SIP Phone HW Conferencing on CME
CSCO11510457
HI
sip phones 7841 on CME (15.7(3)M3) cannot complete a HW conference in the internal network of company.
for example:
1. Phone A calls to Phone B
2. Phone B answer the call, and press the conference softkey, and call Phone C
3. after Phone C answer the call from Phone B, Phone B press the conference softkey again.
it shows that Phone A cannot merge to the conference.
I have referenced a lot of posts in the forum, but still cannot resolve the probllem.
output of "debug ephone hw-conference"
Apr 2 08:08:59.342: Check associated hwconf with callid 45082
Apr 2 08:08:59.342: Unable to associate a dn/chan with callid 45082
Apr 2 08:09:07.338: Check associated hwconf with callid 45082
Apr 2 08:09:07.338: Unable to associate a dn/chan with callid 45082
Apr 2 08:09:11.450: Check associated hwconf with callid 45082
Apr 2 08:09:11.450: Unable to associate a dn/chan with callid 45082
Apr 2 08:09:13.550: Check associated hwconf with callid 45084
Apr 2 08:09:13.550: Unable to associate a dn/chan with callid 45084
Apr 2 08:09:13.734: Check associated hwconf with callid 45085
Apr 2 08:09:13.734: Unable to associate a dn/chan with callid 45085
Apr 2 08:09:16.574: Check associated hwconf with callid 45082
Apr 2 08:09:16.574: Unable to associate a dn/chan with callid 45082
Apr 2 08:09:16.734: Check associated hwconf with callid 45082
Apr 2 08:09:16.734: Unable to associate a dn/chan with callid 45082
Apr 2 08:09:21.366: Check associated hwconf with callid 45093
Apr 2 08:09:21.366: Unable to associate a dn/chan with callid 45093
Apr 2 08:09:23.426: Check associated hwconf with callid -1
Apr 2 08:09:23.426: Unable to associate a dn/chan with callid -1
Apr 2 08:09:23.426: Check associated hwconf with callid 45094
Apr 2 08:09:23.426: Unable to associate a dn/chan with callid 45094
Apr 2 08:09:23.426: skinny_hwcfb_check_resource: for Audio
Apr 2 08:09:23.426: skinny_hwcfbi_find_next_mtpcb Got MTPCB conference type req 52:Audio only as Audio only Pass
Apr 2 08:09:23.426: skinny_hwcfb_get_adhoc_number:
Apr 2 08:09:23.426: skinny_hwcfb_get_adhoc_number : Failed to get ad-hoc conference resource
Apr 2 08:09:28.790: Check associated hwconf with callid -1
Apr 2 08:09:28.790: Unable to associate a dn/chan with callid -1
Apr 2 08:09:28.822: Check associated hwconf with callid 45082
Apr 2 08:09:28.822: Unable to associate a dn/chan with callid 45082
Best Regards,
2 Accepted Solutions
HARIS_HUSSAIN
Try Removing G729 Codec from Conference bridge
HARIS_HUSSAIN
Seems like a Bug Can you try with a Different IOS Version. Just upgrade to latest Stable IOS Version available.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
10 Replies 10
HARIS_HUSSAIN
Hi HARIS_HUSSAIN, thanks for you reply. I remove G729 codec under the conference bridge, but the problem is still exists. dspfarm profile 2 conference codec g711ulaw codec g711alaw maximum sessions 2 associate application SCCP
That error always makes me think there is missing config, but you have everything in place just fine. Although I must be missing something subtle, because the output of your "show telephony-service conference hardware" is blank and it should not be. You should see the A001 and A002 listed underneath. This means that the telephony-service is unable to allocate conference hardware because it doesn't think it has any available.
Try bouncing the telephony-service and then sccp:
config t
no sccp
telephony-service
 shutdown
 no shutdown
 exit
sccp
end
If the output of "show telephony-service conference hardware" is still blank, then debug sccp messages (and maybe debug sccp events) and bounce sccp again to see it attempting to register the conference bridge.
Let us know how this goes.
Maren
Hi Maren, thanks for your reply. I try to bounce the telephony-service and sccp, but cannot resolve the problem. Pls reference the attachment.
Alright then. The debugs show the xcoder and the cfb fully registered.
So then, there must be an allocation issue. Please run the following pair of debugs and try to create a conference call, and post the results.
debug ephone mtp
Hi Maren, I collect the output of "debug ephone hw-conference" and "debug ephone mtp". it looks like the same with debug ephone hw-conference.
HARIS_HUSSAIN
Haris
HI Haris, you are right, i downgrade to 15.6(3)M , then everything is ok. thanks for your help!!
Great !! glad It worked. You can mark the thread as Solved by accepting the solution provided.
What was your Origianl IOS Version?
Haris
Hi Haris, 15.7(3)M3 I think it might shoot this BUG https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn07969
