sip phone registration problem
m.szalankiewicz
Hi All,
I have a problem with one SIP Cisco 8961 Phone. All others phones are working fine. Phone cannot register itself.
From sip debug point of view all is looking fine.
024590: May 14 08:32:52.123 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.136.18.1 SIP/2.0
Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK62ed888b
From: <sip:883@10.136.18.1>;tag=885a9202a40c0003242dc30c-074f75b9
To: <sip:883@10.136.18.1>
Call-ID: 885a9202-a40c0002-07b4af88-761791bc@10.136.18.232
Max-Forwards: 70
Date: Fri, 01 Jan 1982 00:00:46 GMT
CSeq: 101 REGISTER
User-Agent: Cisco-CP8961/9.4.1
Contact: <sip:C758D6C-189F@10.136.18.232:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-885a9202a40c>";+u.sip!devicename.ccm.cisco.com="SEP885A9202A40C";+u.sip!model.ccm.cisco.com="540"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.2,X-cisco-xsi-8.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:25 Name=SEP885A9202A40C ActiveLoad=sip8961.9-4-1-9.loads InactiveLoad=sip8961.9-3-2-10.loads Last=initialized"
Expires: 3600
024591: May 14 08:32:52.127 BST: //2199475/50E106EBBA80/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:883@10.136.18.1>;tag=113F60EC-1025
Date: Tue, 14 May 2019 07:32:52 GMT
Server: Cisco-SIPGateway/IOS-15.6.1.T2
CSeq: 101 REGISTER
WWW-Authenticate: Digest realm="all",nonce="16EBBD994E86567E",algorithm=MD5,qop="auth"
Content-Length: 0
024592: May 14 08:32:52.167 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.136.18.232:5060;branch=z9hG4bK15346e82
Max-Forwards: 70
CSeq: 102 REGISTER
Authorization: Digest username="883",realm="all",uri="sip:10.136.18.1",response="80f0b7aaccf21c5e2ef7c17dc0f15206",nonce="16EBBD994E86567E",cnonce="03b60928",qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
Sent:
SIP/2.0 200 OK
CSeq: 102 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:883@10.136.18.232:5060>;expires=3600;x-cisco-newreg
Expires:  3600
Content-Length: 0
024594: May 14 08:32:53.039 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.136.18.1:5060;branch=z9hG4bK1C34265CF
To: <sip:883@10.136.18.232>
Call-ID: 50E859FB-755111E9-BA82CF9D-31D0504A@10.136.18.1
CSeq: 101 NOTIFY
Content-Length: 0
however
#show voice register pool attempted-registrations | b 885a.9202.a40c
 MAC address: 885a.9202.a40c
 IP address : 10.136.18.232
 Attempts   : 6470
 Time of first attempt : 14:44:28.231 BST Fri May 10 2019
 Time of latest attempt: 09:32:51.876 BST Tue May 14 2019
 Reason for failure    :
         Unauthorized registration request
any ideas ?
Marcin
Ishan Zutshi
Can you share the output of "debug ccsip all" when the phone tries to register?
also the "show voice register pool all brief"
MAC/IP address of the phone.
gachilleas
Check if the register pool includes the IP address of the SIP Phone (check subnet mask).
If not there is a case where SIP phones when they belong in different subnet than CME they should use user/pass.
If this is the case use authenticate register command under voice register pool.
Also check
voice service voip
ip address trusted list ....
You may try erasing CTL files under phone security settings
m.szalankiewicz
HI,
Thank you for your all.
I restarted the router  and all is fine now.
Marcin
