05-14-2019 02:21 AM
Hi All,
I have a problem with one SIP Cisco 8961 Phone. All others phones are working fine. Phone cannot register itself.
From sip debug point of view all is looking fine.
024590: May 14 08:32:52.123 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: REGISTER sip:10.136.18.1 SIP/2.0 Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK62ed888b From: <sip:883@10.136.18.1>;tag=885a9202a40c0003242dc30c-074f75b9 To: <sip:883@10.136.18.1> Call-ID: 885a9202-a40c0002-07b4af88-761791bc@10.136.18.232 Max-Forwards: 70 Date: Fri, 01 Jan 1982 00:00:46 GMT CSeq: 101 REGISTER User-Agent: Cisco-CP8961/9.4.1 Contact: <sip:C758D6C-189F@10.136.18.232:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-885a9202a40c>";+u.sip!devicename.ccm.cisco.com="SEP885A9202A40C";+u.sip!model.ccm.cisco.com="540" Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.0.1 Content-Length: 0 Reason: SIP;cause=200;text="cisco-alarm:25 Name=SEP885A9202A40C ActiveLoad=sip8961.9-4-1-9.loads InactiveLoad=sip8961.9-3-2-10.loads Last=initialized" Expires: 3600 024591: May 14 08:32:52.127 BST: //2199475/50E106EBBA80/SIP/Msg/ccsipDisplayMsg: Sent: SIP/2.0 401 Unauthorized Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK62ed888b From: <sip:883@10.136.18.1>;tag=885a9202a40c0003242dc30c-074f75b9 To: <sip:883@10.136.18.1>;tag=113F60EC-1025 Date: Tue, 14 May 2019 07:32:52 GMT Call-ID: 885a9202-a40c0002-07b4af88-761791bc@10.136.18.232 Server: Cisco-SIPGateway/IOS-15.6.1.T2 CSeq: 101 REGISTER WWW-Authenticate: Digest realm="all",nonce="16EBBD994E86567E",algorithm=MD5,qop="auth" Content-Length: 0 024592: May 14 08:32:52.167 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: REGISTER sip:10.136.18.1 SIP/2.0 Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK15346e82 From: <sip:883@10.136.18.1>;tag=885a9202a40c0003242dc30c-074f75b9 To: <sip:883@10.136.18.1> Call-ID: 885a9202-a40c0002-07b4af88-761791bc@10.136.18.232 Max-Forwards: 70 Date: Fri, 01 Jan 1982 00:00:46 GMT CSeq: 102 REGISTER User-Agent: Cisco-CP8961/9.4.1 Contact: <sip:C758D6C-189F@10.136.18.232:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-885a9202a40c>";+u.sip!devicename.ccm.cisco.com="SEP885A9202A40C";+u.sip!model.ccm.cisco.com="540" Authorization: Digest username="883",realm="all",uri="sip:10.136.18.1",response="80f0b7aaccf21c5e2ef7c17dc0f15206",nonce="16EBBD994E86567E",cnonce="03b60928",qop=auth,nc=00000001,algorithm=MD5 Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.0.1 Content-Length: 0 Reason: SIP;cause=200;text="cisco-alarm:25 Name=SEP885A9202A40C ActiveLoad=sip8961.9-4-1-9.loads InactiveLoad=sip8961.9-3-2-10.loads Last=initialized" Expires: 3600 Sent: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK15346e82 From: <sip:883@10.136.18.1>;tag=885a9202a40c0003242dc30c-074f75b9 To: <sip:883@10.136.18.1>;tag=113F60EC-1025 Date: Tue, 14 May 2019 07:32:52 GMT Call-ID: 885a9202-a40c0002-07b4af88-761791bc@10.136.18.232 Server: Cisco-SIPGateway/IOS-15.6.1.T2 CSeq: 102 REGISTER Supported: X-cisco-cme-sis-1.0.0 Supported: X-cisco-srtp-fallback Contact: <sip:883@10.136.18.232:5060>;expires=3600;x-cisco-newreg Expires: 3600 Content-Length: 0 024594: May 14 08:32:53.039 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 200 OK Via: SIP/2.0/UDP 10.136.18.1:5060;branch=z9hG4bK1C34265CF From: <sip:883@10.136.18.1>;tag=113F611C-2121 To: <sip:883@10.136.18.232> Call-ID: 50E859FB-755111E9-BA82CF9D-31D0504A@10.136.18.1 Date: Tue, 14 May 2019 07:32:52 GMT CSeq: 101 NOTIFY Content-Length: 0
however
#show voice register pool attempted-registrations | b 885a.9202.a40c MAC address: 885a.9202.a40c IP address : 10.136.18.232 Attempts : 6470 Time of first attempt : 14:44:28.231 BST Fri May 10 2019 Time of latest attempt: 09:32:51.876 BST Tue May 14 2019 Reason for failure : Unauthorized registration request
any ideas ?
Marcin
05-15-2019 03:55 AM
Can you share the output of "debug ccsip all" when the phone tries to register?
also the "show voice register pool all brief"
MAC/IP address of the phone.
05-15-2019 06:23 AM
Check if the register pool includes the IP address of the SIP Phone (check subnet mask).
If not there is a case where SIP phones when they belong in different subnet than CME they should use user/pass.
If this is the case use authenticate register command under voice register pool.
Also check
voice service voip
ip address trusted list ....
05-15-2019 06:57 AM
You may try erasing CTL files under phone security settings
05-16-2019 12:28 AM - edited 05-16-2019 12:29 AM
HI,
Thank you for your all.
I restarted the router and all is fine now.
Marcin
