SIP Phone (7841) getting unregister frequently
gpsriramdc
Level 4
Level 4
Hi All,
7841 Phone in Remote site (Over the WAN) getting unregistered frequently. Everytime phone unregistered due to keepalive timeout with cause code 13.
Has any other fine tuning can be do in CUCM avoid this frequent unregistration
42625628.000 |17:18:39.909 |SdlSig |SIPStationDPrimaryLineTimeout |wait |SIPStationD(2,100,73,15984) |SdlTimerService(2,100,3,1) |2,100,14,45842.4^10.3.30.8^SEP006CBCA85D8F |[R:L-H:0,N:0,L:0,V:0,Z:0,D:0]
42625628.001 |17:18:39.909 |AppInfo |SIPStationD(15984) - Primary Line Timeout -- shutting down.
42625628.002 |17:18:39.909 |AppInfo |EndPointUnregistered - An endpoint has unregistered Device name:SEP006CBCA85D8F Device IP address:10.3.30.8 Protocol:SIP Device type:622 Device description:SEP006CBCA85D8F Reason Code:13 IPAddressAttributes:0 LastSignalReceived:SIPStationDPrimaryLineTimeout App ID:Cisco CallManager Cluster ID:CCM-Trust Node ID:TrustCCMSub
Thanks in Advance.......
5 Replies 5
Aseem Anand
You can check the QOS settings to make sure the signaling traffic is marked with correct COS & DSCP value and is given adequate bandwidth. If its only specific to 7841 and other models are working fine then can you check the bug below:
Another thing
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut28504/?referring_site=bugquickviewredir
Aseem
Hi Assem,
Thanks for your reply Aseem. Active firmware of Phone is 10-3-1-12. Since 10.3 (1) is mentioned as known affected version let me try with firmware upgrade and update you.
Sure, do share the test results.
Aseem
Hi Aseem,
Firmware upgrade didn't help. I tested with upgrading to the latest version.
We are facing the same issue.
Have you fined a fix for that?
Thanks ,
