Walkthrough Wednesdays
751
KonradStepniewski
Participant
SIP outgoing call problem
Testing outgoing calls with SIP provider and getting quite odd result.
My topology:
CUCM 6.1 - trunk - CUBE-- (FW) -- inet -- SIP provider -- PSTN
When I call PSTN number via my SIP provider PSTN phone rings. When I answer the call is ended on PSTN end but my phone keeps ringing.
My Config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
h323
no h225 timeout keepalive
sip
dial-peer voice 99 voip
answer-address .T
destination-pattern .T
session protocol sipv2
session target ipv4:83.140.41.61
dtmf-relay rtp-nte
codec g711alaw
CUBE is registered with SIP provider and I'm sending correct number as CLID.
Looks like problem with signaling but not sure where is problem. Between CUBE and internet there is firewall doing NAT but tried different options and same results.
Any help really appreciated.
12 REPLIES 12
KonradStepniewski
Participant
Full debug ccsip all from one call.
You're receiving a 200 OK but it's not getting through.
Add this:
voice service voip
sip
midcall-signaling passthru
And upgrade to 12.4(24)T1
hth,
nick
Upgraded and added command to configuration but this has changed nothing.
I will open case with TAC to solve this issue.
I do have the same problem.
Please post if you are able to solve the issue.
Thank you in advance
Yes, but problem was on Juniper firewall and SIP ALG enabled. Cisco side was fine.
Seems like I'm dealing with the same issue. However, I've upgraded my 1760 to IOS release 12.4(25b) but I still don't have the option "midcall-signaling" in the SIP configuration part of voice service voip. Is this command only available on the 28xx platform?
Hi Dave,
This is in 12.4(20)T and later. 12.4(25) is still mainline (not T-train) code.
You may not be able to get this command on the 1760, as I believe IOS stopped at 12.4(15)T. You may try 12.4(15)XZ if it's available.
-nick
Hi Nick,
You're right: according to CCO the last available IOS for the 1760 platform in the T-train is 12.4(15)T10, which according to the release notes contains some new features and bugfixes but not the SIP commmands needed. Apparently the mainline releases don't include them either... Any suggestions apart from upgrading to a 28xx platform?
Cheers, dave.
IP-to-IP GW not passing messages mid-call is a serious bug and cisco should fix it in all releases no matter what.
I wonder why it has not surfaced until now.
Hi Dave,
The reason for this is because H323-SIP / SIP-SIP supplementary features weren't added until 12.4(20)T. They mostly worked, but they had not been tested and had all of the right things developed yet.
Unfortunately, there's a good chance you may not be able to get SIP-SIP / SIP-H323 features on the 12.4(15)T throttle. It's much more than a bug - there were 2 or 3 full projects to getting these features to work correctly, and they were added in 12.4(20)T.
You may have better luck with SIP-H323 than SIP-SIP, as it takes use of the H323 code which was a little more mature in the 12.4(15)T train.
-nick
Hi Nick,
I've changed the implementation to H323-SIP, now ringback tone is working fine. Thanks for your help!
Cheers, dave.
Hi Dave,
Glad I could help!
-nick
Content for Community-Ad
Spotlight Awards 2021
