SIP outgoing calls are not working on Cisco 4331
Bothra Group
Hi all,
we have 3 locations connected with MPLS line and internal calls are working fine.we have taken SIP for outgoing calls in one location. SIP connected to cisco 4331 router. outbound calls are not working. attached is my debug and config.
Please do the needful.
27 Replies 27
Bothra Group
Dear Roger,
I have done as you suggested but no luck.
This debug does not show the registration for the ITSP, it only includes registration events for desk phones. If you please could provide your complete running configuration, as it stands after you have done the suggested changes, in a plain text file so that we can control your configuration it would be great.
Response Signature
Bothra Group
Dear Roger,
I have done some modifications. now incoming and outgoing calls are working for two phones only as i specified sip profiles and translated rule. how ca i add all DID numbers to all extensions.
Please find the below running config of cisco 4331.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2024.06.24 09:11:17 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 22129 bytes
! Last configuration change at 22:08:39 IST Sat Jun 22 2024 by admin
! NVRAM config last updated at 01:49:27 IST Sun Jun 23 2024 by admin
version 17.6
service timestamps log datetime localtime
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname VTZ_ISR_4331
boot-start-marker
boot system flash
boot system flash:/isr4300-universalk9.17.06.01a.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
--More--   address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 9 $9$WrtXRWqju01Ouk$/ce2Imoix5bAF2VjR4wPEVY9Sn7fmwUlabUo/IvpuYw
aaa new-model
aaa session-id common
clock timezone IST 5 30
clock calendar-valid
--More--  !
ip host ap.ims.airtel.in 10.5.109.147
ip name-server 172.17.40.63 172.16.10.51 8.8.8.8
ip domain name bothragroup.local
login on-success log
subscriber templating
--More--  !
password encryption aes
crypto pki trustpoint TP-self-signed-1642857267
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1642857267
revocation-check none
rsakeypair TP-self-signed-1642857267
D697DF7F 28
quit
voice service voip
ip address trusted list
ipv4 172.17.27.59
ipv4 192.168.5.8
ipv4 172.17.40.8
ipv4 10.125.41.230
ipv4 10.5.109.147
ipv4 10.5.64.98
ipv4 10.5.64.99
ipv4 10.5.64.114
ipv4 10.5.64.115
ipv4 10.5.64.66
ipv4 10.5.64.67
ipv4 10.5.64.82
--More--   ipv4 10.5.64.83
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
trace
sip
registrar server expires max 120 min 60
localhost dns:ap.ims.airtel.in
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity modify "187@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
--More--   request INVITE sip-header From modify "187@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header P-Asserted-Identity modify "190@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header From modify "190@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
voice register global
mode cme
source-address 172.17.40.8 port 5600
max-dn 200
max-pool 100
timezone 39
date-format D/M/Y
create profile sync 0015144571460344
auto-register
voice register dn 1
--More--   number 101
name Reception
no-reg
label Reception
voice register dn 87
number 187
name IT
no-reg
label IT
voice register pool 1
busy-trigger-per-button 2
id mac 8C1E.809A.2478
type 7841
--More--   number 1 dn 1
dtmf-relay cisco-rtp
username Ipphone101 password xxxx
codec g711ulaw
voice translation-rule 101
rule 1 /^0\(.*\)/ /\1/
voice translation-rule 102
rule 1 /^.918914560050/ /187/
rule 2 /^.918914560051/ /190/
rule 3 /08914560050/ /187/
rule 4 /08914560051/ /190/
voice translation-rule 190
--More--  !
voice translation-profile 101
translate called 101
voice translation-profile 102
translate called 102
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
voice-card 0/4
no watchdog
voice-card 1/0
--More--   no watchdog
license udi pid ISR4331/K9 sn FDO26401TY2
license boot level uck9
redundancy
mode none
--More--  !
interface GigabitEthernet0/0/0
ip address 172.17.40.8 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/1
ip address 172.49.53.22 255.255.255.252
negotiation auto
interface GigabitEthernet0/0/2
ip address 10.125.41.230 255.255.255.252
negotiation auto
interface Service-Engine0/1/0
interface Service-Engine0/2/0
interface Service-Engine0/4/0
interface Service-Engine1/0/0
vrf forwarding Mgmt-intf
--More--   no ip address
negotiation auto
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip http path flash:CME_GUI
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.17.40.1
ip route 10.5.64.0 255.255.255.0 10.125.41.229
ip route 10.5.109.0 255.255.255.0 10.125.41.229
ip route 172.17.24.0 255.255.252.0 172.49.53.21
ip route 172.17.27.0 255.255.255.0 172.49.53.21
ip route 172.38.44.0 255.255.255.0 172.49.53.21
ip route 192.168.5.0 255.255.255.0 172.49.53.21
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
--More--  !
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 1/0/24
voice-port 1/0/25
voice-port 1/0/26
voice-port 1/0/27
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
max-ephones 50
max-dn 100
ip source-address 172.17.40.8 port 2000
--More--   time-zone 39
date-format dd-mm-yy
max-conferences 8 gain -6
moh enable-g711 "webui:aaa.odm"
transfer-system full-consult
transfer-pattern 1..
secondary-dialtone 0
create cnf-files version-stamp 7960 Jun 21 2024 13:06:46
dspfarm profile 1 transcode universal
associate application CUBE
shutdown
dial-peer voice 900 voip
description KolCUCM
destination-pattern 9..
session protocol sipv2
session target ipv4:172.17.27.59
session transport tcp
incoming called-number 1..
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
--More--   dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 1 voip
description KkdCME
destination-pattern 8..
session target ipv4:192.168.5.8
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 101 voip
description # Outgoing call to PSTN #
destination-pattern 0T
session target sip-server
session transport udp
voice-class sip dtmf-relay force rtp-nte
no voice-class sip early-offer forced
voice-class sip profiles 1
--More--   voice-class sip bind control source-interface GigabitEthernet0/0/2
voice-class sip bind media source-interface GigabitEthernet0/0/2
dtmf-relay rtp-nte sip-kpml
codec g711ulaw
no vad
dial-peer voice 102 voip
description # Incoming call from SIP Trunk #
translation-profile incoming 102
incoming called-number .%
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials number +91891456xx username +91891456xx@ap.ims.xxxxx.in password xxxx realm ap.ims.xxxx.in
authentication username +918914560xxx@ap.ims.xxx.in password 6 xxxx realm ap.ims.xxxx.in
--More--   no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:ap.ims.airtel.in expires 300
sip-server dns:ap.ims.airtel.in
connection-reuse
host-registrar
destination transport-method http
ntp server time.google.com
ntp server time.cloudflare.com
ntp server 0.in.pool.ntp.org
end
VTZ_ISR_4331#
VTZ_ISR_4331#
VTZ_ISR_4331#
Bothra Group
Dear Roger,
I have done some modifications and now able to do outgoing and incoming for two phones. please find the attached running config and suggest me for sip profiles and translation rules.
voice service voip
ipv4 172.17.27.59
ipv4 192.168.5.8
ipv4 172.17.40.8
ipv4 10.125.41.230
ipv4 10.5.109.147
ipv4 10.5.64.98
ipv4 10.5.64.99
ipv4 10.5.64.114
ipv4 10.5.64.115
ipv4 10.5.64.66
ipv4 10.5.64.67
ipv4 10.5.64.82
mode border-element
trace
sip
voice class codec 1
mode cme
max-dn 200
max-pool 100
timezone 39
date-format D/M/Y
auto-register
--More--  !
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
retry invite 2
retry register 10
timers connect 100
connection-reuse
host-registrar
Bothra Group
sh run
version 17.6
service call-home
boot-start-marker
boot system flash
boot-end-marker
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
--More--  !
--More--  !
D697DF7F 28
quit
voice service voip
ipv4 172.17.27.59
ipv4 192.168.5.8
ipv4 172.17.40.8
ipv4 10.125.41.230
ipv4 10.5.109.147
ipv4 10.5.64.98
ipv4 10.5.64.99
ipv4 10.5.64.114
ipv4 10.5.64.115
ipv4 10.5.64.66
ipv4 10.5.64.67
ipv4 10.5.64.82
mode border-element
trace
sip
voice class codec 1
mode cme
max-dn 200
max-pool 100
timezone 39
date-format D/M/Y
auto-register
voice register dn 1
--More--   number 101
name Reception
no-reg
label Reception
number 187
name IT
no-reg
label IT
type 7841
codec g711ulaw
--More--  !
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
voice-card 0/4
no watchdog
voice-card 1/0
redundancy
mode none
--More--  !
negotiation auto
negotiation auto
negotiation auto
negotiation auto
ip http server
--More--  !
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 1/0/24
voice-port 1/0/25
voice-port 1/0/26
voice-port 1/0/27
telephony-service
max-ephones 50
max-dn 100
shutdown
description KolCUCM
codec g711ulaw
description KkdCME
dtmf-relay rtp-nte
codec g711ulaw
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
retry invite 2
retry register 10
timers connect 100
connection-reuse
host-registrar
end
VTZ_ISR_4331#
VTZ_ISR_4331#
VTZ_ISR_4331#
Bothra Group
Hi Roger,
Im unable to upload txt file. Please find the attached runnning config. now i,m able to to do outgoing and incoming for two numbers only. request you to help me on sip profiles and translation rules for extension numbers.
Thanks in advance
Bothra Group
Dear Roger,
how can i write sip profile for below details.
DID Range 8914560050 to 8914560079
Intercom numbers 141 to 190 (Cisco IP Phones Model :7841)
SBC IP: 10.5.109.147
Domain ap.ims.airtel.in
Username +918914560050@ap.ims.airtel.in
At present i wrote profile for particular numbers. i.e
Now i can able to outgoing calls from those extension numbers only.
You don’t need to be that specific in the match part of your SIP profile. If you use this it would match any of your numbers.
request INVITE sip-header P-Asserted-Identity modify ".*@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
request INVITE sip-header From modify ".*@ap.ims.airtel.in" "+918914560050@ap.ims.airtel.in"
Response Signature
Dear Roger,
I'm unable to do outgoing calls if I specify sip-profile as you suggested. below are the debug ccsip messages output.
VTZ_ISR_4331#
Jun 24 11:44:16.545: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.17.40.8 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.115:5060;branch=z9hG4bK5e7dbe14
From: <sip:132@172.17.40.8>;tag=3891b747f00f2c6131c2c3ff-6577b55b
To: <sip:132@172.17.40.8>
Call-ID: 3891b747-f00f0094-0668a2cc-4eec92cf@172.17.40.115
Max-Forwards: 70
Session-ID: 1193838300105000a0003891b747f00f;remote=00000000000000000000000000000000
Date: Mon, 24 Jun 2024 11:44:24 GMT
CSeq: 11175 REGISTER
User-Agent: Cisco-CP7841/14.0.1
Contact: <sip:1E5C9-788@172.17.40.115:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f00f>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F00F";+u.sip!model.ccm.cisco.com="622"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Jun 24 11:44:16.547: //91886/EB8A36A18D0B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:132@172.17.40.8>;tag=10580D2A-1D91
Date: Mon, 24 Jun 2024 11:44:16 GMT
Server: Cisco-SIPGateway/IOS-17.6.1a
Supported: X-cisco-cme-sis-9.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:132@172.17.40.115:5060>;expires=120
Expires: 120
Content-Length: 0
Jun 24 11:44:17.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0@172.17.40.8;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK7b877bfd
From: "IT" <sip:187@172.17.40.8>;tag=3891b747f24005d756da8016-08a93196
To: <sip:0@172.17.40.8>
Call-ID: 3891b747-f240003c-6fdef801-00447158@172.17.40.137
Max-Forwards: 70
Session-ID: 0d2ecf6500105000a0003891b747f240;remote=00000000000000000000000000000000
Date: Mon, 24 Jun 2024 11:44:19 GMT
CSeq: 101 INVITE
Contact: <sip:1E63B-161A@172.17.40.137:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP3891B747F240"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "IT" <sip:187@172.17.40.8>;party=calling;id-type=subscriber;privacy=off;screen=yes
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 351
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 14123 0 IN IP4 172.17.40.137
s=SIP Call
b=AS:4064
t=0 0
m=audio 31050 RTP/AVP 0 8 116 18 101
c=IN IP4 172.17.40.137
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
Jun 24 11:44:17.728: //91887/EC3DA7938D0C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 24 Jun 2024 11:44:17 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Session-ID: 00000000000000000000000000000000;remote=0d2ecf6500105000a0003891b747f240
Content-Length: 0
Jun 24 11:44:17.806: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:0@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK553844a4
To: <sip:0@ap.ims.airtel.in>;tag=105811C7-56E
From: <sip:187@172.17.40.137>;tag=3891b747f24005d825107ce7-50f536fe
Call-ID: EC3E6B11-315511EF-8D11B5FF-AEC501B5@ap.ims.airtel.in
Session-ID: 5f82aa6500105000a0003891b747f240;remote=00000000000000000000000000000000
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 0
Jun 24 11:44:19.001: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK16a43764
Date: Mon, 24 Jun 2024 11:44:20 GMT
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Content-Type: application/kpml-response+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="8" tag="Backspace OK"/>
Jun 24 11:44:19.308: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK494c25cd
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="9" tag="Backspace OK"/>
Jun 24 11:44:19.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK2a8d97d2
Date: Mon, 24 Jun 2024 11:44:21 GMT
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="7" tag="Backspace OK"/>
Jun 24 11:44:19.978: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK5ac05595
CSeq: 1004 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Jun 24 11:44:20.296: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK11225d80
CSeq: 1005 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="1" tag="Backspace OK"/>
Jun 24 11:44:20.628: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK589cb679
Date: Mon, 24 Jun 2024 11:44:22 GMT
CSeq: 1006 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Jun 24 11:44:20.901: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK291133e9
CSeq: 1007 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
Jun 24 11:44:21.238: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK3718bfc8
CSeq: 1008 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="4" tag="Backspace OK"/>
Jun 24 11:44:21.548: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK2b76f8cf
Date: Mon, 24 Jun 2024 11:44:23 GMT
CSeq: 1009 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Jun 24 11:44:21.858: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK48bc69cf
CSeq: 1010 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="3" tag="Backspace OK"/>
Jun 24 11:44:22.536: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.182:5060;branch=z9hG4bK27a2d10e
From: <sip:121@172.17.40.8>;tag=8c1e809a24e57ba85e4e7d8d-5d099411
To: <sip:121@172.17.40.8>
Call-ID: 8c1e809a-24e501e0-00fb7796-1ebe0aae@172.17.40.182
Max-Forwards: 70
Session-ID: 9d2f7ab700105000a0008c1e809a24e5;remote=00000000000000000000000000000000
Date: Mon, 24 Jun 2024 11:44:29 GMT
CSeq: 30783 REGISTER
Contact: <sip:1E5AA-DA9@172.17.40.182:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a24e5>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A24E5";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Jun 24 11:44:22.539: //91888/EF1C5DFB8D12/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:121@172.17.40.8>;tag=10582492-452
Contact: <sip:121@172.17.40.182:5060>;expires=120
Expires: 120
Content-Length: 0
Jun 24 11:44:29.377: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.158:5060;branch=z9hG4bK3b70e065
From: <sip:190@172.17.40.8>;tag=8c1e809a251300c16fa68f83-170a9aeb
To: <sip:190@172.17.40.8>
Call-ID: 8c1e809a-25130002-76050729-56c2e900@172.17.40.158
Max-Forwards: 70
Session-ID: 6a6bbdd900105000a0008c1e809a2513;remote=00000000000000000000000000000000
CSeq: 254 REGISTER
Contact: <sip:1E609-E29@172.17.40.158:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a2513>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2513";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Jun 24 11:44:29.380: //91889/F33038FF8D13/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:190@172.17.40.8>;tag=10583F4B-1038
CSeq: 254 REGISTER
Contact: <sip:190@172.17.40.158:5060>;expires=120
Expires: 120
Content-Length: 0
Jun 24 11:44:31.857: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK723029d7
Date: Mon, 24 Jun 2024 11:44:33 GMT
CSeq: 1011 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 215
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="423" text="Timer Expired" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
Jun 24 11:44:31.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK3a91cb77
CSeq: 1012 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Content-Length: 218
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
Jun 24 11:44:32.048: //91890/EC3DA7938D0C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:08978180483@ap.ims.airtel.in:5060 SIP/2.0
Via: SIP/2.0/UDP 10.125.41.230:5060;branch=z9hG4bK3053EE0
To: <sip:08978180483@ap.ims.airtel.in>
Date: Mon, 24 Jun 2024 11:44:32 GMT
Call-ID: F4AB3F9D-315511EF-8D15B5FF-AEC501B5@ap.ims.airtel.in
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3963463571-0827658735-2366420479-2932146613
User-Agent: Cisco-SIPGateway/IOS-17.6.1a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1719229472
Contact: <sip:187@10.125.41.230:5060>
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
Content-Length: 249
+918914560050@ap.ims.airtel.in>;tag=105849B7-1D11
v=0
o=CiscoSystemsSIP-GW-UserAgent 264 1023 IN IP4 10.125.41.230
s=SIP Call
c=IN IP4 10.125.41.230
t=0 0
m=audio 10068 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
Jun 24 11:44:32.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.179:5060;branch=z9hG4bK21c83cf7
From: <sip:151@172.17.40.8>;tag=8c1e809a253f29aa6df65de0-26c56699
To: <sip:151@172.17.40.8>
Call-ID: 8c1e809a-253f0038-44ffc6ab-144b03a8@172.17.40.179
Max-Forwards: 70
Session-ID: d2b05f6d00105000a0008c1e809a253f;remote=00000000000000000000000000000000
Date: Mon, 24 Jun 2024 11:44:39 GMT
CSeq: 10659 REGISTER
User-Agent: Cisco-CP7841/14.1.1
Contact: <sip:1E58E-A5C@172.17.40.179:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-8c1e809a253f>";+u.sip!devicename.ccm.cisco.com="SEP8C1E809A253F";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Jun 24 11:44:32.281: //91891/F4EB08E38D16/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:151@172.17.40.8>;tag=10584AA0-1A57
Contact: <sip:151@172.17.40.179:5060>;expires=120
Expires: 120
Content-Length: 0
Jun 24 11:44:32.549: //91890/EC3DA7938D0C/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Jun 24 11:44:33.549: //91890/EC3DA7938D0C/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1719229473
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Jun 24 11:44:35.550: //91887/EC3DA7938D0C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
To: <sip:0@172.17.40.8>;tag=10585765-78
CSeq: 101 INVITE
Reason: Q.850;cause=102
Content-Length: 0
Jun 24 11:44:35.578: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0@172.17.40.8;user=phone SIP/2.0
Max-Forwards: 70
Date: Mon, 24 Jun 2024 11:44:37 GMT
CSeq: 101 ACK
Content-Length: 0
Jun 24 11:44:35.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:168@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.5.8:5060;branch=z9hG4bK12B8AB1
From: "Bikash" <sip:805@192.168.5.8>;tag=77B98F68-2047
To: <sip:168@172.17.40.8>;tag=1057CC6A-213
Date: Mon, 24 Jun 2024 11:43:59 GMT
Call-ID: E191B8B4-315511EF-AC1CE9A9-4928BFF3@192.168.5.8
Max-Forwards: 70
Timestamp: 1719229475
CSeq: 103 BYE
Reason: Q.850;cause=16
Session-ID: 7052f7b800105000a0003891b747f426;remote=12e1d2c800105000a0003891b747f202
Content-Length: 0
Jun 24 11:44:35.970: //91882/E0F74DBCAC14/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 24 Jun 2024 11:44:35 GMT
CSeq: 103 BYE
Session-ID: 12e1d2c800105000a0003891b747f202;remote=7052f7b800105000a0003891b747f426
Content-Length: 0
Jun 24 11:44:35.970: //91883/E0F74DBCAC14/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:1E629-7F@172.17.40.163:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK3054ADC
From: "Bikash" <sip:805@ap.ims.airtel.in>;tag=1057CBD8-501
To: <sip:168@172.17.40.163>;tag=3891b747f202783a7ec8060a-2c27adb2
Call-ID: E1927C32-315511EF-8D08B5FF-AEC501B5@ap.ims.airtel.in
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
Jun 24 11:44:36.085: //91883/E0F74DBCAC14/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Server: Cisco-CP7841/14.0.1
Content-Length: 0
77160: Jun 24 11:44:36.110: //91890/EC3DA7938D0C/
------------------ Cover Buffer ---------------
Search-key = 187:08978180483:91890
Timestamp = Jun 24 11:44:31.859
CallID = 91890
Peer-CallID = 91887
Correlator = NA
Called-Number = 08978180483
Calling-Number = 187
SIP CallID = F4AB3F9D-315511EF-8D15B5FF-AEC501B5@ap.ims.airtel.in
SIP SessionID =
GUID = EC3DA7938D0C
77054: Jun 24 11:44:31.859: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir:Outbound, Peer-Tag: 101
77055: Jun 24 11:44:31.859: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77056: Jun 24 11:44:31.859: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_SET_MODE, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
77057: Jun 24 11:44:31.860: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PRE_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
77063: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_PEER_MULTIMEDIA_CHANNEL_IND, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
77064: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec = No Codec , Negotiated DTMF Type = inband-voice, Stream Index = 1
77065: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_allocate_port (10068)
77066: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Media-State: Event = E_IPIP_MEDIA_SERV_EV_PEER_CHNL_IND, Current State = S_IPIP_MEDIA_SERV_STATE_IDLE, Next State = S_IPIP_MEDIA_SERV_STATE_INIT_XCODER_RESERVED
77067: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: ccsip_xcoder_reserve (-1)
77068: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_CONTINUE_PRE_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
77069: Jun 24 11:44:31.860: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_INIT_CALL_SETUP, Current State = S_SIP_IWF_SDP_IDLE, Next State = CNFSM_NO_STATE_CHANGE
77070: Jun 24 11:44:31.860: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
77071: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_SETUP, Current State = STATE_IDLE
77072: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_IDLE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_IDLE
77073: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_IDLE, Current Sub-State = STATE_IDLE, Next Sub-State = STATE_IDLE
77074: Jun 24 11:44:31.861: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_call_proceeding (0)
77075: Jun 24 11:44:32.045: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_DNS_RESOLVED, Current State = STATE_IDLE
77076: Jun 24 11:44:32.045: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_IDLE, Current Sub-State = STATE_IDLE, Next Sub-State = STATE_NONE
77077: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_create_session (0)
77078: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
77079: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
77080: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_SDP_SENT, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State = S_SIP_EARLY_DIALOG_OFFER_SENT
77081: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_SENT_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_SENT_AWAIT_SDP
77082: Jun 24 11:44:32.048: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_SENT_INVITE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77083: Jun 24 11:44:32.048: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
77084: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
77085: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
77086: Jun 24 11:44:32.047: //91890/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent: SIP UDP message from 10.125.41.230:5060 to 10.5.109.147:5060
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
77091: Jun 24 11:44:32.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_TRYING, Current State = STATE_SENT_INVITE
77092: Jun 24 11:44:32.548: //91890/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
77095: Jun 24 11:44:33.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_TRYING, Current State = STATE_SENT_INVITE
77096: Jun 24 11:44:33.548: //91890/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
77099: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_TRYING, Current State = STATE_SENT_INVITE
77100: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x170396B, Originated at:0x1E000FD, Cause Code = 102
77101: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_call_disconnected (0)
77102: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_SENT_INVITE, Next State = STATE_DISCONNECTING, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77103: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x260070A, Originated at:0x260070B, Cause Code = 102
77104: Jun 24 11:44:35.546: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
77105: Jun 24 11:44:35.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_DISCONNECTING
77106: Jun 24 11:44:35.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_delete_dp_session (0)
77107: Jun 24 11:44:35.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_call_disconnect_done (0)
77108: Jun 24 11:44:35.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77109: Jun 24 11:44:35.548: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Error: sipSPIFlushDeferredQueue: Invalid deferredQueue
77110: Jun 24 11:44:35.548: //91890/EC3DA7938D0C/CUBE_VT/SIP/MISC/Error: ws_call_fork_cleanup: ws_info is NULL
77111: Jun 24 11:44:35.547: //91890/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_release_port (10068)
77161: Jun 24 11:44:36.114: //91887/EC3DA7938D0C/
Search-key = 187:0:91887
Timestamp = Jun 24 11:44:17.721
CallID = 91887
Peer-CallID = 91890
Correlator = NA
Called-Number = 0
SIP CallID = 3891b747-f240003c-6fdef801-00447158@172.17.40.137
SIP SessionID =
GUID = EC3DA7938D0C
77019: Jun 24 11:44:17.721: //91887/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received: SIP UDP message from 172.17.40.137:5060 to 172.17.40.8:5060
Max-Forwards: 70
CSeq: 101 INVITE
Expires: 180
Content-Length: 351
v=0
s=SIP Call
b=AS:4064
t=0 0
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
77023: Jun 24 11:44:17.722: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77024: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir:Inbound, Peer-Tag: 40027
77025: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Offer-Answer: Event = E_SIP_INVITE_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State = S_SIP_EARLY_DIALOG_OFFER_RCVD
77026: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_RCVD_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT
77027: Jun 24 11:44:17.723: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type = voice+dtmf, Stream State = STREAM_ADDING Negotiated Codec = g711ulaw, Negotiated DTMF Type = rtp-nte, Stream Index = 1
77028: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
77029: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_allocate_port (10066)
77030: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type = voice+dtmf, Stream State = STREAM_ADDING Negotiated Codec = g711ulaw, Negotiated DTMF Type = rtp-nte, Stream Index = 1
77031: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_call_setup_ind_with_callID (0)
77032: Jun 24 11:44:17.724: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_IDLE, Next State = STATE_RECD_INVITE, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77033: Jun 24 11:44:17.727: //91887/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent: SIP UDP message from 172.17.40.8:5060 to 172.17.40.137:5060
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
77034: Jun 24 11:44:19.003: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'8/'
77035: Jun 24 11:44:19.103: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77036: Jun 24 11:44:19.308: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'9/'
77037: Jun 24 11:44:19.409: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77038: Jun 24 11:44:19.693: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'7/'
77039: Jun 24 11:44:19.792: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77040: Jun 24 11:44:19.977: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'8/'
77041: Jun 24 11:44:20.078: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77042: Jun 24 11:44:20.296: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'1/'
77043: Jun 24 11:44:20.398: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77044: Jun 24 11:44:20.628: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'8/'
77045: Jun 24 11:44:20.729: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77046: Jun 24 11:44:20.900: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'0/'
77047: Jun 24 11:44:21.001: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77048: Jun 24 11:44:21.237: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'4/'
77049: Jun 24 11:44:21.337: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77050: Jun 24 11:44:21.547: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'8/'
77051: Jun 24 11:44:21.647: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77052: Jun 24 11:44:21.857: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/DTMF Digit: Type: KPML-Digit-Notify, Dir: Received, DIGIT: /'3/'
77053: Jun 24 11:44:21.957: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Timer-Action: Event = SIP_TIMER_DIGIT, Current State = STATE_RECD_INVITE
77058: Jun 24 11:44:31.860: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_IWF_EV_SET_MODE, Current State = CNFSM_CONTAINER_STATE, Next State = CNFSM_NO_STATE_CHANGE
77059: Jun 24 11:44:31.860: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_create_session (0)
77060: Jun 24 11:44:31.860: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
77061: Jun 24 11:44:31.860: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
77062: Jun 24 11:44:31.861: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_PROCEEDING, Current State = STATE_RECD_INVITE
77112: Jun 24 11:44:35.548: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x260070A, Originated at:0x260070B, Cause Code = 102
77113: Jun 24 11:44:35.548: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
77114: Jun 24 11:44:35.548: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_RECD_INVITE
77115: Jun 24 11:44:35.547: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_RECD_INVITE, Next State = STATE_DISCONNECTING, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77116: Jun 24 11:44:35.548: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_DISCONNECTING, Next State = STATE_DISCONNECTING, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77117: Jun 24 11:44:35.548: //91887/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
CSeq: 101 INVITE
Content-Length: 0
77119: Jun 24 11:44:35.577: //91887/EC3DA7938D0C/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
77120: Jun 24 11:44:35.577: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/Event-Action: Event = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_DISCONNECTING
77121: Jun 24 11:44:35.577: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_delete_dp_session (0)
77122: Jun 24 11:44:35.578: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: cc_api_call_disconnect_done (0)
77123: Jun 24 11:44:35.579: //91887/EC3DA7938D0C/CUBE_VT/SIP/FSM/SPI-State-Change: Current State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State = STATE_NONE, Next Sub-State = STATE_NONE
77124: Jun 24 11:44:35.579: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Error: sipSPIFlushDeferredQueue: Invalid deferredQueue
77125: Jun 24 11:44:35.579: //91887/EC3DA7938D0C/CUBE_VT/SIP/MISC/Error: ws_call_fork_cleanup: ws_info is NULL
77126: Jun 24 11:44:35.579: //91887/EC3DA7938D0C/CUBE_VT/SIP/API: voip_rtp_release_port (10066)
Jun 24 11:44:40.198: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1@172.17.40.8;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK4bf78efd
From: "IT" <sip:187@172.17.40.8>;tag=3891b747f24005da5c1896fc-1d4e603c
To: <sip:1@172.17.40.8>
Call-ID: 3891b747-f240003e-45919227-5328588a@172.17.40.137
Max-Forwards: 70
Session-ID: 4957c8ea00105000a0003891b747f240;remote=00000000000000000000000000000000
Date: Mon, 24 Jun 2024 11:44:41 GMT
CSeq: 101 INVITE
Expires: 180
Content-Length: 351
v=0
o=Cisco-SIPUA 23905 0 IN IP4 172.17.40.137
s=SIP Call
b=AS:4064
t=0 0
m=audio 23990 RTP/AVP 0 8 116 18 101
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
Jun 24 11:44:40.204: //91892/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 24 Jun 2024 11:44:40 GMT
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=4957c8ea00105000a0003891b747f240
Content-Length: 0
Jun 24 11:44:40.301: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:1@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK54a0c093
To: <sip:1@ap.ims.airtel.in>;tag=10586994-263C
From: <sip:187@172.17.40.137>;tag=3891b747f24005db1d92d194-3731a806
Call-ID: F9A3FCCB-315511EF-8D1CB5FF-AEC501B5@ap.ims.airtel.in
CSeq: 1000 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 0
Jun 24 11:44:40.511: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK0ccc19ac
Date: Mon, 24 Jun 2024 11:44:42 GMT
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Jun 24 11:44:40.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK32b92403
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
Jun 24 11:44:40.849: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:190@172.17.40.158:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK3057201E
From: "IT" <sip:187@ap.ims.airtel.in>;tag=10586C19-2084
To: <sip:190@172.17.40.158>
Call-ID: FA0666F8-315511EF-8D1EB5FF-AEC501B5@ap.ims.airtel.in
Min-SE: 1800
Cisco-Guid: 4188233891-0827658735-2367141375-2932146613
CSeq: 101 INVITE
Timestamp: 1719229480
Contact: <sip:187@172.17.40.8:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 9278 7554 IN IP4 172.17.40.8
s=SIP Call
c=IN IP4 172.17.40.8
t=0 0
m=audio 10072 RTP/AVP 0 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jun 24 11:44:40.863: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 3182f52700105000a0008c1e809a2513;remote=4957c8ea00105000a0003891b747f240
CSeq: 101 INVITE
Contact: <sip:1E609-E29@172.17.40.158:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP8C1E809A2513"
Content-Length: 0
Jun 24 11:44:40.882: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.137:5060;branch=z9hG4bK79b13d7b
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 218
Jun 24 11:44:40.998: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:190@172.17.40.158>;tag=8c1e809a251300c22cc54271-12258173
CSeq: 101 INVITE
Remote-Party-ID: "Phalguna Ravindra" <sip:190@172.17.40.8>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Jun 24 11:44:41.000: //91892/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:1@172.17.40.8>;tag=10586CAF-A5C
CSeq: 101 INVITE
Contact: <sip:1E609-E29@172.17.40.8:5060>
Content-Length: 0
Jun 24 11:44:41.884: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:1@172.17.40.8;user=phone SIP/2.0
Max-Forwards: 70
Session-ID: 4957c8ea00105000a0003891b747f240;remote=3182f52700105000a0008c1e809a2513
Date: Mon, 24 Jun 2024 11:44:43 GMT
CSeq: 101 CANCEL
Content-Length: 0
Jun 24 11:44:41.887: //91892/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Jun 24 11:44:41.888: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:190@172.17.40.158:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1719229481
Content-Length: 0
Jun 24 11:44:41.888: //91892/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
Jun 24 11:44:41.895: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Jun 24 11:44:41.902: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
Jun 24 11:44:41.903: //91893/F9A360A38D17/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:190@172.17.40.158:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun 24 11:44:41.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1@172.17.40.8;user=phone SIP/2.0
Session-ID: 5f82aa6500105000a0003891b747f240;remote=4957c8ea00105000a0003891b747f240
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jun 24 11:44:42.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:153@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.5.8:5060;branch=z9hG4bK12BB24C4
Remote-Party-ID: "Bikash" <sip:805@192.168.5.8>;party=calling;screen=yes;privacy=off
From: "Bikash" <sip:805@192.168.5.8>;tag=77BA34A0-757
To: <sip:153@172.17.40.8>
Call-ID: FAC795D5-315511EF-AC29E9A9-4928BFF3@192.168.5.8
Min-SE: 1800
Cisco-Guid: 4199893809-0827658735-2887969193-1227407347
CSeq: 101 INVITE
Timestamp: 1719229482
Contact: <sip:805@192.168.5.8:5060>
Expires: 180
Max-Forwards: 69
Session-ID: 71a9fdf400105000a0003891b747f426;remote=00000000000000000000000000000000
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 4398 6303 IN IP4 192.168.5.8
s=SIP Call
c=IN IP4 192.168.5.8
t=0 0
m=audio 13810 RTP/AVP 0 101 19
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jun 24 11:44:42.119: //91894/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=71a9fdf400105000a0003891b747f426
Content-Length: 0
Jun 24 11:44:42.120: //91895/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:153@172.17.40.154:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.40.8:5060;branch=z9hG4bK30588B4
From: "Bikash" <sip:805@ap.ims.airtel.in>;tag=1058710F-EF4
To: <sip:153@172.17.40.154>
Call-ID: FAC831FD-315511EF-8D24B5FF-AEC501B5@ap.ims.airtel.in
Min-SE: 1800
CSeq: 101 INVITE
Contact: <sip:805@172.17.40.8:5060>
Expires: 180
Max-Forwards: 68
Content-Length: 269
v=0
o=CiscoSystemsSIP-GW-UserAgent 2330 3657 IN IP4 172.17.40.8
s=SIP Call
t=0 0
m=audio 10076 RTP/AVP 0 121 19
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jun 24 11:44:42.134: //91895/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 3f47d5d600105000a0003891b747f04c;remote=71a9fdf400105000a0003891b747f426
Date: Mon, 24 Jun 2024 11:44:49 GMT
CSeq: 101 INVITE
Contact: <sip:1E615-1833@172.17.40.154:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP3891B747F04C"
Content-Length: 0
Jun 24 11:44:42.233: //91895/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:153@172.17.40.154>;tag=3891b747f04c757f6e1e8736-369ad3b2
CSeq: 101 INVITE
Remote-Party-ID: "Pritesh Jain" <sip:153@172.17.40.8>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Jun 24 11:44:42.235: //91894/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:153@172.17.40.8>;tag=10587183-1636
CSeq: 101 INVITE
Require: 100rel
RSeq: 8612
Contact: <sip:1E615-1833@172.17.40.8:5060>
Content-Length: 0
Jun 24 11:44:42.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:1E615-1833@172.17.40.8:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.5.8:5060;branch=z9hG4bK12BC290
CSeq: 102 PRACK
RAck: 8612 101 INVITE
Max-Forwards: 70
Session-ID: 71a9fdf400105000a0003891b747f426;remote=3f47d5d600105000a0003891b747f04c
Content-Length: 0
Jun 24 11:44:42.245: //91894/FA554B31AC22/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Jun 24 11:44:43.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.17.40.136:5060;branch=z9hG4bK180416e5
From: <sip:122@172.17.40.8>;tag=3891b747f04a24f9794aab0f-0964929d
To: <sip:122@172.17.40.8>
Call-ID: 3891b747-f04a0049-49509d7d-38eb2ed2@172.17.40.136
Max-Forwards: 70
Session-ID: 144c266300105000a0003891b747f04a;remote=00000000000000000000000000000000
CSeq: 9327 REGISTER
Contact: <sip:1E5B0-742@172.17.40.136:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-3891b747f04a>";+u.sip!devicename.ccm.cisco.com="SEP3891B747F04A";+u.sip!model.ccm.cisco.com="622"
Content-Length: 0
Expires: 3600
Jun 24 11:44:43.428: //91896/FB8FC7108D25/SIP/Msg/ccsipDisplayMsg:
Sent:
VTZ_ISR_4331#SIP/2.0 200 OK
To: <sip:122@172.17.40.8>;tag=1058762B-13B3
CSeq: 9327 REGISTER
Contact: <sip:122@172.17.40.136:5060>;expires=120
Expires: 120
Content-Length: 0
Please repost the output in an attached plain text file. It’s not practical to work on the output if you put it directly into the reply as we would need to copy the whole thing into a suitable text editor such as Notepad++.
Response Signature
I'm unable to upload txt file here. showing error
Dear Roger,
Bothra Group
Dear Roger,
Please find the attached file and suggest me.
