Explorer
SIP registration failing - SIP/2.0 404 Not Found
Hi All,
I'm trying to register a Polycom SoundStation IP 6000 with a CME and I'm getting the following in the SIP debug:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.20.58.73;branch=z9hG4bK4660f4bcDCE42CB5
From: "SoundStation IP" <sip:SSIP@172.20.58.1>;tag=F9F16E81-B1C86AE2
To: <sip:SSIP@172.20.58.1>
Date: Thu, 23 Aug 2018 02:28:17 GMT
Call-ID: fc75dbb6-18483ff-a4c589d0@172.20.58.73
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 REGISTER
Content-Length: 0
1132028: Aug 22 22:28:17.888: //158545/0786CEFC9583/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:SSIP@172.20.58.1>;tag=C7A706DC-E03
CSeq: 1 REGISTER
Content-Length: 0
Config is below:
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
registrar server
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 172.20.58.1 port 5060
max-dn 5
max-pool 5
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 12
create profile sync 8071007903605222
voice register dn 1
number 44
voice register pool 1
id mac 6416.7F05.A369
number 1 dn 1
dtmf-relay rtp-nte
codec g711ulaw
sccp local Vlan90
sccp ccm 172.20.58.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
sip-ua
telephony-service
video
authentication credential cisco cisco
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 172.20.58.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message PSDAB
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
cnf-file perphone
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 12
keepalive 30 auxiliary 4
voicemail 99
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$jm40$FR5/m6sRZ.7kLSJ53nxAp.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 7.T
transfer-pattern 8.. blind
secondary-dialtone 7
night-service code *59
night-service day Sun 00:00 23:59
night-service day Mon 17:00 08:00
night-service day Tue 17:00 08:00
night-service day Wed 17:00 08:00
night-service day Thu 17:00 08:00
night-service day Fri 17:00 08:00
night-service day Sat 00:00 23:59
night-service date Jul 3 00:00 23:59
fac standard
1 ACCEPTED SOLUTION
Re: SIP registration failing - SIP/2.0 404 Not Found
Interesting, why is there a period in the URI after the IP ?
REGISTER sip:172.20.58.1.:5060
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
9 REPLIES 9
Beginner
You have to define a username and password under the device register pool same as if you register a 3rd party SIP phone in CM.
Check this: https://community.cisco.com/t5/ip-telephony-and-phones/how-to-register-3rd-party-sip-to-cme/td-p/737940
Explorer
@Flo.Matalis,
Thanks for you response. I added a username in the CME and on the Polycom but am now getting the following error:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.20.58.73;branch=z9hG4bK6f49637DFD6F3C8
From: "Conference Room" <sip:44@172.20.58.1.>;tag=B996B3B4-8B90996D
To: <sip:44@172.20.58.1.>
Date: Thu, 23 Aug 2018 14:56:11 GMT
Call-ID: 2bc1f321-a6badc82-6ebb8a2b@172.20.58.73
CSeq: 1 REGISTER
Content-Length: 0
1156360: Aug 23 10:56:11.736: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Malformed/Missing URL'
CSeq: 1 REGISTER
Content-Length: 0
Any ideas?
-mike
Beginner
Can you post your voice pool config for this phone? Also, the extension number of your Polycom is only 44? On your Polycom web GUI, can you also put the extension number same as what you configured on the voice pool config?
Explorer
@Flo.Matalis,
Config below. Let me know if I omitted anything pertinent. Yes, they use 2-digit extensions and this phone will have extension 44.
ip dhcp pool phone
network 172.20.58.0 255.255.255.0
default-router 172.20.58.1
option 150 ip 172.20.58.1
option 66 ip 172.20.58.1
option 151 ip 172.20.58.1
option 160 ip 172.20.58.1
voice service voip
sip
registrar server
no update-callerid
mode cme
max-dn 5
max-pool 5
timezone 12
voice register dn 1
number 44
number 1 dn 1
dtmf-relay rtp-nte
username polycom password 456
codec g711ulaw
interface Vlan100
description $FW_INSIDE$
ip address 172.20.58.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip virtual-reassembly in
ip local pool SDM_POOL_1 172.20.50.10 172.20.50.30
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
sccp local Vlan90
sccp
sccp ccm group 1
sip-ua
telephony-service
video
fxo hook-flash
max-ephones 138
max-dn 600
service dss
cnf-file perphone
time-zone 12
voicemail 99
dn-webedit
time-webedit
transfer-pattern .T
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
Highlighted
Explorer
Screen Shot 2018-08-23 at 12.35.32 PM.png Here's the Polycom config
Show the complete messages including the SIP REGISTER. Also remove the MAC from the pool, that is not required. CME won't do a mac based auth for these phones. Put in a dummy i.e. 0000.0000.0000. Ensure you are configuring the Polycom correctly.
Nipun Singh Raghav
Explorer
@Nipun Singh Raghav
Here are the complete ccsip debug all messages:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.08.23 12:38:16 =~=~=~=~=~=~=~=~=~=~=~=
UC560#
UC560#
1168712: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.20.58.73]:5060, local_address:[ - ]
1168713: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1168714: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1168715: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.20.58.1.:5060 SIP/2.0
Via: SIP/2.0/UDP 172.20.58.73;branch=z9hG4bKf6ca8423DCA6B814
From: "Conference Room" <sip:44@172.20.58.1.>;tag=69EC3B99-8ECBFEBA
CSeq: 1 REGISTER
Call-ID: 45ee38cd-c951668e-bcabf397@172.20.58.73
Contact: <sip:44@172.20.58.73>;methods="INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, MESSAGE, SUBSCRIBE, NOTIFY, PRACK, UPDATE, REFER"
User-Agent: PolycomSoundStationIP-SSIP_6000-UA/4.0.8.1972
Accept-Language: en
Max-Forwards: 70
Expires: 3600
Content-Length: 0
1168716: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1168717: Aug 23 12:38:24.611: Parse Error: url_parseSipUrl: Received Bad Host
1168718: Aug 23 12:38:24.611: Parse Error: url_parseSipUrl: Received Bad Host
1168719: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x89431B68) with key=[31157] to table
1168720: Aug 23 12:38:24.611: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1168721: Aug 23 12:38:24.611: //-1/000000000000/SIP/Info/ccsip_iwf_init:
1168722: Aug 23 12:38:24.611: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
1168723: Aug 23 12:38:24.611: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
1168724: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168725: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1168726: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
1168727: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.20.58.1
1168728: Aug 23 12:38:24.611: //-1/C9E85A709BDD/SIP/State/sipSPIChangeState: 0x89431B68 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
1168729: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168730: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
1168731: Aug 23 12:38:24.611: Parse Error: url_parseSipUrl: Received Bad Host
1168732: Aug 23 12:38:24.611: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168733: Aug 23 12:38:24.611: Parse Error: url_parseSipUrl: Received Bad Host
1168734: Aug 23 12:38:24.611: Parse Error: url_parseSipUrl: Received Bad Host
1168735: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
1168736: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPITransportSendMessage: msg=0x8C7F8048, addr=172.20.58.73, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
1168737: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1168738: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1168739: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x8C7F8048 to default port=5060
1168740: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.20.58.73, rport:5060 with laddr:
1168741: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x8C7F8048
1168742: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8C7F8048, addr=172.20.58.73, port=5060, local_addr=, connId=2 for UDP
1168743: Aug 23 12:38:24.615: Parse Error: url_parseSipUrl: Received Bad Host
1168744: Aug 23 12:38:24.615: Parse Error: url_parseSipUrl: Received Bad Host
1168745: Aug 23 12:38:24.615: Parse Error: url_parseSipUrl: Received Bad Host
1168746: Aug 23 12:38:24.615: Parse Error: url_parseSipUrl: Received Bad Host
1168747: Aug 23 12:38:24.615: Parse Error: url_parseSipUrl: Received Bad Host
1168748: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
1168749: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPITransportSendMessage: msg=0x86B0DBF0, addr=172.20.58.73, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x814ACF94
1168750: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1168751: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1168752: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x86B0DBF0 to default port=5060
1168753: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.20.58.73, rport:5060 with laddr:
1168754: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x86B0DBF0
1168755: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x86B0DBF0, addr=172.20.58.73, port=5060, local_addr=, connId=2 for UDP
1168756: Aug 23 12:38:24.615: //-1/C9E85A709BDD/SIP/State/sipSPIChangeState: 0x89431B68 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
1168757: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 23 Aug 2018 16:38:24 GMT
CSeq: 1 REGISTER
Content-Length: 0
1168758: Aug 23 12:38:24.615: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 REGISTER
Content-Length: 0
UC560#
UC560#
UC560#
UC560#
UC560#
UC560#
1168759: Aug 23 12:38:32.368: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168760: Aug 23 12:38:32.368: Use file-acct reset when the problem is recovered
1168761: Aug 23 12:38:32.380: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168762: Aug 23 12:38:32.380: Use file-acct reset when the problem is recovered
UC560#
UC560#
UC560#
UC560#
1168763: Aug 23 12:38:39.876: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168764: Aug 23 12:38:39.876: Use file-acct reset when the problem is recovered
1168765: Aug 23 12:38:39.892: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168766: Aug 23 12:38:39.892: Use file-acct reset when the problem is recovered
UC560#
UC560#
UC560#
UC560#
UC560#
UC560#
UC560#
1168767: Aug 23 12:38:56.616: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[31157] removed.
1168768: Aug 23 12:38:56.616: //-1/C9E85A709BDD/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
1168769: Aug 23 12:38:56.616: //-1/C9E85A709BDD/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
1168770: Aug 23 12:38:56.616: //-1/C9E85A709BDD/SIP/Info/ccsip_offer_ans_delete:
1168771: Aug 23 12:38:56.616: //-1/C9E85A709BDD/SIP/Info/ccsip_iwf_delete:
1168772: Aug 23 12:38:56.616: //-1/C9E85A709BDD/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 89431B68
1168773: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.20.58.73]:5060, local_address:[ - ]
1168774: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
1168775: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
1168776: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: "Conference Room" <sip:44@172.20.58.1.>;tag=F9F16E81-B1C86AE2
CSeq: 1 REGISTER
Accept-Language: en
Max-Forwards: 70
Expires: 3600
Content-Length: 0
1168777: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
1168778: Aug 23 12:38:58.000: Parse Error: url_parseSipUrl: Received Bad Host
1168779: Aug 23 12:38:58.000: Parse Error: url_parseSipUrl: Received Bad Host
1168780: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x89431B68) with key=[31158] to table
1168781: Aug 23 12:38:58.000: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
1168782: Aug 23 12:38:58.000: //-1/000000000000/SIP/Info/ccsip_iwf_init:
1168783: Aug 23 12:38:58.000: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
1168784: Aug 23 12:38:58.000: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
1168785: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168786: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
1168787: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
1168788: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.20.58.1
1168789: Aug 23 12:38:58.000: //-1/DDCF14D79BE8/SIP/State/sipSPIChangeState: 0x89431B68 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
1168790: Aug 23 12:38:58.000: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168791: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
1168792: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168793: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.20.58.73,Port 5060, Transport 1, SentBy Port 5060
1168794: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168795: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168796: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
1168797: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPITransportSendMessage: msg=0x86BB7D60, addr=172.20.58.73, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
1168798: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1168799: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1168800: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x86BB7D60 to default port=5060
1168801: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.20.58.73, rport:5060 with laddr:
1168802: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x86BB7D60
1168803: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x86BB7D60, addr=172.20.58.73, port=5060, local_addr=, connId=2 for UDP
1168804: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168805: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168806: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168807: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168808: Aug 23 12:38:58.004: Parse Error: url_parseSipUrl: Received Bad Host
1168809: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
1168810: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPITransportSendMessage: msg=0x8C7F8048, addr=172.20.58.73, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x814ACF94
1168811: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
1168812: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
1168813: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x8C7F8048 to default port=5060
1168814: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.20.58.73, rport:5060 with laddr:
1168815: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x8C7F8048
1168816: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8C7F8048, addr=172.20.58.73, port=5060, local_addr=, connId=2 for UDP
1168817: Aug 23 12:38:58.004: //-1/DDCF14D79BE8/SIP/State/sipSPIChangeState: 0x89431B68 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
1168818: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 23 Aug 2018 16:38:58 GMT
CSeq: 1 REGISTER
Content-Length: 0
1168819: Aug 23 12:38:58.004: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 REGISTER
Content-Length: 0
UC560#
UC560#
1168820: Aug 23 12:39:08.060: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168821: Aug 23 12:39:08.060: Use file-acct reset when the problem is recovered
1168822: Aug 23 12:39:08.060: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168823: Aug 23 12:39:08.060: Use file-acct reset when the problem is recovered
1168824: Aug 23 12:39:08.060: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168825: Aug 23 12:39:08.060: Use file-acct reset when the problem is recovered
1168826: Aug 23 12:39:08.072: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168827: Aug 23 12:39:08.072: Use file-acct reset when the problem is recovered
1168828: Aug 23 12:39:08.072: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
1168829: Aug 23 12:39:08.072: Use file-acct reset when the problem is recovered
UC560#
UC560#
Nipun Singh Raghav
VIP Advisor
Can you add bind command under voice service voip > sip? Also, add authenticate realm under voice register global
Content for Community-Ad
August's Community Spotlight Awards
