SIP SRST inbound and outbound translations
benbollinger
Level 2
Level 2
We're currently got 4 FXO ports that are PLAR'd to 7403 and when the link to callmanager is up it rings a hunt group.  We also dial 8 for an outside line.
When SRST kicks in our 8841's failover fine but the translations don't seem to work for inbound and outbound digit manipulation so calls don't ring 7403/202100 and dialing 8 gives you and immediate busy signal.
Any pointers or assistance would be greatly appreciated.
Below is a section of our config:
voice register global
 mode srst
 timeouts interdigit 4
 system message SRST Mode
 max-dn 25
 max-pool 25
voice register pool  1
 translation-profile incoming SRST-OUT
 translation-profile outgoing 9
 id network 172.XX.11.64 mask 255.255.255.192
 proxy 172.XX.11.65
 alias 1 7403 to 202100
 dtmf-relay cisco-rtp
 codec g711ulaw
 no vad
voice translation-rule 9
 rule 1 /^8/ //
voice translation-rule 30
 rule 1 /7403/ /202100/
voice-port 0/0/0
 connection plar 7403
 caller-id enable
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 caller-id enable
voice-port 0/0/3
 caller-id enable
dial-peer voice 1 pots
 preference 1
 destination-pattern .T
 port 0/0/0
dial-peer voice 2 pots
 preference 1
 port 0/0/1
dial-peer voice 3 pots
 preference 1
 port 0/0/2
dial-peer voice 4 pots
 preference 1
 port 0/0/3
dial-peer voice 100 voip
 destination-pattern 7403
 translate-outgoing calling 9
 session target ipv4:10.X.0.5
 dtmf-relay h245-signal h245-alphanumeric cisco-rtp
 codec g711ulaw
 no vad
dial-peer voice 101 voip
 preference 1
 session target ipv4:10.Y.0.5
 codec g711ulaw
 no vad
0 Replies 0
