SIP registration help
campbech1
I'm attempting to setup a new SIP provider and this is the first time I've set one up, outside of using AT&T.
The registration string they are requesting isn't what I'm use to.
I realize the below is based on Asterisk, but it's the only documentation from the vendor I can find.  I can't find a way to convert them over to my 2911 for testing.
They are requesting it setup as:
disallow=all
allow=ulaw
username=AUTHORIZATIONNAME
fromuser=AUTHORIZATIONNAME
type=friend
secret=PASSWORD
qualify=no
maxexpirey=3600
host=bt.voipdnsservers.com
fromdomain=bt.voipdnsservers.com
insecure=invite
dtmfmode=rfc2833
session-timers=refuse
defaultexpirey=60
nat=no
canreinvite=no
They then want the registration string to be:
AUTHORIZATIONNAME:PASSWORD@bt.voipdnsservers.com/AUTHORIZATIONNAME
I have spent a full day on this and I'm not getting any closer.
Could anyone provide a couple minutes of assistance?
R0g22
Look at the AT&T section here -
https://www.cisco.com/c/en/us/solutions/enterprise/interoperability-portal/networking_solutions_products_genericcontent0900aecd805bd13d.html
It should help you. You basically need to configure the "sip-ua" on the IOS GW to support registration.
5 Replies 5
R0g22
Thank you for this, but I’m use to configuring for AT&T. I’m having an issue with a new vendor that wants their registration different than what I’m use to.
OK. Got you. That looks like something that won't be possible natively. You might want to use SIP Profile to tweak the authorization header.
Can your provider do IP address based authentication or have they mandated a registration based auth ?
Correct, I believe it will be a profile, just not sure how to manipulate it to be what I need. I messed with it for quite a while today.
Yes, they won’t change what they are requesting.
I left for the day so don’t have access to my lab. I will give it a try tomorrow and see if it is even possible to put it in that format.
