SIP-to-SIP (CUBE) Calls Being Rejected By Provider
I have a 2821 running IOS c2800nm-adventerprisek9-mz.151-4.M7 in a lab environment. I have it configured with SIP trunks to both CUCM and a termination provider. I am using static (source ip based) authentication with the provider. When I place calls from an analog phone on an FXS port, the call connects to the PSTN just fine. When placing calls from CUCM, I get a Temporarily Unavailable error, which after much research I've found means 401 Unauthorized from this provider (annoying, I know).
So, I know the problem has something to do with a configuration change I need to make in order to the calls originating from CUCM, but I'm at a loss as to what. I've tried working with the provider, but they seem to be incapable of really looking deep into things. I'll continue to work with them, but I'm asking here as well, hoping one of you has seen this before.
Here is the INVITE sent from my gateway when dialed from an analog phone (successful):
INVITE sip:16518158320@67.205.159.100:5060 SIP/2.0
Via: SIP/2.0/TCP 10.xx.xx.xx:5060;branch=z9hG4bK48F192D
Remote-Party-ID: "Cordless 0" <sip:6125556666@10.xx.xx.xx>;party=calling;screen=no;privacy=off
From: "Cordless 0" <sip:6125556666@sip.didlogic.net>;tag=B9FD280-25D0
To: <sip:16518158320@67.205.159.100>
Date: Fri, 11 Apr 2014 19:47:30 GMT
Call-ID: F3B23EB0-C0E811E3-830AE452-E7A949D0@10.0.0.50
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 4044704048-3236434403-2198201426-3886631376
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1397245650
Contact: <sip:6125556666@10.0.0.50:5060;transport=tcp>
Call-Info: <sip:10.xx.xx.xx:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 8252 7196 IN IP4 10.xx.xx.xx
s=SIP Call
c=IN IP4 10.xx.xx.xx
t=0 0
m=audio 17690 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
And here is the SIP INVITE from the CUCM Call, note that nothing is sent after this in either case before receiving the respective Replies.
Via: SIP/2.0/TCP 10.xx.xx.xx:5060;branch=z9hG4bK48D6F4
Remote-Party-ID: "Zach Bullough" <sip:651815xxxx@10.xx.xx.xx>;party=calling;screen=yes;privacy=off
From: "Zach Bullough" <sip:651815xxxx@sip.didlogic.net>;tag=B9E9608-19EA
To: <sip:1651815xxxx@67.205.159.100>
Date: Fri, 11 Apr 2014 19:46:09 GMT
Call-ID: C3674D14-C0E811E3-82FCE452-E7A949D0@10.xx.xx.xx
Min-SE:  1800
Cisco-Guid: 3964935168-0000065536-0000000029-0051685568
CSeq: 101 INVITE
Timestamp: 1397245569
Contact: <sip:6518158320@10.xx.xx.xx:5060;transport=tcp>
Expires: 180
Max-Forwards: 69
Session-Expires:  1800
Content-Length: 285
v=0
o=CiscoSystemsSIP-GW-UserAgent 5407 1747 IN IP4 10.xx.xx.xx
s=SIP Call
t=0 0
m=audio 17212 RTP/AVP 0 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
 As far as I can tell, they are about as identical as they can be. Note that IPs I censored are all identical in their respective uses.
Here is what I think the relevant configuration:
sip
  bind control source-interface Vlan1
  bind media source-interface Vlan1
  session transport tcp
  header-passing
  no call service stop
  registration passthrough static
sip-ua
 permit hostname dns:east-softswitch-01.circuitid.com
Any tips or complete solutions are welcome. If you need more information, please let me know.
George Thomas
Level 10
Level 10
401 unauthorized to me means something that you send, the provider doesnt like. Did provider give you a specific DID for your trunk. I would modify your external phone number mask to be that caller ID and try again. If possible, please post full SIP debug from the gateway.
Please rate useful posts.
Hey, thanks for the reply. I managed to fix the SIP-to-SIP problem. I was missing a sip privacy setting in my voice class voip config. I found the recommended configuration for another Trunk provider, and that solved the problem.
For people who come across this later, what I added was
  asserted-id ppi
to voice service voip
 sip
After that, my static authenticated calls started working. Now I'm dealing with what I think is a NAT issue with dynamic (digest) authentication. Using quite a few sip-profile MODIFY commands I've managed to manually NAT my inside private network in the messages, but somehow, things are still not working right. I show as registered to my outside public IP, like I should, but once I authenticate calls through the proxy, I never receive a reply... Not sure what's happening there.
The biggest problem lies in that I have this lab behind non-cisco equipment for the moment, pending my dedicated lab connection going in, and the consumer-grade router is not translating everything like it should... at least that's my suspicion.
If anyone feels like helping out, here's the full config:
 sip
  header-passing
  error-passthru
  asserted-id ppi
  localhost dns:domain.com
  midcall-signaling passthru
  sip-profiles 1
voice class sip-profiles 1
 request INVITE sip-header From modify "@.+>" "@domain.com>"
 request REGISTER sip-header From modify "@.*>" "@domain.com>"
 request REGISTER sip-header Contact modify "@.*>" "@domain.com>"
 request INVITE sip-header Contact modify "@.*>" "@domain.com>"
 request INVITE sip-header Call-Info remove
 request INVITE sdp-header Connection-Info modify "10\.0\.0\.50" "domain.com"
 request INVITE sdp-header Audio-Connection-Info modify "10\.0\.0\.50" "domain.com"
 request INVITE sdp-header Session-Owner modify "10\.0\.0\.50" "domain.com"
 request INVITE sdp-header Session-Info modify "10\.0\.0\.50" "domain.com"
sip-ua
 credentials username 170705 password 7 011535570F0E145C75 realm chicago.voip.ms
 credentials username 32046 password 7 110F2A564317195F50 realm sip.didlogic.net
 authentication username 170705 password 7 08277F1D5D1C174446 realm chicago.voip.ms
 authentication username 170705 password 7 050D355C75495C5A4D realm chicago2.voip.ms
 authentication username 32046 password 7 050D355C75495C5A4D realm sip.didlogic.net
 registrar 1 dns:chicago.voip.ms expires 3600
 registrar 2 dns:chicago2.voip.ms expires 3600
 registrar 3 dns:sip.didlogic.net expires 3600
dial-peer voice 30 voip
 description SHARED OUTGOING SIP PSTN 11
 translation-profile outgoing CUBE-CLEAN
 destination-pattern 01[2-9]..[2-9]......
 session protocol sipv2
 session target dns:chicago2.voip.ms
 session transport udp
 no voice-class sip block 180
 no voice-class sip block 183
 no voice-class sip block 181
 dtmf-relay sip-notify rtp-nte
 codec g711ulaw
And here's a sample conversation where I suddenly stop getting messages:
Apr 13 21:41:34.762: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1XXXXXXXXXX@sip.didlogic.net:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.50:5060;branch=z9hG4bK59E1187
From: "Zach Bullough" <sip:XXXXXXXXXX@domain.com>;tag=1654EA40-97B
To: <sip:1XXXXXXXXXX@sip.didlogic.net>
Date: Sun, 13 Apr 2014 21:41:34 GMT
Call-ID: 3800BC64-C28B11E3-8835E452-E7A949D0@domain.com
Min-SE:  1800
Cisco-Guid: 1623638144-0000065536-0000000080-0051685568
CSeq: 101 INVITE
Timestamp: 1397425294
Contact: <sip:XXXXXXXXXX@domain.com>
Expires: 180
Max-Forwards: 69
Cisco-Gcid: 37FEE753-C28B-11E3-8832-E452E7A949D0
P-Preferred-Identity: "Zach Bullough" <sip:XXXXXXXXXX@domain.com>
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 8376 7466 IN IP4 domain.com
s=SIP Call
c=IN IP4 domain.com
t=0 0
m=audio 18902 RTP/AVP 0 101 19
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Apr 13 21:41:34.934: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 10.0.0.50:5060;branch=z9hG4bK59E1187;rport=15245;received=65.128.160.150
To: <sip:1XXXXXXXXXX@sip.didlogic.net>;tag=b27e1a1d33761e85846fc98f5f3a7e58.eef9
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.didlogic.net", nonce="U0sFulNLBI487NoK3aQj+bLy5mdhpj2ZsnxLxYA=", qop="auth"
Server: kamailio (4.0.3 (x86_64/linux))
Content-Length: 0
Apr 13 21:41:34.938: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1XXXXXXXXXX@sip.didlogic.net:5060 SIP/2.0
From: "Zach Bullough" <sip:XXXXXXXXXX@10.0.0.50>;tag=1654EA40-97B
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Apr 13 21:41:34.942: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.0.50:5060;branch=z9hG4bK59FB7C
Min-SE:  1800
CSeq: 102 INVITE
Expires: 180
Proxy-Authorization: Digest username="32046",realm="sip.didlogic.net",uri="sip:1XXXXXXXXXX@sip.didlogic.net:5060",response="cb4e17ed3708ffe3958ea4d3f2e0cba1",nonce="U0sFulNLBI487NoK3aQj+bLy5mdhpj2ZsnxLxYA=",cnonce="D5251403",qop=auth,algorithm=md5,nc=00000001
Max-Forwards: 69
Content-Length: 274
v=0
s=SIP Call
c=IN IP4 domain.com
t=0 0
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Apr 13 21:41:35.438: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 13 Apr 2014 21:41:35 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1397425295
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
s=SIP Call
c=IN IP4 domain.com
t=0 0
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Apr 13 21:41:36.438: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 13 Apr 2014 21:41:36 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1397425296
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
s=SIP Call
c=IN IP4 domain.com
t=0 0
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Apr 13 21:41:38.438: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 13 Apr 2014 21:41:38 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1397425298
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
s=SIP Call
c=IN IP4 domain.com
t=0 0
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Apr 13 21:41:42.438: //1586/60C6C0800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 13 Apr 2014 21:41:42 GMT
Min-SE:  1800
CSeq: 102 INVITE
Timestamp: 1397425302
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
s=SIP Call
c=IN IP4 domain.com
t=0 0
c=IN IP4 domain.com
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Are you sure its matching the correct outgoing dial-peer ?
Because the session target configured under dial-peer 30 is chicago2.voip.ms and the call is going to sip.didlogic.net.
Manish
Ayodeji Okanlawon
We need a full picture. Please post the full debugs.
Please rate all useful posts
