Beginner
SIP TO SIP n SCCP to SIP Transfer Problem in CME
hello
i have strange issue related to transfer betweeb sip n sccp
let me explain exactly what is happening
PSTN --- CME --- Ext 100 [SCCP Phone Operator]  .... if call coming directly from PSTN she can transfer the call to sip phones
Branch PABX (non cisco) ---- MPLS Cloud ---- CME --- SIP Phone
if from branch a guy dialed ext, other person answered, trying to transfer , press the transfer key, dial the extension both calls remain in hold & no voice and unable to resume also, any one can recommend anything
telephony-service
 no auto-reg-ephone
 max-ephones 42
 max-dn 200
 ip source-address 10.10.131.1 port 2000
 service phone displayOnTime 08:00
 service phone displayIdleTimeout 00:03
 service phone settingsAccess 1
 service phone handsetWidebandEnable 1
 service phone handsetWidebandUIControl 0
 service phone headsetWidebandUIControl 0
 service phone g722CodecSupport 2
 service phone displayOnWhenIncomingCall 1
 service phone backlightIdleTimeout 00:03
 service phone backlightOnTime 08:00
 service phone displayOnDuration 10:00
 service phone daysDisplayNotActive 6
 service phone daysBacklightNotActive 6
 service phone backlightOnDuration 11:00
 service phone ehookEnable 1
 service phone headsetWidebandEnable 0
 service phone webAccess 0
 service directed-pickup gpickup
 timeouts interdigit 7
 timeouts ringing 60
 timeouts transfer-recall 30
 system message
 url services http://10.10.131.2/voiceview/common/login.do
 url authentication http://10.10.131.1/CCMCIP/authenticate.asp
 cnf-file perphone
 load 7916-24 B016-1-0-4-2.SBN
 load 7945 SCCP45.9-4-2SR1-1S
 load 7965 SCCP45.9-4-2SR1-1S
 time-zone 31
 date-format dd-mm-yy
 voicemail 09
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh enable-g711 "flash:/Phones/music_on_hold.au"
 multicast moh 239.10.16.16 port 2000
  dn-webedit
 time-webedit
 transfer-system full-blind
 transfer-pattern 9.T
 transfer-pattern .T
 transfer-pattern 4.....
 transfer-pattern 1..
 secondary-dialtone 9
 login timeout 3
 after-hours block pattern 1 900.T
 after-hours day Sun 00:00 23:59
 after-hours day Mon 00:00 23:59
 after-hours day Tue 00:00 23:59
 after-hours day Wed 00:00 23:59
 after-hours day Thu 00:00 23:59
 after-hours day Fri 00:00 23:59
 after-hours day Sat 00:00 23:59
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server expires max 600 min 60
voice register global
 mode  cme
 source-address 10.10.131.1 port 5060
 max-dn 200
 max-pool 42
 load 7821 sip78xx.10-1-1SR1-4
 authenticate register
 authenticate realm all
 timezone 31
 date-format D/M/Y
 mwi stutter
 mwi reg-e164
 no dst auto-adjust
 voicemail 09
 url directory http://10.10.131.1/localdirectory
 tftp-path flash:
 file text
 create profile sync 0014401022675423
 ntp-server 172.17.0.101 mode unicast
 camera
 video
MC-Nuwaidrat-CME#sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  initializing          down
GigabitEthernet0/0         192.168.131.40  YES NVRAM  up                    up
ISM0/0                     10.10.131.1     YES unset  up                    up
GigabitEthernet0/1         10.10.131.1     YES NVRAM  up                    up
ISM0/1                     unassigned      YES unset  up                    up
Serial0/0/0:0              unassigned      YES unset  down                  down
Serial0/0/0:1              unassigned      YES unset  down                  down
Serial0/0/0:2              unassigned      YES unset  down                  down
Serial0/0/0:3              unassigned      YES unset  down                  down
Serial0/0/0:4              unassigned      YES unset  down                  down
Serial0/0/0:5              unassigned      YES unset  down                  down
Serial0/0/0:6              unassigned      YES unset  down                  down
Serial0/0/0:7              unassigned      YES unset  down                  down
Serial0/0/0:8              unassigned      YES unset  down                  down
Serial0/0/0:9              unassigned      YES unset  down                  down
Serial0/0/0:15             unassigned      YES unset  up                    up
Vlan1                      unassigned      YES unset  up                    up
Everyone's tags (3)
2 REPLIES 2
Beginner
does anyone face the same
does anyone face the same issue before ??
VIP Advisor
Hi, Try to change the
Try to change the transfer type to consultive. Also, what is the connection to the PABX?
Content for Community-Ad
August's Community Spotlight Awards
