Sip Profiles
Jonathan Forbes
I have a cisco 2911 voice router set up for sip trunk to provider.
I am running this behind a nat device and trying to get sip profile to rewrite the private ip to the public ip.
I have set this up with applying the sip profile to my dial peer. The provider still says i am send the private ip address to them in the sdp header and the sip header
any help would be great.
voice class sip-profiles 100
request ANY sip-header Replaces modify "192.168.90.2" "216.5.81.21"
response ANY sip-header Replaces modify "192.168.90.2" "216.5.81.21"
request INVITE sip-header Remote-Party-ID modify "192.168.90.2" "216.5.81.21"
request INVITE sip-header Contact modify "192.168.90.2" "216.5.81.21"
request ANY sip-header Contact modify "192.168.90.2" "216.5.81.21"
request ANY sip-header Remote-Party-ID modify "192.168.90.2" "216.5.81.21"
response ANY sip-header Remote-Party-ID modify "192.168.90.2" "216.5.81.21"
response ANY sip-header Contact modify "192.168.90.2" "216.5.81.21"
request ANY sdp-header Connection-Info modify "192.168.90.2" "216.5.81.21"
request ANY sdp-header Session-Owner modify "192.168.90.2" "216.5.81.21"
response ANY sdp-header Connection-Info modify "192.168.90.2" "216.5.81.21"
response ANY sdp-header Session-Owner modify "192.168.90.2" "216.5.81.21"
response ANY sdp-header Audio-Connection-Info modify "192.168.90.2" "216.5.81.21"
response ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
request ANY sdp-header Audio-Attribute modify "sendonly" "sendrecv"
request ANY sdp-header Audio-Media modify "192.168.90.2" "216.5.81.21"
request ANY sdp-header Audio-Connection-Info modify "192.168.90.2" "216.5.81.21"
R0g22
First thing, this needs to be done by an ALG. Second, you should use the SIP Profile Test tool to test your profiles against the SIP message -
https://cway.cisco.com/tools/SipProfileTest/
Do you mean sip alg from my firewall or from my router?
Whatever the NAT device is, presumably a firewall. It needs to support SIP protocol inspection and rewriting (aka ALG). I do not believe a SIP Profile will be sufficient to get this done on the CUBE router itself, though you could perform NAT natively on that router instead of an external box.
