08-11-2015 07:58 AM - edited 03-17-2019 03:57 AM
hello
i have strange issue related to transfer betweeb sip n sccp
let me explain exactly what is happening
PSTN --- CME --- Ext 100 [SCCP Phone Operator] .... if call coming directly from PSTN she can transfer the call to sip phones
Branch PABX (non cisco) ---- MPLS Cloud ---- CME --- SIP Phone
if from branch a guy dialed ext, other person answered, trying to transfer , press the transfer key, dial the extension both calls remain in hold & no voice and unable to resume also, any one can recommend anything
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 200
ip source-address 10.10.131.1 port 2000
service phone displayOnTime 08:00
service phone displayIdleTimeout 00:03
service phone settingsAccess 1
service phone handsetWidebandEnable 1
service phone handsetWidebandUIControl 0
service phone headsetWidebandUIControl 0
service phone g722CodecSupport 2
service phone displayOnWhenIncomingCall 1
service phone backlightIdleTimeout 00:03
service phone backlightOnTime 08:00
service phone displayOnDuration 10:00
service phone daysDisplayNotActive 6
service phone daysBacklightNotActive 6
service phone backlightOnDuration 11:00
service phone ehookEnable 1
service phone headsetWidebandEnable 0
service phone webAccess 0
service directed-pickup gpickup
timeouts interdigit 7
timeouts ringing 60
timeouts transfer-recall 30
system message
url services http://10.10.131.2/voiceview/common/login.do
url authentication http://10.10.131.1/CCMCIP/authenticate.asp
cnf-file perphone
load 7916-24 B016-1-0-4-2.SBN
load 7945 SCCP45.9-4-2SR1-1S
load 7965 SCCP45.9-4-2SR1-1S
time-zone 31
date-format dd-mm-yy
voicemail 09
max-conferences 8 gain -6
call-park system application
call-forward pattern .T
call-forward system redirecting-expanded
moh enable-g711 "flash:/Phones/music_on_hold.au"
multicast moh 239.10.16.16 port 2000
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 4.....
transfer-pattern 1..
secondary-dialtone 9
login timeout 3
after-hours block pattern 1 900.T
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 600 min 60
voice register global
mode cme
source-address 10.10.131.1 port 5060
max-dn 200
max-pool 42
load 7821 sip78xx.10-1-1SR1-4
authenticate register
authenticate realm all
timezone 31
date-format D/M/Y
mwi stutter
mwi reg-e164
no dst auto-adjust
voicemail 09
url directory http://10.10.131.1/localdirectory
tftp-path flash:
file text
create profile sync 0014401022675423
ntp-server 172.17.0.101 mode unicast
camera
video
MC-Nuwaidrat-CME#sh ip interface brief
Embedded-Service-Engine0/0 unassigned YES NVRAM initializing down
GigabitEthernet0/0 192.168.131.40 YES NVRAM up up
ISM0/0 10.10.131.1 YES unset up up
GigabitEthernet0/1 10.10.131.1 YES NVRAM up up
ISM0/1 unassigned YES unset up up
Serial0/0/0:0 unassigned YES unset down down
Serial0/0/0:1 unassigned YES unset down down
Serial0/0/0:2 unassigned YES unset down down
Serial0/0/0:3 unassigned YES unset down down
Serial0/0/0:4 unassigned YES unset down down
Serial0/0/0:5 unassigned YES unset down down
Serial0/0/0:6 unassigned YES unset down down
Serial0/0/0:7 unassigned YES unset down down
Serial0/0/0:8 unassigned YES unset down down
Serial0/0/0:9 unassigned YES unset down down
Serial0/0/0:15 unassigned YES unset up up
Vlan1 unassigned YES unset up up
08-11-2015 12:54 PM
does anyone face the same issue before ??
08-12-2015 03:17 AM
Try to change the transfer type to consultive. Also, what is the connection to the PABX?
