ā05-01-2018 06:37 PM - edited ā03-17-2019 12:43 PM
Hi Cisco Techs,
Please let me know if posted in wrong forum
ISP supplied router has necessary details under VOIP and SIP tabs to connect to them for VOIP calls.
Do I need to configure CUBE as part of CUCM 7.1.2 to connect calls then?
Thanks again..
Solved! Go to Solution.
ā05-05-2018 12:59 AM
try this:
lots of info, but does contain all you need. dont worry about TLS for the moment. make it as simple as possible.
ā05-01-2018 07:11 PM
John,
you dont necissarily need a cube. if your ISP provide router supports SIP, you should be able to point your cucm trunk to that. there is no requirement from cisco that a cucm sip trunk needs to point to a CUBE, it could also point to a non-cisco product. I hope that answers your question
ā05-01-2018 10:14 PM
Thanks Dennis for the quick response. Is there a link some guiding how to point trunk to ISP router device please?
try this:
