SIP to SIP Info for Flashhook event on Cisco Unified Border Element (CUBE)
mrousseau
I've had an open case for a very long time with Cisco.
I purchased two CUBE's with the intent to make VoIP call transfers via hookflash.  These hookflashes are supported for FXS-SIP (via sip-ua hookflash-info command) and SIP-FXS (via DSAPP tcl script) scenarios but I've been told by Cisco support that anything listed for SIP-SIP hookflash transfers is not yet supported by the CUBE.
I was told it could be done via a custom tcl script but that is something not supported by tac and you will have to go to Cisco DevNet.
This is my first post in DevNet, but I hope to be in contact with some clever and generous individuals who could give me some of their time to help me resolve this issue.
I am running IOS 15.3(3)M1 or later on my CUBEs, I've done basic tclsh ping test scripts, but I'm not sure how to tackle producing a script that will constantly execute the pass-through of SIP INFO hookflash messages by the CUBE using a tcl script.
INFO message to be handled by the CUBE but the CUBE is rejecting it.  I attached a trace of the logs from the CUBE for more detail.
Received:
INFO sip:405153192439@192.168.33.251:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.33.103:5060;branch=z9hG4bK1694924683
From: <sip:911@192.168.33.103>;tag=89188638-6ba95ef0-ver1e13
To: <sip:405153192439@192.168.33.251>;tag=540038-1978
Call-ID: 1E52787-6E6C11E4-8032CD81-64C4D401@192.168.33.251
CSeq: 104 INFO
Max-Forwards: 70
User-Agent: Tangerine-oSIP-UA/1.06
Content-Type: application/broadsoft ;version=1.0
Content-Length:    17
event flashhook
I've also tried to allow unsupported messages to be passed-through the 2901 CUBE, but it did not seem to matter.
voice service voip
sip
pass-thru content unsupp
Finally, this is my first attempt at using DevNet, I hope to become a contributing member asap.
Thanks for you time.
George Thomas
Level 10
Level 10
I think you need to post here: https://communities.cisco.com/community/developer
Please rate useful posts.
