Having a problem applying firmware on a 7906 IP phone its driving me crazy ..
The phone has SIP version sip11.8-3-1s and i'm trying to put sccp on the phone using an isolated network without using the CUCMe
iv'e defaulted the settings using the # key and the number combo 123456789*0# and the phone picks up an ip address and then loads the term11.default file
Setup a dhcp server with option 150 the phone is getting an address and is talking to the tftp i can see the file being transfered through the tftp log
Connection received from 172.16.11.51 on port 49153 [04/03 11:13:09.442]
Read request for file <term11.default.loads>. Mode octet [04/03 11:13:09.442]
Using local port 2197 [04/03 11:13:09.442]
<term11.default.loads>: sent 2 blks, 662 bytes in 0 s. 0 blk resent [04/03 11:13:09.504]
The phone then goes into its boot menu with Cisco logo and java and sits there no more activety is on the tftp. The six files that are refrenced in the term11 file are in the same directoy of the tftp server :
jar11sccp.8-5-4TH1-6.sbn
cnu11.8-5-4TH1-6.sbn
apps11.8-5-4TH1-6.sbn
dsp11.8-5-4TH1-6.sbn
cvm11sccp.8-5-4TH1-6.sbn
Anyone know what i'm doing wrong ? I'm going to try an early 8.3.1 and see if that makes any difference.
