10-20-2016 12:04 AM - edited 03-17-2019 08:25 AM
Dear,
I have CUCM 10.5 and 2911 in one of my branch for srst refrence with WAN link down for twenty 7821 SIP Phone.
the problem is that when going to srst mode they all register and after about 1 or 2 minute ip phone get unregistered and then registered again.
this is my configuration:
no voice hunt unassigned-number
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 200
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 2
h225 timeout setup 2
voice register global
mode esrst
source-address x.x.x.x port 5060
system message "SRST Mode"
max-dn 30
max-pool 20
voice register dn 1
number xxx
voice register dn 2
number xxx
voice register dn 3
number xxx
voice register dn 4
number xxx
voice register dn 5
number xxx
voice register dn 6
number xxx
voice register dn 7
number xxx
voice register dn 8
number xxx
voice register dn 9
number xxx
voice register dn 10
number xxx
voice register dn 11
number xxx
voice register dn 12
number xxx
voice register dn 13
number xxx
voice register dn 14
number xxx
voice register dn 15
number xxx
voice register pool 1
id network 172.22.3.0 mask 255.255.255.0
number 1 dn 1
no digit collect kpml
voice register pool 2
number 1 dn 2
voice register pool 3
number 1 dn 3
voice register pool 4
number 1 dn 4
voice register pool 5
number 1 dn 5
voice register pool 6
number 1 dn 6
voice register pool 7
number 1 dn 7
voice register pool 8
number 1 dn 8
voice register pool 9
number 1 dn 9
voice register pool 10
number 1 dn 10
voice register pool 11
number 1 dn 11
voice register pool 12
number 1 dn 12
voice register pool 13
number 1 dn 13
voice register pool 14
number 1 dn 14
voice register pool 15
number 1 dn 15
voice hunt-group 1 sequential
final x
list x,x,x
timeout 8
pilot x
preference 2 secondary 9
10-20-2016 01:01 AM
Do you have packet captures for the duration when the IP phone registers in SRST and then unregisters after 1-2 minutes? The captures can show what exactly cause the phones to unregister. If this is affecting all the phones / phone models then it is likely a network issue as within the config there isn't anything that would force the phone to unregister while the network is up.
Manish
10-20-2016 08:05 AM
Also, you can run debug ccsip mess, keep one phone only for testing and share the debug after phone goes to SRST, unregister in 1-2 mins then registers again.
10-22-2016 06:59 AM
Thanks for reply
p>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-00082f1bff5b>";+u.sip!devicename.ccm.cisco.com="SEP00082F1BFF5B";+u.sip!model.ccm.cisco.com="621"
Supported: extended-refer,norefersub,X-cisco-srtp-fallback,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Oct 22 13:13:23.667: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.82:5060;branch=z9hG4bK097a71f0
From: <sip:2210@172.22.3.11>;tag=c80084abd8ce018f38c193a5-0129fe79
To: <sip:2210@172.22.3.11>
Call-ID: c80084ab-d8ce0034-518af367-77a704d9@172.22.3.82
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:13:07 GMT
CSeq: 102 REGISTER
User-Agent: Cisco-CP7821/10.3.1
Contact: <sip:06288983-39cf-f1b4-ca78-b4bb67363fd0@172.22.3.82:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd8ce>";+u.sip!devicename.ccm.cisco.com="SEPC80084ABD8CE";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:24.131: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.63:5060;branch=z9hG4bK201f0b47
From: <sip:2143@172.22.3.11>;tag=e0d173e55f5300e907379675-6e9dfb17
To: <sip:2143@172.22.3.11>
Call-ID: e0d173e5-5f530044-1a8f23c9-43487b7b@172.22.3.63
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:56:12 GMT
CSeq: 207 REGISTER
Contact: <sip:b8b030f8-e8ab-cbd8-3e58-94e4b10ca4e5@172.22.3.63:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e55f53>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E55F53";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:10 Name=SEPE0D173E55F53 ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=tcp_timeout"
Expires: 3600
Received:
Via: SIP/2.0/UDP 172.22.3.63:5060;branch=z9hG4bK6ead3d50
From: <sip:2243@172.22.3.11>;tag=e0d173e55f5300ea01bb775c-146d6dcd
To: <sip:2243@172.22.3.11>
Call-ID: e0d173e5-5f530045-3035548d-2ef27742@172.22.3.63
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:30326dd5-9c72-5925-81ab-968e558dc9e5@172.22.3.63:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e55f53>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E55F53";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:24.679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.68:5060;branch=z9hG4bK669e932f
From: <sip:2208@172.22.3.11>;tag=00082f1bff5b008c77c677bf-1c7c2141
To: <sip:2208@172.22.3.11>
Call-ID: 00082f1b-ff5b0038-5b1b89fd-06b36f94@172.22.3.68
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:13:21 GMT
CSeq: 103 REGISTER
Contact: <sip:22707d9c-f107-e4a4-32d3-bd2b541d79ca@172.22.3.68:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-00082f1bff5b>";+u.sip!devicename.ccm.cisco.com="SEP00082F1BFF5B";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:24.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.65:5060;branch=z9hG4bK6ed66613
From: <sip:2144@172.22.3.11>;tag=e0d173e5e814013478f9b455-367b9e4f
To: <sip:2144@172.22.3.11>
Call-ID: e0d173e5-e8140048-2735acd3-5951b9f3@172.22.3.65
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:56:08 GMT
CSeq: 207 REGISTER
Contact: <sip:fb50ab7e-dff2-01b0-b7a7-70644018cb89@172.22.3.65:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5e814>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5E814";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:12 Name=SEPE0D173E5E814 ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=cm-reset-tcp"
Expires: 3600
Received:
Via: SIP/2.0/UDP 172.22.3.65:5060;branch=z9hG4bK2e64fde7
From: <sip:2244@172.22.3.11>;tag=e0d173e5e81401350487e262-00807544
To: <sip:2244@172.22.3.11>
Call-ID: e0d173e5-e8140049-2321f6fb-65395fcc@172.22.3.65
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:a06749d2-3d3d-35b2-090e-550730586350@172.22.3.65:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5e814>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5E814";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:24.867: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.81:5060;branch=z9hG4bK34d45a69
From: <sip:2133@172.22.3.11>;tag=e0d173e5561b008e723676ab-3656ba53
To: <sip:2133@172.22.3.11>
Call-ID: e0d173e5-561b0036-3b4d39c4-0f945099@172.22.3.81
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:56:16 GMT
CSeq: 207 REGISTER
Contact: <sip:edb178ca-9761-b174-f958-53863b6a7da2@172.22.3.81:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5561b>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5561B";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:10 Name=SEPE0D173E5561B ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=tcp_timeout"
Expires: 3600
Oct 22 13:13:24.871: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.81:5060;branch=z9hG4bK3484703d
From: <sip:2233@172.22.3.11>;tag=e0d173e5561b008f20463467-0893d02d
To: <sip:2233@172.22.3.11>
Call-ID: e0d173e5-561b0037-089acae3-16c00dc5@172.22.3.81
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:1e299b95-584a-8a05-92ef-68824b7435c5@172.22.3.81:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5561b>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5561B";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:25.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.73:5060;branch=z9hG4bK3c3054d7
From: <sip:2218@172.22.3.11>;tag=e0d173e5819000943f444db2-10f251bc
To: <sip:2218@172.22.3.11>
Call-ID: e0d173e5-8190003d-7477d460-41a20459@172.22.3.73
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:13:09 GMT
CSeq: 102 REGISTER
Contact: <sip:32bd7f53-e271-d606-f6f1-f12f63058f95@172.22.3.73:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e58190>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E58190";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:26.235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.84:5060;branch=z9hG4bK3ea34c4f
From: <sip:2213@172.22.3.11>;tag=1ce85d07e7520021529f0fb8-5d9b3fab
To: <sip:2213@172.22.3.11>
Call-ID: 1ce85d07-e7520038-7f46e6a0-1c39b6f0@172.22.3.84
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:12:57 GMT
CSeq: 103 REGISTER
Contact: <sip:0bd2af45-8eab-da57-f7a2-671c19dd2b82@172.22.3.84:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-1ce85d07e752>";+u.sip!devicename.ccm.cisco.com="SEP1CE85D07E752";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:26.915: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:26.927: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.62:5060;branch=z9hG4bK20dac1b9
From: <sip:2140@172.22.3.11>;tag=e0d173e5de1f02013537b7bf-454d9e53
To: <sip:2140@172.22.3.11>
Call-ID: e0d173e5-de1f006c-6a98633f-2da1721a@172.22.3.62
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:56:18 GMT
CSeq: 208 REGISTER
Contact: <sip:968bcf8f-bc87-8e6c-422b-3518de44f566@172.22.3.62:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5de1f>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5DE1F";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:12 Name=SEPE0D173E5DE1F ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=cm-reset-tcp"
Expires: 3600
Received:
Via: SIP/2.0/UDP 172.22.3.67:5060;branch=z9hG4bK09ed0eb7
From: <sip:2207@172.22.3.11>;tag=e0d173e5835b007c055ad624-3255fafb
To: <sip:2207@172.22.3.11>
Call-ID: e0d173e5-835b000d-79dfce5a-0738b9a9@172.22.3.67
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:12:58 GMT
CSeq: 102 REGISTER
Contact: <sip:328796cd-6d0e-c960-49af-bf62f003959d@172.22.3.67:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e5835b>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E5835B";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:26.931: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.75:5060;branch=z9hG4bK5022091b
From: <sip:2116@172.22.3.11>;tag=5067ae2065e0007465833db9-2862e689
To: <sip:2116@172.22.3.11>
Call-ID: 5067ae20-65e00034-2ab7c8b3-00b2e554@172.22.3.75
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:56:14 GMT
CSeq: 207 REGISTER
Contact: <sip:9acfe5bb-8a3d-b00f-6356-dcd5e8accaa9@172.22.3.75:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-5067ae2065e0>";+u.sip!devicename.ccm.cisco.com="SEP5067AE2065E0";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:12 Name=SEP5067AE2065E0 ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=cm-reset-tcp"
Expires: 3600
Received:
Via: SIP/2.0/UDP 172.22.3.75:5060;branch=z9hG4bK2361ec84
From: <sip:2216@172.22.3.11>;tag=5067ae2065e000750efe22e4-01fb05d3
To: <sip:2216@172.22.3.11>
Call-ID: 5067ae20-65e00035-7a489b8f-09fd6c30@172.22.3.75
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:a5fab677-5fe4-f45a-66d0-00cc3198b120@172.22.3.75:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-5067ae2065e0>";+u.sip!devicename.ccm.cisco.com="SEP5067AE2065E0";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:27.587: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:28.155: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK4ba3d772
From: <sip:2112@172.22.3.11>;tag=e0d173e56e4d00ef04b4b668-48155eaa
To: <sip:2112@172.22.3.11>
Call-ID: e0d173e5-6e4d0040-7515f613-3bb50e95@172.22.3.71
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:13:26 GMT
CSeq: 208 REGISTER
Contact: <sip:880b21d4-9f18-90da-23e8-c7f1edb5730a@172.22.3.71:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e56e4d>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E56E4D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:20 Name=SEPE0D173E56E4D ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-1-1SR1-4.loads Last=phone-keypad"
Expires: 3600
Oct 22 13:13:28.163: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK0d659549
From: <sip:2212@172.22.3.11>;tag=e0d173e56e4d00f06bb54f2b-63f906f8
To: <sip:2212@172.22.3.11>
Call-ID: e0d173e5-6e4d0041-4bd72597-1217a215@172.22.3.71
Max-Forwards: 70
CSeq: 103 REGISTER
Contact: <sip:28f907ce-0287-7898-ef44-dab2741856b6@172.22.3.71:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-e0d173e56e4d>";+u.sip!devicename.ccm.cisco.com="SEPE0D173E56E4D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:28.171: //7301/27E191EA98E1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:2112@172.22.3.11>;tag=A895100-716
Date: Sat, 22 Oct 2016 13:13:28 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M1
CSeq: 208 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:2112@172.22.3.71:5060>;expires=1200;x-cisco-newreg
Expires: 1200
Content-Type: application/x-cisco-remotecc-response+xml
Content-Length: 267
<?xml version="1.0" encoding="UTF-8"?><x-cisco-remotecc-response><response><code>200</code><optionsind><srstoption><sharedline>enable</sharedline><blfspeeddial>enable</blfspeeddial><video>enable</video></srstoption></optionsind></response></x-cisco-remotecc-response>
Oct 22 13:13:28.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:28.483: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:2100@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK796a5b94
From: <sip:2100@172.22.3.71>;tag=e0d173e56e4d00f3576f3ce3-0dde067a
To: <sip:2100@172.22.3.11>
Call-ID: e0d173e5-6e4d003d-2f63f86b-1c5aa069@172.22.3.71
Date: Sat, 22 Oct 2016 13:13:27 GMT
CSeq: 1000 SUBSCRIBE
Event: presence
Accept: application/cpim-pidf+xml
Expires: 3600
Max-Forwards: 70
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 0
Oct 22 13:13:28.907: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:909128151743@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK1fb5f9df
From: <sip:909128151743@172.22.3.71>;tag=e0d173e56e4d00f433b458ee-603d420a
To: <sip:909128151743@172.22.3.11>
Call-ID: e0d173e5-6e4d003e-6807e0f1-0653dad1@172.22.3.71
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Oct 22 13:13:28.927: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:976245368@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK6ec00fea
From: <sip:976245368@172.22.3.71>;tag=e0d173e56e4d00f5727a4ecc-7730baa2
To: <sip:976245368@172.22.3.11>
Call-ID: e0d173e5-6e4d003f-7823db74-19a255e9@172.22.3.71
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Oct 22 13:13:28.931: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:909033608057@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK791fa29e
From: <sip:909033608057@172.22.3.71>;tag=e0d173e56e4d00f648e88892-746aec36
To: <sip:909033608057@172.22.3.11>
Call-ID: e0d173e5-6e4d0040-63d605fd-049d9728@172.22.3.71
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Oct 22 13:13:28.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:3222@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK3bf6bdc6
From: <sip:3222@172.22.3.71>;tag=e0d173e56e4d00f72beb64a8-50416e9a
To: <sip:3222@172.22.3.11>
Call-ID: e0d173e5-6e4d0041-44f6c835-3e0306bd@172.22.3.71
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Received:
SUBSCRIBE sip:909101483720@172.22.3.11 SIP/2.0
Via: SIP/2.0/UDP 172.22.3.71:5060;branch=z9hG4bK0e6d11a7
From: <sip:909101483720@172.22.3.71>;tag=e0d173e56e4d00f828efcf2d-4b689c06
To: <sip:909101483720@172.22.3.11>
Call-ID: e0d173e5-6e4d0042-2186b067-5b90ee2d@172.22.3.71
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Oct 22 13:13:28.939: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Received:
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Oct 22 13:13:28.943: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Received:
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Received:
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Received:
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:29.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:29.431: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:29.435: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.69:5060;branch=z9hG4bK1963d864
From: <sip:2109@172.22.3.11>;tag=c80084abd6ce007d2c6f68d3-597c8738
To: <sip:2109@172.22.3.11>
Call-ID: c80084ab-d6ce0036-3c014d18-455e7bff@172.22.3.69
Max-Forwards: 70
CSeq: 208 REGISTER
Contact: <sip:8355fa78-dd68-0c89-f45b-0f831a20abdc@172.22.3.69:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd6ce>";+u.sip!devicename.ccm.cisco.com="SEPC80084ABD6CE";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:20 Name=SEPC80084ABD6CE ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-2-1-12SR1-4.loads Last=phone-keypad"
Expires: 3600
Received:
Via: SIP/2.0/UDP 172.22.3.69:5060;branch=z9hG4bK78df776a
From: <sip:2209@172.22.3.11>;tag=c80084abd6ce007e76df7d35-57549876
To: <sip:2209@172.22.3.11>
Call-ID: c80084ab-d6ce0037-40b77174-39c074ee@172.22.3.69
Max-Forwards: 70
CSeq: 103 REGISTER
Contact: <sip:61762e0c-55fc-9e87-421d-5cc430b9a45e@172.22.3.69:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd6ce>";+u.sip!devicename.ccm.cisco.com="SEPC80084ABD6CE";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:29.439: //7305/28A4E14D98E5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:2109@172.22.3.11>;tag=A895600-1B02
Date: Sat, 22 Oct 2016 13:13:29 GMT
CSeq: 208 REGISTER
Contact: <sip:2109@172.22.3.69:5060>;expires=1200;x-cisco-newreg
Expires: 1200
Content-Length: 267
Oct 22 13:13:29.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.70:5060;branch=z9hG4bK70b47c4a
From: <sip:2111@172.22.3.11>;tag=c80084abd50301d165eabf3f-1a63fa87
To: <sip:2111@172.22.3.11>
Call-ID: c80084ab-d5030063-66b241cb-071d1172@172.22.3.70
Max-Forwards: 70
CSeq: 209 REGISTER
Contact: <sip:528c7989-3183-c982-7866-14099fc5d9d7@172.22.3.70:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd503>";+u.sip!devicename.ccm.cisco.com="SEPC80084ABD503";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:20 Name=SEPC80084ABD503 ActiveLoad=sip78xx.10-3-1-12.loads InactiveLoad=sip78xx.10-2-1-12SR1-4.loads Last=phone-keypad"
Expires: 3600
Oct 22 13:13:29.863: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:30.455: //7309/28E45A7998E9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:2111@172.22.3.11>;tag=A8957A0-A31
CSeq: 209 REGISTER
Contact: <sip:2111@172.22.3.70:5060>;expires=1200;x-cisco-newreg
Expires: 1200
Content-Length: 267
Oct 22 13:13:30.467: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:30.471: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.70:5060;branch=z9hG4bK698d7489
From: <sip:2211@172.22.3.11>;tag=c80084abd50301d47c4af482-028c77e9
To: <sip:2211@172.22.3.11>
Call-ID: c80084ab-d5030064-4700bbd5-41172c2c@172.22.3.70
Max-Forwards: 70
CSeq: 103 REGISTER
Contact: <sip:8b118bf6-34a9-1e23-0497-ba4e517e7b87@172.22.3.70:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd503>";+u.sip!devicename.ccm.cisco.com="SEPC80084ABD503";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 208 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:30.831: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:30.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:31.447: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:31.455: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:31.459: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:31.831: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:31.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:32.251: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
Oct 22 13:13:32.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:33.011: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Oct 22 13:13:33.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:33.019: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:34.047: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:34.087: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:34.487: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:34.907: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 208 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:35.327: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:35.339: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:35.731: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:36.931: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 207 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:36.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:37.347: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:37.351: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel0, changed state to up
Oct 22 13:13:37.359: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:37.863: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:38.691: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:38.707: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 208 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:39.599: %DUAL-5-NBRCHANGE: EIGRP-IPv4 90: Neighbor 172.21.1.1 (Tunnel0) is up: new adjacency
Oct 22 13:13:39.603: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:41.011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:41.411: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:41.883: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:42.695: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:43.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:43.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 172.22.3.66:5060;branch=z9hG4bK339269b6
From: <sip:2106@172.22.3.11>;tag=5067ae2000250184288b4320-120db836
To: <sip:2106@172.22.3.11>
Call-ID: 5067ae20-00250060-2c228656-7be74ca5@172.22.3.66
Max-Forwards: 70
Date: Sat, 22 Oct 2016 13:57:30 GMT
CSeq: 201 REGISTER
Contact: <sip:9cfd1659-08f9-95f1-1eba-7449bb3375d9@172.22.3.66:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-5067ae200025>";+u.sip!devicename.ccm.cisco.com="SEP5067AE200025";+u.sip!model.ccm.cisco.com="621"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 0
Oct 22 13:13:43.895: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 201 REGISTER
Content-Length: 0
Expires: 0
Oct 22 13:13:44.903: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 201 REGISTER
Content-Length: 0
Expires: 0
Oct 22 13:13:45.099: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:46.075: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:46.387: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:47.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 201 REGISTER
Content-Length: 0
Expires: 0
Oct 22 13:13:47.519: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Niavaran-R-E-1#
Niavaran-R-E-1#
Niavaran-R-E-1#
Niavaran-R-E-1#cename.ccm.cisco.com="SEPE0D173E56E4D";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:49.159: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Niavaran-R-E-1#
Niavaran-R-E-1#
Niavaran-R-E-1#
Niavaran-R-E-1#ucename.ccm.cisco.com="SEPC80084ABD6CE";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:49.551: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Contact: <sip:8b118bf6-34a9-1e23-0497-ba4e517e7b87@172.22.3.70:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-c80084abd503>";+u.sip!devi alcename.ccm.cisco.com="SEPC80084ABD503";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 3600
Oct 22 13:13:50.367: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Content-Length: 0
Expires: 3600
Oct 22 13:13:51.151: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 201 REGISTER
Contact: <sip:9cfd1659-08f9-95f1-1eba-7449bb3375d9@172.22.3.66:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-5067ae200025>";+u.sip!devil
All possible debugging has been turned off
Niavaran-R-E-1#cename.ccm.cisco.com="SEP5067AE200025";+u.sip!model.ccm.cisco.com="621"
Content-Length: 0
Expires: 0
Oct 22 13:13:51.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 REGISTER
Niavaran-R-E-1#
Content-Length: 0
Expires: 3600
