SIP trunk configuration help
Deepak Kumar
My VOIP engineer is on holiday and I stuck in a SIP trunk configuration. Please help me to complete SIP trunk configuration.
I have some doubt on VLAN ID which is given by the ISP. I am using Cisco 4431 as voice gateway.InShot_20190422_084832612.jpg
Cisco router 4431.
Sorry I am posting through the mobile browser so ignore any typo.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
HARIS_HUSSAIN
VLAN ID will not be used to configure SIP Trunk, So you can ignore the same
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
George Sotiropoulos
The clarification of Vlan ID is not required for configuring a SIP trunk with the Provider. Do you need assistance on the 4331 CUBE configuration? You can find the following link (amogst others) useful:
https://ucpros.net/cube-configuration-part-1/
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
