SIP Trunk between Cluster CUCM and Asterisk
cristian.munoz
Level 4
Level 4
Hi All
I have a problem with a SIP Trunk between CUCM and Asterisk. In the capture, appears the Subscribers IP trying to connect to Asterisk. How to fix all trafic (SIP+RTP)  only the Publishers IP (that have configured the SIP Trunk) have it.
Any Idea.
TIA
Cristian
mkchandak
To get this working, you need to use MTP and that would force the call through the publisher. Though sice you want to use the Publisher, it would be software MTP and therefore codec would need to be G711.
HTHs....
