03-11-2015 12:03 AM - edited 03-17-2019 02:17 AM
I have CUCM (9.1.2) and Sip phone 9971.
When user hangup phone, and try to dial phone number to PSTN, he waiting about 15 seconds before sip phone make a call. I would to make this time about 1 or 2 seconds. If he call to Polycom server, he does not waiting any time.
I changed any timer - no effects.
I apply "Sip dial rules" nothing changed.
Can anybody tell me how i can fix it?
03-11-2015 12:43 AM
Is only one user impacted. Normally delays in the dialing are due to below:
1) Overlap in dial plan or
2) Interdigit timeout T302 (default is 15 sec) that comes into play specially if you are hitting a variable route pattern
So either you can check your dial plan and have specific route patterns or you can change the inter digit time out to something less 5 secs maybe according to your issue. (3 secs is the minimum value you can configure)
To change inter digit timeout T302 go to - Service Parameters, Call Manager service and search T302. Change it to the required value (its in msecs)
-Terry
Please rate all helpful posts
03-16-2015 08:16 AM
I have an error in route pattern.
There was 1xxx - to device.
Also internal number - 1xx, that's why there was long time waiting.
PS Sorry for my english. :)
