1000
Highlighted
Contributor
SIP Trunk & MTP, MOH or outgoing calls.
I have a "chatch 22".
Scenario:
CUCM 12.0 and UCCX 11.6
Incoming calls don't hear MOH, for the UCCX queue time, unless I enable "Media Termination Point Required".
When I enable the use of MTP, all outgoing calls fail with busy.
The PSTN are trough a Interoute SIP trunk, terminated on a Cisco CUBE-SP ASR1004.
Just floating this to hear if anyone have encountered a ,similar problem.
MOH works fine, when I put an external on hold from a IP-phone(8851).
fortvald
6 REPLIES 6
Highlighted
Collaborator
Hi there
Could you please share the debugs from the gateway. Also try the following
1. Disable Early Offer support for voice and video calls under SIP Profile
2. Reset the SIP Trunk
if that doesn't work
1. Change to Mandatory (Insert MTP if required)
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
NOTICE: This confidential e-mail message is only for the intended recipients. If you are not the intended recipient, be advised that disclosing, copying, distributing, or any other use of this message, is strictly prohibited. In such case, please destroy this message and notify the sender.
Highlighted
Setting was "disabled"
Change to "mandatory" doesn't change the behavoir.
Calls work, but no MOH when calls are queued on the UCCX.
fortvald
Highlighted
Hi there
For the MOH on queued calls can you check Call Control Group >> Network and User Audio source. Is that configured with a music on hold file or None?
Could you try adding the audio source on the Call Control Group and Update.
Also check the CTI ports as well and reset it.
Hope this Helps
Cheers
Rath!
Highlighted
Were you able to resolve this issue? We are experiencing the exact same issue.
Highlighted
Ajlal,
You have the MOH selected in the Call Control on UCCX? That should have resolved the previous issue that you posted on.
Jason
Highlighted
Yes, the MOH source is selected for both User and Network hold in the call control groups in UCCX. Still, no music is heard.
Content for Community-Ad
