Hello - looking for some help on a SIP trunk configuration between the 2 devices. Currently we are running CUCM 9.1 with Avaya Session Manager 6.3. We are having issues with the call completing from the CS 1000 to the CUCM. Below are the session traces from both the Session Manager and CUCM. The CS1000 currently has 4 digit extensions and the CUCM has 7 digit extensions. We translate the number in the Session Manager to send the 7 digits. If you could lead in the right direction I would appreciate it. WOuld this have something to do with the context coming out of Session Manager? It looks like CDP.UDP and then only the 4 digits and the CUCM needs the 7.
Session Manager trace:
mil-ss-01 CUCM 9
SM100 10.101.2.75 10.174.2.75
13:04:53.730 |<--OPTIONS-| | | | | (1) sip:10.5.1.30
13:04:53.731 |--200 OK-->| | | | | (1) 200 OK (OPTIONS)
13:04:53,734 | Request Adaptation | Adapter: mil-ss-01
13:04:56.183 |--INVITE-->| | | | | (2) T:7317;phone-context=cdp.udp F:anonymous@anonymous U:7317;phone-context=cdp.udp
13:04:56.184 |<--Trying--| | | | | (2) 100 Trying
13:04:56,185 | Remote host is trusted | Trusted
13:04:56,185 | Request Adaptation | Adapter: mil-ss-01
13:04:56,186 | Applied ingress Adaptation | P-Asserted-Identity=<sip:
>, Request-URI=sip:
, History-Info=<sip:
>;index=1, <sip:
>;index=1.1
13:04:56,186 | Originating Location found | Location: mil-cs1000m-01
13:04:56,186 | Try routing to determine if emergency call | Location: mil-cs1000m-01
13:04:56,186 | Request Dial Pattern route | for: sip:
13:04:56,186 | Dial Pattern route parameters | URI Domain: company.com Location: mil-cs1000m-01
13:04:56,186 | Trying Dial Pattern route | Domain: company.com Location: mil-cs1000m-01
13:04:56,186 | Dial Pattern found | for: 7317 Pattern: 7317
13:04:56,186 | Route Policy found | Pattern: 7317 RoutePolicyList: to_CUCM9
13:04:56,187 | Route found | for: sip:
SIPEntity: CUCM 9
13:04:56,187 | Entity Link found | SIPEntity: CUCM 9 EntityLink: mil-sessionmgr-01->TCP, biDirId=null, deny=false:5060
13:04:56,187 | Request Adaptation | Adapter: CUCM 9
13:04:56,188 | Applied egress Adaptation | NoAdaptationModuleExists=true, Request-URI=sip:7657317@10.5.131.12;routeinfo=0-0, Remote-Party-ID=<sip:
>;party=calling;screen=no;privacy=off,
13:04:56,188 | Routing SIP request | SipEntity: CUCM 9 EntityLink: mil-sessionmgr-01->TCP:5060
13:04:56,189 | No hostname resolution required | Routing to: sip:10.5.131.12;transport=tcp;lr;phase=terminating
13:04:56.191 | |--INVITE-->| | | | (2) T:7317;phone-context=cdp.udp F:anonymous@anonymous U:7657317 P:terminating
13:04:56.196 | |<--Trying--| | | | (2) 100 Trying
13:04:56.198 | |<--Not Fou-| | | | (2) 404 Not Found
13:04:56.199 | |----ACK--->| | | | (2) sip:7657317@10.5.131.12
13:04:56,200 | Request Adaptation | Adapter: CUCM 9
13:04:56,201 | Request Adaptation | Adapter: CUCM 9
13:04:56,201 | Request Adaptation | Adapter: mil-ss-01
13:04:56.202 |<--Not Fou-| | | | | (2) 404 Not Found
13:04:56.203 |----ACK--->| | | | | (2) sip:7317
13:05:07,597 | Remote host is not trusted | Host not trusted
13:05:07,597 | Originating Location found | Location: mil-cs1000m-01
13:05:12.657 | |<--------OPTIONS-------| | | (3) sip:10.5.2.51
13:05:12,659 | Remote host is not trusted | Host not trusted
13:05:12,659 | Originating Location found | Location: mil-cs1000m-01
13:05:12.660 | |--------200 OK-------->| | | (3) 200 OK (OPTIONS)
13:05:16.877 | |<--------------OPTIONS-------------| | (4) sip:10.5.2.51
13:05:16,879 | Remote host is trusted | Trusted
13:05:16,879 | Request Adaptation | Adapter: mil-ss-01
13:05:16,879 | Applied ingress Adaptation | P-Asserted-Identity=<sip:
13:05:16,879 | Originating Location found | Location: sas-cs1000e-01
13:05:16.880 | |--------------200 OK-------------->| | (4) 200 OK (OPTIONS)
13:05:24.463 | |<--------------------OPTIONS-------------------| (5) sip:10.5.2.51
13:05:24,465 | Remote host is not trusted | Host not trusted
13:05:24,465 | Originating Location found | Location: mil-cs1000m-01
13:05:24.466 | |--------------------200 OK-------------------->| (5) 200 OK (OPTIONS)
CUCM Trace Invite:
SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.5.2.51 on port 46314 index 6 with 3188 bytes:
[1179,NET]
INVITE sip:7657317@10.5.131.12 SIP/2.0
P-AV-Message-Id: 1_1
Route: <sip:10.5.131.12;transport=tcp;lr;phase=terminating>
History-Info: <sip:
>;index=1, <sip:
>;index=1.1
Remote-Party-ID: <sip:
Allow: INVITE, ACK, BYE, REGISTER, REFER, NOTIFY, CANCEL, PRACK, OPTIONS, INFO, SUBSCRIBE, UPDATE
Contact: <sip:00000000;phone-context=
:5060;maddr=10.5.1.30;transport=tcp;user=phone;gsid=68cac530-5d21-11e3-8b45-78e3b505dc88>
Alert-Info: <cid:
Supported: 100rel, x-nortel-sipvc, replaces
Via: SIP/2.0/TCP 10.5.2.51;branch=z9hG4bK138498682095974-AP;ft=3
Via: SIP/2.0/TCP 10.5.2.50:15060;rport=30522;ibmsid=local.1372169047609_2400498_2400522;branch=z9hG4bK138498682095974
Via: SIP/2.0/TCP 10.5.2.50:15060;rport;ibmsid=local.1372169047609_2400497_2400521;branch=z9hG4bK129750805377494
Via: SIP/2.0/TCP 10.5.2.51;branch=z9hG4bK-3fa2ea5-894636b6-7d11effb-AP;ft=19;received=10.5.2.51;rport=19140
Via: SIP/2.0/TCP 10.5.1.30:5060;branch=z9hG4bK-3fa2ea5-894636b6-7d11effb
Record-Route: <sip:22d074d4@10.5.2.51;transport=tcp;lr>
Record-Route: <sip:10.5.2.50:15060;transport=tcp;ibmsid=local.1372169047609_2400497_2400521;lr>
P-Charging-Vector: icid-value="68cac530-5d21-11e3-8b45-78e3b505dc88"
User-Agent: Nortel CS1000 SIP GW release_7.0 version_linux-6.50.00 AVAYA-SM-6.3.1.0.631004
P-Asserted-Identity: <sip:
lid;user=phone>;tag=ac493fe8-1e01050a-13c4-55013-3fa2ea5-2b7d5ad-3fa2ea5
To: <sip:7317;phone-context=
;user=phone>
Call-ID: abef5b48-1e01050a-13c4-55013-3fa2ea5-5d08551f-3fa2ea5
Max-Forwards: 66
CSeq: 1 INVITE
Content-Type: multipart/mixed;boundary=unique-boundary-1
Content-Length: 1063
Av-Global-Session-ID: 68cac530-5d21-11e3-8b45-78e3b505dc88
P-Location: SM;origlocname="mil-cs1000m-01";origsiglocname="mil-cs1000m-01";origmedialocname="mil-cs1000m-01";termlocname="Cisco BE6K";termsiglocname="Cisco BE6K";smaccounting="true"
--unique-boundary-1
Content-Type:
/sdp
SDP Message
v=0
o=- 746 1 IN IP4 10.5.1.30
s=-
c=IN IP4 10.5.1.36
t=0 0
m=audio 5234 RTP/AVP 18 0 8 101 111
c=IN IP4 10.5.1.36
a=tcap:1 RTP/SAVP
a=crypto:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
a=pcfg:1 t=1
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:111 X-nt-inforeq/8000
a=ptime:20
a=sendrecv
--unique-boundary-1
Content-Type: application/x-nt-mcdn-frag-hex;version=linux-6.50.00;base=x2611
Content-Disposition: signal;handling=optional
0500bc05
0107130081900000a200
09090f00e9a4830001004000
1315070011fa0f00a10d02010102020100cc040000c56000
1e0403008183
4a1c0100180001001a011404000067353505000004000000000048710000
--unique-boundary-1
Content-Type: application/x-nt-epid-frag-hex;version=linux-6.50.00;base=x2611
011201
3c:4a:92:f4:84:f4
--unique-boundary-1--
CUCM Trying Message:
SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.5.2.51 on port 46314 index 6
[1180,NET]
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.5.2.51;branch=z9hG4bK138498682095974-AP;ft=3,SIP/2.0/TCP 10.5.2.50:15060;rport=30522;ibmsid=local.1372169047609_2400498_2400522;branch=z9hG4bK138498682095974,SIP/2.0/TCP 10.5.2.50:15060;rport;ibmsid=local.1372169047609_2400497_2400521;branch=z9hG4bK129750805377494,SIP/2.0/TCP 10.5.2.51;branch=z9hG4bK-3fa2ea5-894636b6-7d11effb-AP;ft=19;received=10.5.2.51;rport=19140,SIP/2.0/TCP 10.5.1.30:5060;branch=z9hG4bK-3fa2ea5-894636b6-7d11effb
;user=phone>
Date: Wed, 04 Dec 2013 19:12:41 GMT
CSeq: 1 INVITE
Allow-Events: presence
Content-Length: 0
[1181,NET]
SIP/2.0 404 Not Found
;user=phone>;tag=580~35abe322-3212-479c-8a2c-ab75ead590d5-21575914
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.5.2.51 on port 46314 index 6 with 623 bytes:
[1182,NET]
ACK sip:7657317@10.5.131.12 SIP/2.0
CSeq: 1 ACK
Max-Forwards: 66
Content-Length: 0
[1180,NET]
SIP/2.0 100 Trying
;user=phone>
CSeq: 1 INVITE
Content-Length: 0
CUCM not found message:
[1181,NET]
CSeq: 1 INVITE
Content-Length: 0
CUCM ACK message:
[1182,NET]
CSeq: 1 ACK
Max-Forwards: 66
Content-Length: 0
Thanks.
Hello Ed,
could you please provide the complete CCM trace file? it seems soemthing wrong with the sip messages you posted.
>> Invite header has 7 digits & To filed has 4 digit
SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.5.2.51 on port 46314 index 6 with 3188 bytes: [1179,NET]
To: <>7317;phone-context=cdp.udp@company.com;user=phone>>
--> the '404 Not Found' message indicates no route error.
--> Perhaps, you can try receive the 4 digit from avaya & translate it in CUCM itself and then route to correct destination.
--> You can also crosscheck the 'Inbound call CSS'
--> Please make another test call & collect the complete ccm traces
Hi Ed,
Please provide the complete CCM traces along with the Called and the Calling number.
Jagpreet
Yes, you need to upload the complete ccm trace files, collected using RTMT.
Files have been uploaded sorry for the delay.
Hello Ed,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
this is the URL guide on how to collect the complete CCM trace files. Please ensure you have set the trace level to detailed n collect 'cisco callmanager' trace files for the nonworking call.
I will be setting up a trunk between a CUCM 9.1.2 and Session Manager 6.3 as well. Just curious - have you resolved this issue yet?
