E2-8660C2F6-ED9973E1@66.60.235.98
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 5B12EB66-9A2911E2-8660C2F6-ED9973E1@66.60.235.98
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 74.124.39.222,Port 5060, Transport 2, SentBy Port 5060
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone CDT to SIP default timezone = GMT
Apr  1 12:35:18: //864/80403DA55000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Apr  1 12:35:18: //864/80403DA55000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:313A5974
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar host retrieved : 74.124.39.222
Apr  1 12:35:18: //864/80403DA55000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPISendInvite: Associated container=0x313A5974 to Invite
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipSPITransportSendMessage: msg=0x2A6EF42C, addr=74.124.39.222, port=5060, sentBy_port=0, local_addr=66.60.235.98, is_req=1, transport=2, switch=0, callBack=0x251CD5AC
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting TCP conn create request for addr=74.124.39.222, port=5060, context=0x30FD1844
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x40FA72C0,addr=74.124.39.222, port=5060
Wait Conn Timer started for 5000 msec
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x40FA72C0, connid=-1, addr=74.124.39.222, port=5060, local_addr=66.60.235.98, transport=TCP
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:74.124.39.222, rport:5060 with laddr:66.60.235.98
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x406930E8 with connection=0x40FA72C0
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipSPITransportSendMessage: Deferred sending msg=0x2A6EF42C
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUpdateCallEntry:
Call 864 set InfoType to SPEECH
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 56
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionCreated: context=0x30FD1844
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: gConnTab=0x30FD1844, addr=74.124.39.222, port=5060, local_addr=66.60.235.98, connid=3, transport=TCP
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:74.124.39.222, port:5060 local_addr=66.60.235.98 local_port=29452
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnectionCreated: Moving connection=0x40FA72C0, connid=3state to pending
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Error/sip_tcp_createconnfailed_to_spi: TCP create conn failed to SPI (addr:74.124.39.222, port:5060)
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 57
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWConnectionFailed: context=0x30FD1844
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnFailed: gConnTab=0x30FD1844, addr=74.124.39.222, port=5060, local_addr = 66.60.235.98, transport=TCP
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportStopConnWaitTimer: Wait timer stopped for connection=0x40FA72C0,addr=74.124.39.222, port=5060
Apr  1 12:35:18: //864/80403DA55000/SIP/Transport/sipTransportPostInternalMsg: Posting Internal Msg type=1
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostCloseConnection: Posting TCP conn close for addr=74.124.39.222, port=5060, local_addr=66.60.235.98, connid=3
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Transport/sipDeleteConnInstance: Deleted conn=0x40FA72C0, connid=3, addr=74.124.39.222, port=5060, local_addr=66.60.235.98, transport=TCP
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 61
Apr  1 12:35:18: //864/80403DA55000/SIP/Error/sipTransportPostSendFailure: Posting send failure msg
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 53
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_send_msg_failure: Send Error to 74.124.39.222:5060 for transport TCP
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:38, category:186
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[864], src[6]
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(38) for outgoing call
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG: No Inbound Container Created !!!
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931: No Inbound Container Created !!!
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Apr  1 12:35:18: //864/80403DA55000/SIP/State/sipSPIChangeState: 0x406930E8 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_purge_entry: Socket fd: 0 closed for connid 3 with address: 74.124.39.222, remote port: 5060
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Apr  1 12:35:18: //864/80403DA55000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:87083764 ConnTime 0
Apr  1 12:35:18: //864/80403DA55000/SIP/State/sipSPIChangeState: 0x406930E8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Apr  1 12:35:18: //864/80403DA55000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x406930E8
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 7139296800
Called Number            : 2813867708
Source IP Address (Sig  ): 66.60.235.98
Destn SIP Req Addr:Port  : 74.124.39.222:5060
Destn SIP Resp Addr:Port : 74.124.39.222:5060
Destination Name         : 74.124.39.222
Disconnect Cause (CC)    : 38
Disconnect Cause (SIP)   : 503
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 360
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[951] removed.
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x406930E8 key=5B12EB66-9A2911E2-8660C2F6-ED9973E1@66.60.235.98
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_offer_ans_delete:
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/ccsip_iwf_delete:
Apr  1 12:35:18: //864/80403DA55000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 406930E8
Apr  1 12:35:18: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[951]
GN-USHOU01-RTR01#
I have attached the configuration and also the ccsip messages.  Outbound there was nothing in the debug.  Only when I tried inbound did I see anything in the debug.
3 REPLIES 3
Highlighted
Hall of Fame Master
Please post your configuration and clean "debug ccsip messages". Also is there a reason for running H323 for one call leg and SIP for another, any reasons for not converting H323 to SIP between CUBE and CUCM?
Chris
Highlighted
Hi Chris,
Initially we set it up as an h323 gateway just like all our other GWs.  The plan was for a PRI but the carrier wouldn't get off their @#$ and get it installed so we went with SIP trunks as the sip carrier was already in the building.  Bad thing is this is our first foray into SIP so it's all new to me.  I'll post the config and debug asap.
Highlighted
VIP Mentor
Your CUBE is unable to create a TCP connection with your Provider from the ip address 66.60.235.98
Until the transport layer connection is established, nothing can happen..No INVITE will be sent out...So you need to figure out why you are unable to create a TCP connection to your provider
What is the IP address that yur provider has givn you to connect with and what is the ip adddress of on your gateway..You can send a sh run of your config
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Content for Community-Ad
