09-29-2011 10:06 PM - edited 03-16-2019 07:15 AM
one of my user had a Nokia E71 and a SIP client registering in UCM 6.1 and a 7960G. As he changed his Nokia for a Iphone with SIP client, we did delete the Nokia and generate a new phone for the Iphone but even if I see only in the phone list the 7960 and the Iphone, the E71 is still registering, geting calls under the internal number and working well.
Some idea how is it possible to remove it completely?
Daniel
09-30-2011 12:44 AM
What version of call manager are you running? That sounds like a change notification problem, meaning that the device was deleted from the database if it doesn't show up in the web page but the running CCM service didn't get the update to prevent the device from registering. Restarting the CCM service will likely fix it. If you're on CUCM 6.1.2 there is a known bug you can verify from the node the phone is registering with using the command line command "show tech notify".
10-27-2011 11:39 PM
since september, I did restart the service, no changes. Last week, power outage so sure all was restarted and the Nikia is still registring and answering/generating calls under its number.
I have realy no idea how I can put them out of the UCM....
Maybe an other idea from U?
Cheers,
Daniel
