07-02-2018 09:39 AM - edited 03-18-2019 12:27 PM
Hi everyone,
My setup is composed of an ISR G2 SIP SRST, and a few SIP phones with up to date firmware.
I'm checking the SRST functionality when the phones can't reach the CUCM cluster.
It seems as though when phones registered to the SRST are in a call with one another, all RTP traffic travels through the SRST much like an audio media gateway. When they aren't registered via SRST, but rather the same CUCM cluster, they speak to each other via RTP directly.
Is this correct behavior from the SIP SRST?
Thanks!
Solved! Go to Solution.
07-03-2018 01:08 AM
07-02-2018 09:49 AM
07-03-2018 12:03 AM
1) According to:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/command/reference/srstcr/srsa_n_z.html
It is possible to configure the media mode to flow around (under "voice service voip"). Does this only apply to calls over the SIP trunk between CUCM clusters and SRSTs?
2) Are you aware of any Cisco documentation that states that SRST SIP-to-SIP calls (not over the SIP trunk) only support flow through? I wasn't able to find such a statement.
3) As far as I can tell, no video RTP is supported with endpoints registered under SRST. Even jabber supports only phone-mode under SRST.
Is this accurate? If so, then I just need to make sure that there is no aggregate audio RTP bottleneck to and from my SRST for voice traffic. If there are endpoints which support video under SRST, I'd need to make sure there is no aggregate video RTP bottleneck.
Within:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/media-path.html
It states that "Video codecs are not supported for Media Flow-Through" yet it could be referring to only CME rather than SRST as well. The same document also states that Flow-Around is supported by video endpoints.
Thanks for the assistance.
07-03-2018 01:08 AM
07-03-2018 02:09 AM
Alright, thank you :)
