12-22-2016 02:15 AM - edited 03-17-2019 09:01 AM
i has a SIP Trunk that is pointing to a third party Server that is a callcenter. The Server sends back the calls to Cisco Phones on the CUCM where the calls come from. We have only one peer on the other side.
When the peer server on the other side will be down, routing calls to this destination will not work any longer. How can we do a fallback?
I think about a fallback that sends the calls when the peer not available to a hunt group of Cisco Phones.
How can i manage this?
CUCM Version is 11.5.
Thanks a lot!
Christian
12-22-2016 02:26 AM
Once call has been discover its route and hits trunk/gateway, there is no provision to route the call back to the cluster.
- Vivek
12-22-2016 02:35 AM
There is no way? Means when the SIP Trunk is out of order, there is no fallback?
I know that i can setup a second server and point the SIP Trunk to two peers.
12-22-2016 02:42 AM
When CCM routes the call towards the RL/RG/Device, and call disconnects. CCM looks into the call release code/cause value and decides whether it should further hunt any other devices in RL to route the call. If it does have the device it will try to send the setup to next idle device. The service parameters in CCM dictates whether CCM should further route the call or stop hunting.
Clusterwide Parameters (Route Plan)
Stop Routing on Out of Bandwidth Flag Required Field False
Stop Routing on Unallocated Number Flag Required Field True
Stop Routing on User Busy Flag Required Field True
Stop Routing on Q.931 Disconnect Cause Code "Empty" -----You can defined the cause codes you want
CCM uses the above predefined parameters to take the decision. For eg: Call is released due to Out of BW (Cause code) , CCM looks into the parameters and will still hunt the other device to route the call, as it is set to "False".
So if the other side responds with a valid disconnect cause CUCm would be able to chose next Trunk.
Also you can enable option ping to query the far end is UP\DOWN, with 3rd party server i am not sure about the compatibility but it is worth a shot.
(Rate if it helps)
JB
12-22-2016 02:43 AM
What I meant is there is no way to route the call back to the cluster in such cases.
You always have an option to route the call to other peer outside your cluster when primary peer goes down.
- Vivek
12-22-2016 03:16 AM
I got a dirty solution. But i want to discuss this with any of you here.
From this discussion, i setup the solution for me and it works very well. But can it have some issues, that i did not think about? Loop or something else? The incoming CSS for the SIP Trunk to CUCM itself will have only access to the Hunt Pilot and nothing more.
https://supportforums.cisco.com/discussion/12310986/cucm-91-and-third-party-call-center-integration-over-sip-trunk
