01-31-2017 10:20 AM - edited 03-17-2019 09:21 AM
We have a 2951 running CME and a SIP trunk connecting to Avaya. When calling from CME to Avaya the call goes through with no issue but when someone on the Avaya system tries to call into the CME the call fails. I have run some debugs but I cannot even see the call coming in at all. Does anyone have some suggested debugs that might show an error on the CME side?
Solved! Go to Solution.
01-31-2017 11:59 AM
I do not think there is an error on CME side ,we should atleast see the call hitting CME.
Please check failed call logs from Avaya end and check network routing in both directions.
01-31-2017 10:44 AM
Please run debug ccsip messages and debug voip dialpeer .Also paste sh run from CME.
01-31-2017 11:05 AM
I ran to two debugs suggested and there was no output when dialing from Avaya into CME.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.01.31 11:46:51 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 36126 bytes
! Last configuration change at 10:17:54 MST Tue Jan 31 2017 by longview
! NVRAM config last updated at 22:13:31 MST Wed Jan 25 2017 by longview
version 15.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname *********
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-1.T1.bin
boot-end-marker
aqm-register-fnf
logging buffered 51200
no logging console
aaa session-id common
clock timezone MST -7 0
clock summer-time MDT recurring
no ip source-route
ip cef
no ipv6 cef
voice-card 0
dsp services dspfarm
no voice hunt unassigned-number
no voice hunt invalid-number
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.182.39.7 255.255.255.255
no ip address trusted authenticate
dtmf-interworking rtp-nte
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0.12
bind media source-interface GigabitEthernet0/0.12
header-passing
registrar server expires max 3600 min 120
privacy-policy passthru
sip-profiles 1000
voice class codec 1
codec preference 1 g711ulaw
voice class sip-profiles 1000
request INVITE sip-header Allow-Header modify " UPDATE, " " "
request REINVITE sip-header Allow-Header modify " UPDATE, " " "
response 200 sip-header Allow-Header modify " UPDATE, " " "
response 180 sip-header Allow-Header modify " UPDATE, " " "
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 100 200 100 200 200
voice hunt-group 1 parallel
list 4100,4101,4102,4103,4104,4105,4106,4107,4108,4109,4110,4111,4112,4113,4114,4115,4116,4117,4118,4119,4120,4121
pilot 8003
voice hunt-group 2 parallel
pilot 8004
voice translation-rule 1
rule 1 /^\(4...\)/ /******\1/
voice translation-rule 2
rule 1 // //
voice translation-rule 3
rule 1 /^\(4...\)/ /**********/
voice translation-rule 4
voice translation-rule 5
rule 1 /^911/ /911/
rule 2 /^9\(.*\)/ /\1/
voice translation-profile OUTPSTN
translate calling 1
translate called 2
voice translation-profile PSTN911a
translate calling 3
translate called 5
voice translation-profile PSTN911b
translate calling 4
translate called 5
license udi pid CISCO2921/K9 sn FGL1734119M
license accept end user agreement
hw-module ism 0
hw-module pvdm 0/0
hw-module sm 1
file privilege 0
vtp domain FTS-IOKEARL01-01
vtp mode transparent
redundancy
vlan 20
ip tcp path-mtu-discovery
ip ssh time-out 60
ip ssh version 2
interface Loopback0
ip address 172.31.255.57 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 0
interface Embedded-Service-Engine0/0
no ip address
shutdown
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description TrustedDesktop 172.23.216.0/24
encapsulation dot1Q 10
ip address 172.23.216.1 255.255.255.0
ip helper-address 172.23.218.10
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1300
ip ospf 1 area 172.23.216.0
interface GigabitEthernet0/0.11
description Printers 172.23.217.0/24
encapsulation dot1Q 11
ip address 172.23.217.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
description Voice 172.23.219.0/24
encapsulation dot1Q 12
ip address 172.27.19.1 255.255.255.0 secondary
ip address 172.23.219.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface GigabitEthernet0/0.20
description Server 172.23.218.0/24
encapsulation dot1Q 20
ip address 172.27.18.1 255.255.255.0 secondary
ip address 172.23.218.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface GigabitEthernet0/0.903
description Management 10.63.136.0/24
encapsulation dot1Q 903
ip address 10.63.136.1 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
interface ISM0/0
ip unnumbered Loopback0
service-module ip address 172.31.255.58 255.255.255.252
!Application: CUE Running on ISM
service-module ip default-gateway 172.31.255.57
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
logging source-interface Loopback0
logging host 10.182.15.20
route-map NAT_RMAP permit 10
match ip address NAT_ACL
snmp-server group NetMgmtGroupROPriv v3 priv read NetMgmtView access 18
snmp-server group NetMgmtGroupRWPriv v3 priv read NetMgmtView write NetMgmtView access 18
snmp-server view NetMgmtView iso excluded
snmp-server view NetMgmtView internet included
snmp-server trap-source Loopback0
snmp-server chassis-id FTS-IOKEARL01-RTR01
snmp-server host 10.182.15.20 version 2c wbWJOhHr71YJsQ
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:music-on-hold.au
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:SCCP894x.9-2-2-0.bin1.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin2.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin3.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin4.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin5.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin6.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin7.sgn
tftp-server flash:SCCP894x.9-2-2-0.bin8.sgn
tftp-server flash:SCCP894x.9-2-2-0.loads
tacacs-server host 10.182.15.10 key 7 03290C0A250B2F475A110B310147292934
tacacs-server directed-request
access-list 18 remark NetMgmt SNMP ACL
access-list 18 permit 10.182.15.20
access-list 18 deny any
control-plane
voice-port 0/0/0
translation-profile outgoing PSTN911a
supervisory disconnect anytone
no battery-reversal
cptone CA
connection plar opx **********
bearer-cap Speech
caller-id enable
voice-port 0/0/1
translation-profile outgoing PSTN911b
no battery-reversal
cptone CA
bearer-cap Speech
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.12
sccp ccm 172.27.19.1 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.12
associate ccm 1 priority 1
associate profile 1 register IO-KearlConf
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
dial-peer voice 4000 voip
translation-profile outgoing OUTPSTN
preference 1
destination-pattern 9.T
session protocol sipv2
session target ipv4:10.182.39.7
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
fax-relay ecm disable
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 1000 voip
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4001 voip
preference 1
destination-pattern .T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5000 voip
description SIP dial peer to CUE
destination-pattern 4122
b2bua
session target ipv4:172.31.255.58
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 4002 voip
destination-pattern 24..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4003 voip
destination-pattern 25..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4004 voip
destination-pattern 37..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 4005 voip
destination-pattern 6622
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 100 pots
description 911 Outbound Dial-Peer
destination-pattern 911
progress_ind setup enable 3
progress_ind progress enable 8
no digit-strip
port 0/0/0
dial-peer voice 101 pots
destination-pattern 9911
port 0/0/0
forward-digits 3
dial-peer voice 1 pots
direct-inward-dial
dial-peer voice 200 pots
no digit-strip
port 0/0/1
dial-peer voice 201 pots
port 0/0/1
forward-digits 3
dial-peer voice 102 pots
description IO-Kearl emergency number
preference 2
destination-pattern 9**********$
no digit-strip
port 0/0/0
forward-digits 10
dial-peer voice 103 pots
preference 3
no digit-strip
port 0/0/1
forward-digits 10
dial-peer voice 4006 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 104 pots
description PSTN calls via analog
preference 2
no digit-strip
port 0/0/0
dial-peer voice 105 pots
preference 3
no digit-strip
port 0/0/1
presence
presence call-list
max-subscription 150
allow subscribe
sip-ua
mwi-server ipv4:172.31.255.58 expires 3600 port 5060 transport udp unsolicited
presence enable
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 2
sdspfarm tag 1 IO-KearlConf
conference hardware
conference transfer-pattern
xml user admin password ********** 15
max-ephones 25
max-dn 50
ip source-address 172.27.19.1 port 2000
max-redirect 8
service phone settingsAccess 1
service directed-pickup gpickup
system message FTS Phone
url authentication http://172.27.19.1/CCMCIP/authenticate.do ExtMob Password
cnf-file location flash:
load 7937 apps37sccp.1-4-4-0.bin
load 8945 SCCP894x.9-2-2-0
time-zone 6
voicemail 4122
max-conferences 8 gain -6
call-forward system redirecting-expanded
moh enable-g711 "flash:music-on-hold.au"
web admin system name admin password ********
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Sep 22 2013 20:40:58
ephone-dn-template 1
call-waiting ring
call-forward busy 4122
call-forward noan 4122 timeout 15
mwi sip
pickup-group 1
allow watch
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Newcall Cfwdall Redial Pickup
softkeys seized Meetme Cfwdall Endcall Gpickup
softkeys alerting Endcall
softkeys connected Hold Trnsfer Confrn Endcall
softkeys ringing Answer Dnd
max-calls-per-button 4
busy-trigger-per-button 2
ephone-dn 1 octo-line
number 4123
pickup-group 1
label Boardroom - 4123
description 5872934123
name Boardroom
ephone-dn 2 dual-line
number 4120
description 4120-Project Supervisors
name 4120-Project Supervisors
hold-alert 30 originator
ephone-dn 11 dual-line
number A0001
conference ad-hoc
no huntstop
ephone-dn 12 dual-line
number A0001
conference ad-hoc
no huntstop
ephone-dn 13 dual-line
number A0001
conference ad-hoc
no huntstop
ephone-dn 14 dual-line
number A0001
conference ad-hoc
no huntstop
ephone-dn 15 dual-line
number A0002
conference ad-hoc
no huntstop
ephone-dn 16 dual-line
number A0002
conference ad-hoc
no huntstop
ephone-dn 17 dual-line
number A0002
conference ad-hoc
no huntstop
ephone-dn 18 dual-line
number A0002
conference ad-hoc
no huntstop
ephone-dn 19 dual-line
number A0003
conference ad-hoc
no huntstop
ephone-dn 20 dual-line
number A0003
conference ad-hoc
no huntstop
ephone-dn 21 dual-line
number A0003
conference ad-hoc
no huntstop
ephone-dn 22 dual-line
number A0003
conference ad-hoc
no huntstop
ephone-dn 23
number 8001
mwi on
ephone-dn 24
number 8002
mwi off
ephone-dn 25 octo-line
number 4124 no-reg primary
conference meetme
ephone-dn 26 dual-line
number 7807626744
call-forward all 8003
ephone-dn 27 dual-line
number 7807626745
call-forward all 8004
ephone-dn 29 dual-line
number 4121
label 4121-Spare
description 4121-Spare
name 4121-Spare
ephone-dn 30 dual-line
number 4100
pickup-group 1
label KEARL EX.MGR-4100
description KEARL EX.MGR 4100
name KEARL EX.MGR
mobility
snr calling-number local
snr 917802157140 delay 5 timeout 15 cfwd-noan 4122
snr ring-stop
snr answer-too-soon 2
snr mode virtual
call-forward noan 4122 timeout 25
ephone-dn 31 dual-line
number 4101
pickup-group 1
label 4101
description 4101
name 4101
mobility
snr 917807425363 delay 5 timeout 15 cfwd-noan 4122
snr ring-stop
snr mode virtual
ephone-dn 32 dual-line
number 4102
pickup-group 1
label 4102-EHT Supervisors
description EHT Supervisors 4102
name EHT Supervisors
ephone-dn 33 dual-line
number 4103
pickup-group 1
label 4103-E/I Superintendents
description E/I Superintendents 4103
name E/I Superintendents
ephone-dn 34 dual-line
number 4104
pickup-group 1
label 4104-SW Superintendents
description SW Superintendents 4104
name SW Superintendents
ephone-dn 35 dual-line
number 4105
pickup-group 1
label 4105-Tool Crib
description Tool Crib 4105
name Tool Crib
ephone-dn 36 dual-line
number 4106
label 4106-Safety 2
description Safety 2 4106
name Safety 2
ephone-dn 37 dual-line
number 4107
pickup-group 1
label 4107-Payroll
description Payroll 4107
name Payroll
ephone-dn 38 dual-line
number 4108
pickup-group 1
label 4108-Safety Admin
description Safety Admin 4108
name Safety Admin
ephone-dn 39 dual-line
number 4109
pickup-group 1
label 4109-Ut/Fr Planners
description Utilities/Froth 4109
name Utilities/Froth Planners
ephone-dn 40 dual-line
number 4110
pickup-group 1
label 4110-Planners
description OPP/Extraction/RWI/Tailings/PD 4110
name OPP/Extraction/RWI/Tailings/PD
ephone-dn 41 dual-line
number 4111
pickup-group 1
label 4111-Procurement
description Procurement Team 4111
name Procurement Team
ephone-dn 42 dual-line
number 4112
pickup-group 1
label 4112 -HVAC Supervisors
description HVAC Supervisors 4112
name HVAC Supervisors
ephone-dn 43 dual-line
number 4113
pickup-group 1
label 4113-Production
description Production Projects 4113
name Production Projects
ephone-dn 44 dual-line
number 4114
pickup-group 1
label 4114-Finance
description Finance 4114
name Finance
ephone-dn 45 dual-line
number 4115
pickup-group 1
label 4115-FTH/UTL Super
description FTH/UTL Supervisor - 4115
name FTH/UTL Supervisor
ephone-dn 46 dual-line
number 4116
pickup-group 1
label 4116-SpareExt
description SpareExtension 4116
name SpareExtension
ephone-dn 47 dual-line
number 4117
pickup-group 1
label 4117-SpareExt
description SpareExtension 4117
name SpareExtension
ephone-dn 48 dual-line
number 4118
pickup-group 1
label 4118-SpareExt
description SpareExtension 4118
name SpareExtension
ephone-dn 49 dual-line
number 4119
pickup-group 1
label 4119-SpareExt
description SpareExtension 4119
name SpareExtension
ephone 1
device-security-mode none
mac-address 0004.F2F7.34E3
ephone-template 1
type 7937
button 1:1
ephone 2
mac-address DCA5.F43E.C409
ephone-template 1
username "ph4119" password 12345
type 8945
button 1:49
ephone 3
mac-address DCA5.F43E.C513
ephone-template 1
username "name1" password 12345
fastdial 1 3775 name ivan
type 8945
button 1:30
ephone 4
mac-address DCA5.F43E.BEC9
ephone-template 1
username "name2" password 12345
type 8945
button 1:31
ephone 5
mac-address DCA5.F43E.C0AD
ephone-template 1
username "ph4102" password 12345
fastdial 1 97807628986 name The Gareth
type 8945
button 1:32
ephone 6
mac-address DCA5.F43E.C089
ephone-template 1
username "ph4103" password 12345
type 8945
button 1:33
ephone 7
mac-address DCA5.F43E.C13B
ephone-template 1
username "ph4104" password 12345
type 8945
button 1:34
ephone 8
mac-address DCA5.F43E.C141
ephone-template 1
username "ph4105" password 12345
type 8945
button 1:35
ephone 9
mac-address DCA5.F43E.BF9B
ephone-template 1
username "ph4106" password 12345
type 8945
button 1:36
ephone 10
mac-address DCA5.F43E.C133
ephone-template 1
username "payroll" password 12345
type 8945
button 1:37
ephone 11
mac-address DCA5.F43E.BEBD
ephone-template 1
username "ph4108" password 12345
type 8945
button 1:38
ephone 12
mac-address DCA5.F43E.BEED
ephone-template 1
username "ph4109" password 12345
type 8945
button 1:39
ephone 13
mac-address DCA5.F43E.B925
ephone-template 1
username "ph4110" password 12345
type 8945
button 1:40
ephone 14
mac-address DCA5.F43E.C553
ephone-template 1
username "ph4111" password 12345
type 8945
button 1:41
ephone 15
mac-address DCA5.F43E.B9BD
ephone-template 1
username "ph4112" password 12345
type 8945
button 1:42
ephone 16
mac-address DCA5.F43E.C105
ephone-template 1
username "ph4113" password 12345
type 8945
button 1:43
ephone 17
mac-address DCA5.F43E.C11B
ephone-template 1
username "ph4114" password 12345
type 8945
button 1:44
ephone 18
mac-address DCA5.F43E.BF39
ephone-template 1
username "ph4115" password 12345
type 8945
button 1:45
pin 12345
ephone 19
mac-address DCA5.F43E.C12D
ephone-template 1
username "ph4116" password 12345
type 8945
button 1:46
ephone 20
mac-address DCA5.F43E.BFEF
ephone-template 1
username "ph4117" password 12345
type 8945
button 1:47
ephone 21
mac-address DCA5.F43E.C135
ephone-template 1
username "ph4118" password 12345
type 8945
button 1:48
ephone 22
mac-address 8478.ACED.6C47
button 1:2
line con 0
exec-timeout 15 0
authorization exec CONSOLE
logging synchronous
login authentication CONSOLE
length 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
speed 9600
flowcontrol software
line 131
login authentication TTY
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 15 0
privilege level 0
authorization exec VTY
logging synchronous
login authentication VTY
length 0
notify
transport input ssh
line vty 5 15
exec-timeout 15 0
privilege level 0
logging synchronous
length 0
notify
transport input ssh
scheduler allocate 20000 1000
ntp source Loopback0
ntp server 10.182.1.22 prefer source Loopback0
end
01-31-2017 11:59 AM
01-31-2017 12:22 PM
Was finally able to get the Avaya guy to find the error. Thanks for the help!!
01-10-2018 11:44 AM
02-28-2018 09:04 AM
Sorry for the late reply. I am unsure what was done on the Avaya side to resolve this issue as I have never done any work on them. We had our Avaya consultant come in and resolve the issue nothing needed to change on the Cisco side.
