05-05-2017 10:04 AM - edited 03-17-2019 10:15 AM
We currently have a sites using Alcatel PBX`s (Only support E1 connections) .
Our service provider only offer SIP trunks, but we don't want change the PBX.
What we are looking at doing is connect the SIP trunk (30 channel) to a C2901-CME-SRST/K9_SIP10 and transform to a E1 PRI to connect it the PBX.
The questions ares:
1. Need other tipe of licensing? (Because its SIP10, but we seen configurations with more channels than licensing)
2. The cube licensing its mandatory to configure a SIP trunk?
3. The provider brings a SBC, we need a CUBE?
4. Something to keep in mind for prosible problems, misfunctionality or risks?
very thankful for your help
Solved! Go to Solution.
05-06-2017 08:03 AM
1 and 2: Yes you need to own CUBE licensing to connect via SIP to carrier. The CUBE licenses are RTU paper licenses that do not get applied to anything at this point.
3: Your CME can serve as CUBE, so no need for separate router
4: Important things to consider: faxing protocol (T38 vs. passthrough), DTMF method, default codec (may require transcoders depending on call flows).
05-06-2017 08:03 AM
05-25-2017 02:02 PM
Thanks Chris.
One more question: our provider SIP trunk is in G.711A, if the PRI Trunk is G711A; In that order, the DSP resources aren't needed?
05-25-2017 02:17 PM
You should not need any DSPs as long as the codec profile includes the codecs and end devices can understand it.
05-08-2017 07:16 PM
Jesus,
you might also want to considering if you are going to use media flow through or flow around on your CUBE (if you have a choice at all). and how many DSP's you need to potential transcoding
Please rate if useful.
