05-14-2013 09:46 AM - edited 03-16-2019 05:18 PM
Hi All,
I have an issue with a sip call.
Basically the phone rings but times out when calling in externally.
The topology is:
ITSP ------ CUBE ----- CUCM
All call legs are SIP.
I have done a debug ccsip messages and it would appear that after the CUBE acknowledges the OK from the CUCM the CUBE isnt then passing the SDP information on to the ITSP.
So as a result it just rings out.
Thanks for the help.
Cheers
Kev
Solved! Go to Solution.
05-15-2013 01:23 PM
Disabled rel1xx on dial-peer 1.
Makes sense as this is the dial-peer with the incoming called number on it.
Must stop the re1xx being sent from the cube when it hits this dial-peer.
Im going to debug it to confirm.
Cheers
05-15-2013 01:48 PM
Ok its connecting now at both ends but im getting one way voice called can hear caller but not the other way around.
Call then drops after about 20 seconds.
Debug attached.
Cheers
05-15-2013 01:57 PM
We are not getting an ACK from your provider..It is possible that your sip messages are not even getting to them. Do you have sip bind commands configured..You may have configured it wrongly...Can you please send your sh run..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
05-15-2013 02:09 PM
Ive attached the config.
The control and media are bound to gi0/1.300 under dial-peer 1.
Cheers
05-15-2013 02:26 PM
OK..So you have set the bind commands on gig 0/1.200. The question is this..Can your provider connect to this IP: 192.168.60.254? I doubt this because I can see that they are sending you invite on a different interface..
INVITE sip:0218169019@192.168.244.250:5060;user=phone SIP/2.0
interface GigabitEthernet0/1.200
description VOIP LAN
encapsulation dot1Q 200
ip address 192.168.60.254 255.255.255.0
If they cant talk to you on that ip then you cant configure your dial-peers and sip bind commands like this..
You have two options:
1. Dont use any bind comands at all, and the CUBE will chose the closest interface to the destination to send sip signalling and media
2. configure seperate dial-peers for calls coming in and outgoing from your CUBE
You need to seperate your inbound dial-peer and apply your bind commands like this..
dial-peer voice 3 voip
description From ITSP
session protocol sipv2
incoming called-number 021816.... (DDI BLOCK here)
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernetx/y --where gigx/y will be the interface facing your ITSP
voice-class sip bind media source-interface GigabitEthernetx/y
dtmf-relay rtp-nte
no vad
05-15-2013 11:32 PM
I realised after my last post that the sip was bound to the wrong interface and so it was in a different VLAN.
I changed the bind to .300 and changed the ip on the trunk on UCM and bang its fixed.
Cheers
05-16-2013 01:39 AM
Kevin,
Good to know its resolved. You can enable PRACK back, this can be useful in some cases. The problem wasnt PRACK after all
05-16-2013 02:33 AM
Aye mate,
I already have.
Thanks for the use of your eyes much appreciated.
Cheers
Kev
05-28-2013 09:17 AM
There are now problems with supplemntary services. A debug seems to show the audio inactive messages being passed to the ITSP and the ITSP sending an ok. The CUBE then sends an ACK and the a BYE to end the call.
Debug below:
*May 28 15:22:22.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0824636267@192.168.244.250:5060 SIP/2.0
Via: SIP/2.0/UDP 10.128.16.21:5060;branch=z9hG4bK27bcd7da7872c
From: <0218169019>;tag=9a6faa78-a360-49d5-b7da-21602c33796a-447465430218169019>
To: <0824636267>;tag=1F99CD74-6690824636267>
Date: Tue, 28 May 2013 15:24:03 GMT
Call-ID: 37657887-C6E111E2-85E0F85B-C341310C@192.168.244.250
Supported: timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 0929196991-3336638946-2245589083-3275829516
User-Agent: Cisco-CUCM8.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <0218169019>0218169019>
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires: 1800;refresher=uac
P-Asserted-Identity: "Test JR" <9019>9019>
Remote-Party-ID: "Test JR" <9019>;party=calling;screen=yes;privacy=off9019>
Content-Type: application/sdp
Content-Length: 221
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 10.128.16.21
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 30060 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=inactive
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
*May 28 15:22:22.695: //495/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 28 May 2013 15:22:22 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M2
Content-Length: 0
*May 28 15:22:22.695: //493/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0824636267@192.168.244.10:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.244.250:5060;branch=z9hG4bK2D02489
To: <0824636267>;tag=isn3930u-CC-290824636267>
Call-ID: rwswtmxrwmxsrqxtviiu03qtuvb1u0im@SoftX3000
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1369754542
Expires: 180
Content-Length: 289
v=0
o=CiscoSystemsSIP-GW-UserAgent 3683 3901 IN IP4 192.168.244.250
s=SIP Call
c=IN IP4 192.168.244.250
t=0 0
m=audio 17364 RTP/AVP 18 97
a=inactive
a=fmtp:18 annexb=yes
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=ptime:20
*May 28 15:22:22.755: //493/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <0824636267>0824636267>
Content-Length: 243
v=0
o=HuaweiSoftX3000 15910632 15910633 IN IP4 192.168.244.10
s=Sip Call
c=IN IP4 192.168.244.10
t=0 0
m=audio 20342 RTP/AVP 18 97
a=fmtp:97 0-15
a=fmtp:18 annexb=no
a=inactive
Sent:
ACK sip:0824636267@192.168.244.10:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.244.250:5060;branch=z9hG4bK2D1FE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*May 28 15:22:22.759: //493/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0824636267@192.168.244.10:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.244.250:5060;branch=z9hG4bK2D2B11
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=65
P-RTP-Stat: PS=123,OS=2460,PR=112,OR=2240,PL=0,JI=0,LA=0,DU=2
Content-Length: 0
*May 28 15:22:22.759: //495/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0218169019@10.128.16.21:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.244.250:5060;branch=z9hG4bK2D3792
To: <0218169019>;tag=9a6faa78-a360-49d5-b7da-21602c33796a-447465430218169019>
Max-Forwards: 70
CSeq: 102 BYE
P-RTP-Stat: PS=112,OS=2240,PR=130,OR=2600,PL=0,JI=0,LA=0,DU=2
Content-Length: 0
*May 28 15:22:22.795: //493/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
*May 28 15:22:22.919: //495/37626BBF85D8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
Kev
05-28-2013 10:16 AM
Kevin,
This is how call hold/transfer works with CUBE/CUCM
1. CUCM sends invite (re-invite) with an inactive SDP (a=inactive) to indicate a break in media path
2. CUCM sends a Delayed offer to insert MOH or to resume Media stream
NB: CUCM expects a sendrecv offer with SDP to the DO. (NB:if cucm gets an inactive offer SDP in the 200 OK instead of providing a send-recv offer SDP, the media path remains in an inactive state and causes calls to dropcall will drop),CUCM sends an ACK with sendonly to the 200 OK
3.CUCM establishes newcall leg with the intended transfered destination..Once this call is connected
4.CUCM receives a new Transfer instruction from the transferring phone to connect the held party
5. Next CUCM sends a re-invite with an inactive SDP to indicate a break in media path to MOH (in attempt to complete transfer)
6.Next CUCM sends an inactive SDP to indicate a break in media path between transfering party & transfered party to remove Xferring party from call
7. Next CUCM sends a DO re-invite to connect the transfered party. The far end then sends 200 OK with the required SDP to connect the call
As you can see, when CUBE sent an INVITE with a=inactive, the respond was a 200 ok with a=inactive...Looka the step 2 from above..CUBE expected a send-recv. This is why the call is disconnected
The strange thing is that according to the RFC3264
rfc-3264 sec-6.1(Unicast Stream), It says the
following must requirement:
If a stream is offered as sendonly, the corresponding stream MUST be
marked as recvonly or inactive in the answer.
If a media stream is
listed as recvonly in the offer, the answer MUST be marked as
sendonly or inactive in the answer.
If an offered media
stream is listed as inactive, it MUST be marked as inactive in the
answer.
So your ITSP is doing the correct thing but Cisco implementation doesnt follow that.
If you were on CUCM8.5, then you can enable the parameter use MTP if needed but its not available in CUCM8.0.
Yor options
1. Use an MTP on CUCM sip trunk..Hence CUCM wont send an inactive SDP to the CUBE during transfer or hold. Be careful here is you have faxes etc..Doesnt work well..But you can try this for test and see if it works then that will confirm what I have described
2. We can try and configure a sip profile that will change any SDP with a=inacive to a=send-recv and see if that helps
06-07-2013 03:54 AM
Sorry for the late reply pal.
Been busy.
I configured the CUBE as a HW MTP and it sorted it.
Now no MOH even though the SIP trunk is assigned an MOH server.
Im thinking maybe its because of the g729br8 codec as i dont even see CUCM invoke MOH.
