238
Explorer
SIP phone COR configuration - Unable to make PSTN calls
Hey guys,
I have configured a new 3rd party SIP phone. Internal calls are working but calls to PSTN are failing. I think it is a corlist issue. Config below. What am I missing?
Thanks in advance.
voice register dn 1
number 44
voice register pool 1
id mac 6416.7F05.A369
number 1 dn 1
cor incoming user-international default
dtmf-relay rtp-nte
username polycom password 456
codec g711ulaw
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 7911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
prefix 7
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 7[2-9]..[2-9]......
no digit-strip
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 7[2-9]11
no digit-strip
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 71[2-9]..[2-9]......
no digit-strip
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 7011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 71800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 71855.......
forward-digits all
no sip-register
4 REPLIES 4
Highlighted
VIP Advisor
Re: SIP phone COR configuration - Unable to make PSTN calls
run debug voice ccapi and see why its failing. Also, check show dialplan number command and see what dialpeer is matched.
Explorer
@Mohammed al Baqari,
Thanks for your reply. show dialplan number output is below. The user gets a waive-off tone after the fourth digit ("0"). That is when it matches this pattern and my guess is that this phone does not have the correct privileges to all North American long distance. I'll have to have the user dial the number again with the ccsip debug running tomorrow though as I don't have physical access to it.
UC560#show dialplan number 71508221****
Macro Exp.: 71508221****
VoiceEncapPeer62
peer type = voice, system default peer = FALSE, information type = voice,
description = `**CCA*North American-10-Digit*Long Distance**',
tag = 62, destination-pattern = `71[2-9]..[2-9]......',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=5,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 62, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:call-national
Translation profile (Incoming):
Translation profile (Outgoing):OUTGOING_TRANSLATION_PROFILE
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
trunk-group:
id = `ALL_FXO', preference = `'
type = pots, prefix = `',
forward-digits all
session-target = `', voice-port = `',
direct-inward-dial = disabled,
digit_strip = disabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 338390658, Charged Units = 0,
Successful Calls = 9262, Failed Calls = 4394, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = -508825104.
Last Disconnect Time = -508819012.
Matched: 71508221**** Digits: 4
Target:
Everyone's tags (1)
Explorer
debug voice ccapi output below. I'm seeing this:
1280928: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 719179####
1280900: Aug 27 10:25:57.321: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.20.58.73]:5060, local_address:[ - ]
1280901: Aug 27 10:25:57.321: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1280902: Aug 27 10:25:57.321: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1280903: Aug 27 10:25:57.321: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:719179####@172.20.58.1:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.20.58.73;branch=z9hG4bKd74aaab601E04
From: "Conference Room" <sip:44@172.20.58.1>;tag=AC368C91-AE55A99A
To: <sip:719179####@172.20.58.1;user=phone>
CSeq: 1 INVITE
Call-ID: 23dcf3e5-bd2f0e8e-c710523f@172.20.58.73
Contact: <sip:44@172.20.58.73>
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER
User-Agent: PolycomSoundStationIP-SSIP_6000-UA/4.0.8.1972
Accept-Language: en
Supported: 100rel,replaces
Allow-Events: conference,talk,hold
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 461
v=0
o=- 1418472045 1418472045 IN IP4 172.20.58.73
s=Polycom IP Phone
c=IN IP4 172.20.58.73
t=0 0
a=sendrecv
m=audio 2232 RTP/AVP 115 99 9 102 0 8 18 127
a=rtpmap:115 G7221/32000
a=fmtp:115 bitrate=48000
a=rtpmap:99 SIREN14/16000
a=fmtp:99 bitrate=48000
a=rtpmap:9 G722/8000
a=rtpmap:102 G7221/16000
a=fmtp:102 bitrate=32000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:127 telephone-event/8000
1280904: Aug 27 10:25:57.321: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1280905: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x89431B68) with key=[31992] to table
1280906: Aug 27 10:25:57.325: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1280907: Aug 27 10:25:57.325: //-1/000000000000/SIP/Info/ccsip_iwf_init:
1280908: Aug 27 10:25:57.325: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
1280909: Aug 27 10:25:57.325: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
1280910: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1280911: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1280912: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
1280913: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.20.58.1
1280914: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/State/sipSPIChangeState: 0x89431B68 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
1280915: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1280916: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
1280917: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1280918: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1280919: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
1280920: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.20.58.1
1280921: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1280922: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
1280923: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
1280924: Aug 27 10:25:57.325: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
1280925: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
1280926: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x89431B68 key=23dcf3e5-bd2f0e8e-c710523f@172.20.58.73719179####
1280927: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
1280929: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 44
1280930: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name Conference Room, number 44, Calling oct3 0x00, oct_3a 0x80, Called number 719179####
1280931: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:172.20.58.73:5060, Host:172.20.58.73
1280932: Aug 27 10:25:57.325: //-1/F29BAA5CA592/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 44
1280933: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
1280934: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
1280935: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
1280936: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Peer tag 40001 matched for incoming call
1280937: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1280938: Aug 27 10:25:57.329: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1280939: Aug 27 10:25:57.329: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
1280940: Aug 27 10:25:57.329: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.20.58.1
1280941: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
1280942: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
1280943: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPISetMediaFlowMode: Forcing the flow mode to FLOW-THROUGH for SIP line
1280944: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
1280945: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
1280946: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
1280947: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
1280948: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
1280949: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
1280950: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIGetCallConfig: Media forking disabled
1280951: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Line
1280952: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1280953: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
1280954: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
1280955: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIContinueNewMsgInvite: Calling name Conference Room, number 44, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 719179####, oct3 0x00
1280956: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
1280957: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIContinueNewMsgInvite: Requires reliable-provisional support
1280958: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIValidateRequestUri: Not Enabled
1280959: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/UpdateSIPDirectVoiceMailNumber: Direct call from SIP line: called number 719179####
1280960: Aug 27 10:25:57.329: //-1/F29BAA5CA592/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
1280961: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled: - 0
1280962: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
1280963: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:8C78C470
1280964: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
1280965: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
1280966: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
1280967: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
1280968: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
1280969: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
1280970: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
1280971: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
1280972: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 2232
SIP: (161070) Attribute mid, level 1 instance 1 not found.
1280973: Aug 27 10:25:57.329: //161070/F29BAA5CA592/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
1280974: Aug 27 10:25:57.329: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1280975: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
1280976: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 172.20.58.1
1280977: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.20.58.1
1280978: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(115) reserved for codec No Codec
1280979: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1280980: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(115) could not be reserved
as its in use by other codec No Codec
1280981: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (115) is reserved by another application
1280982: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
1280983: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 115
1280984: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec: mpeg4
1280985: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(99) reserved for codec No Codec
1280986: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1280987: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(102) reserved for codec No Codec
1280988: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1280989: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(102) reserved for codec No Codec
1280990: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 99
1280991: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(127) reserved for codec No Codec
1280992: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
1280993: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(127) reserved for codec No Codec
1280994: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 99
1280995: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/rtpAvpCodec_to_voipCodec: Dynamic Payload :115 in SDP Body
1280996: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/rtpAvpCodec_to_voipCodec: Dynamic Payload :99 in SDP Body
1280997: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/rtpAvpCodec_to_voipCodec: Dynamic Payload :102 in SDP Body
1280998: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
1280999: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoPtimeNegotiation: No ptime present or multiple ptime attributes that can't be handled
1281000: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
1281001: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
1281002: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(127) reserved for codec
1281003: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(127) reserved for codec
1281004: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
1281005: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 127 for RTP-NTE
1281006: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
1281007: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
1281008: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
1281009: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
1281010: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
1281011: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=172.20.58.73, dest_port=2232
1281012: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
1281013: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 127
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
1281014: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
1281015: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
1281016: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.20.58.1
1281017: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
1281018: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_offer_ans_process_event:
1281019: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_RCVD
1281020: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_offer_ans_is_invite_offer_valid: - 1
1281021: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_offer_ans_common_offer_rcvd_hdlr:
1281022: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_iwf_handle_network_event:
1281023: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/ccsip_iwf_process_event:
1281024: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_RCVD_SDP
1281025: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_def_ed_rcvd_sdp_hdlr:
1281026: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
CallID 161070, sdp 0x89B657F4 channels 0x894331BC
1281027: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/copy_channels:
callId 161070 size 0 ptr 0x8C4F17F8)
1281028: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: stream_callid = 161070, peer_stream_callid = -1
1281029: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 115 mline 1
1281030: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_dynamic_codec_params:
1281031: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 99 mline 1
1281032: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_dynamic_codec_params:
1281033: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 9 mline 1
1281034: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPISelectCodecVersion: g722-64 flavor of G722 codec will be used
1281035: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec g722-64
1281036: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found:
Codec to be matched: 37
1281037: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found: No match for the codecs found..
1281038: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 102 mline 1
1281039: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_dynamic_codec_params:
1281040: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
1281041: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
1281042: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found:
Codec to be matched: 5
1281043: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
1281044: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
1281045: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_codec_params_in_channelInfo:
1281046: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
1281047: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_codec_params_in_channelInfo:
Adding negotiated codec 5 ptype 0 time 20, bytes 160 as channel 0 mline 1 ss 1 172.20.58.73:2232
1281048: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
1281049: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=0,stream->negotiated_codec_bytes=160,stream->mline_index=1, media_ndx=1
1281050: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 8 mline 1
1281051: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec g711alaw
1281052: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found:
Codec to be matched: 6
1281053: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found: No match for the codecs found..
1281054: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 18 mline 1
1281055: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
1281056: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec: Unexpected VoIPCodec Type :
1281057: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_static_codec_params: An exact codec match not configured, using interoperable codec
1281058: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec
1281059: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found:
Codec to be matched: -2123687480
1281060: Aug 27 10:25:57.333: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec: Unexpected VoIPCodec Type :
1281061: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/codec_found: No match for the codecs found..
1281062: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
Hndl ptype 127 mline 1
1281063: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_update_dynamic_codec_params:
1281064: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_upd_2833_dtmf_params:
1281065: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_upd_2833_dtmf_params: setting ipip_caps DTMF to RFC2833: callid = 161070, dtmf = 6
1281066: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Error/sipSPI_ipip_upd_2833_dtmf_params: Unable to find proper instance for FMTP
SIP: (161070) fmtp attribute, level 1 instance 0 not found.
1281067: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Error/sipSPI_ipip_upd_2833_dtmf_params: Unable to acquire event mask for rfc2833
1281068: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Error/sipSPI_ipip_update_call_entry:
1281069: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[0].codec = 5
1281070: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[1].codec = -1
1281071: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: srcChannelID = -1, dstChannelID = 161070
1281072: Aug 27 10:25:57.333: //161070/F29BAA5CA592/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 161070
Peer Callid : -1
RTP/SRTP Negotiated : 8
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 127 (tx), 127 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [172.20.58.1]:0
Media Dest Addr/Port : [172.20.58.73]:2232
1281073: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_calculate_channel_count: Number of streams to report = 1
1281074: Aug 27 10:25:57.337: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata:
CALL_ERROR; Avlist Set Is Failed
1281075: Aug 27 10:25:57.337: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count: Unable to set CHANNEL_COUNT for callid 161070
1281076: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo: Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
1281077: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT
1281078: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_RCVD
1281079: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Media/sipSPIUpdCallWithSdpInfo:
Media line : 1
Callid : 161070
1281080: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIHandleInviteMedia:
Preferred DTMF relay 1 : 6
Preferred DTMF relay 2 : 0
Negotiated DTMF relay : 6
Preferred and Negotiated NTE payloads: 127 127
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
1281081: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
1281082: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
1281083: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
1281084: Aug 27 10:25:57.337: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17732 for stream 1
1281085: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17732
1281086: Aug 27 10:25:57.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
1281087: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17732
1281088: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
1281089: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 127
1281090: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
1281091: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 23dcf3e5-bd2f0e8e-c710523f@172.20.58.73
1281092: Aug 27 10:25:57.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
1281093: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
1281094: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
1281095: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
1281096: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
1281097: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
1281098: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
1281099: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
1281100: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 24
1281101: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
1281102: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
1281103: Aug 27 10:25:57.337: //161070/F29BAA5CA592/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
1281211: Aug 27 10:25:57.373: //161070/F29BAA5CA592/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 89431B68
1281212: Aug 27 10:25:57.373: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[31992]
1281213: Aug 27 10:26:00.137: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x89B589B0 Connection=0x8824158C, addr=172.20.58.73, port=5060, connid=3 has been REFRESHED
1281214: Aug 27 10:26:00.137: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x89B589B0,addr=172.20.58.73
1281215: Aug 27 10:26:01.033: %SEC-
Explorer
show dialplan number is matching on a dialpeer but the ccapi output shows this diapleer is not matching for some reason.
UC560#sh dialplan number 71917940####
Macro Exp.: 71917940####
VoiceEncapPeer62
allow watch = FALSE
URI classes:
Destination =
dnis-map =
permission :both
trunk-group:
forward-digits all
bandwidth:
Connect Time = 339957483, Charged Units = 0,
Successful Calls = 9295, Failed Calls = 4408, Incomplete Calls = 0
Last Setup Time = -482807560.
Last Disconnect Time = -482794158.
Matched: 71917940#### Digits: 4
Target:
Content for Community-Ad
August's Community Spotlight Awards
