I wanted to update name and label of the Cisco 7821 as per commands below.
voice register dn 9
number 7065
allow watch
name AdamS
label label AdamS-7065
I have restarted the voice register 9.
CCME-01(config)#voice register pool 9
CCME-01(config-register-pool)#restart
voice register global has the below profile sync
mode cme
create profile sync 3683027624335412
Is there any extra action required for changes to apply?
Thank you.
Daniel
Solved! Go to Solution.
You need to issue below command before restart.
create profile
and then
Restart
create profile
and then
Restart
