1545
Highlighted
Beginner
SIP Phones - re-registration issues
Dear Community,
My CUCME new SIP phones are restarting and re-registering in everything 5 minutes, SCCP phone are working fine. I have done all basic configuration required to register and activate SIP phones (CUBE config, Voice register global config, mapped dns to buttons etc), while doing "debug ccsip errors" i am getting the following messages
BRANCH2-R3#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            172.16.120.2    YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/0/0                unassigned      YES NVRAM  administratively down down
Serial0/0/1                unassigned      YES NVRAM  administratively down down
Serial0/1/0:0              unassigned      YES unset  down                  down
Serial0/1/0:1              unassigned      YES unset  down                  down
Serial0/1/0:2              unassigned      YES unset  down                  down
Serial0/1/0:15             unassigned      YES unset  down                  down
Loopback0                  3.3.3.3         YES NVRAM  up                    up
BRANCH2-R3#sh run | se voice register global
mode cme
source-address 3.3.3.3 port 5060
max-dn 10
max-pool 5
load 7961 SIP41.8-4-2S
authenticate register
tftp-path flash:
create profile sync 0004223125212201
BRANCH2-R3#
Aug 18 23:26:27.912: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:26:27.912: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:26:27.912: //91/DBFCA6598064/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:27:12.189: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:12.189: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:12.189: //92/F660E1AE8065/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization head
Aug 18 23:27:47.706: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:47.706: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:47.706: //93/0B8C3DC18066/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:27:47.730: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:47.730: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:47.734: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:27:47.734: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Aug 18 23:30:16.519: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:30:16.523: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:30:16.523: //94/643FEC9F8067/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:00.971: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:00.975: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:00.975: //95/7EBEDAD48068/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:36.455: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:36.455: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:36.455: //96/93E4A01A8069/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:31:36.487: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Aug 18 23:34:13.578: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:34:13.578: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:34:13.578: //97/F18BA65B806A/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:34:58.118: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:34:58.118: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:34:58.118: //98/0C17E568806B/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:35:33.597: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:35:33.601: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:35:33.601: //99/213E28CD806C/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Thanks in advance
rajesh
3 REPLIES 3
Highlighted
Hall of Fame Master
Do not use SIP for Cisco phones with CME.
Use SCCP and everything will work smooth, plus you will have much more features and a better calling experience.
Highlighted
Thanks for the response, i need to do SIP for my lab requirements
dear community  :Any other comments
Highlighted
hi i have the same problem but some of SIP Phones are registered while others not .
i ran the same debug and i am receiving the same error .
so would you advice if you got any chance to solve it .
