02-26-2017 02:13 AM - edited 03-17-2019 09:39 AM
Dear,
I am new to Collab World.
My Scenario is
SIP Provider----(SIP Trunk)------VGateway---------(H323)--------CUCM10.5.2-----------------UCCX
i want to configure incoming call to route to UCCX Application.
Please help to know what step i do to configure this scenario.
the configuration that i do and debug that i have is like this:
*Feb 26 07:05:51.337: //-1/D76F9A3FB434/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x229D4580
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 2177622027
Called Number : xxxxx
Source IP Address (Sig ): 10.194.10.6
Destn SIP Req Addr:Port : 10.105.40.11:0
Destn SIP Resp Addr:Port : 10.105.40.11:5060
Destination Name : 10.105.40.11
Disconnect Cause (CC) : 100
Disconnect Cause (SIP) : 422
dial-peer voice 21 voip
session protocol sipv2
incoming called-number xxxxx
dtmf-relay rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 23 voip
destination-pattern xxxxx
session target ipv4:CUCM-PUB
codec g711ulaw
no vad
dial-peer voice 22 voip
session target ipv4:CUCM-SUB
codec g711ulaw
no vad
and i Configure a SIP Trunk from CUCM to Router with defaullt sip profile and security profile on CUCM 10.5.2
02-26-2017 07:24 AM
In call flow, you have mentioned h323 protocol b/w CUCM and VG...dial-peer pointing towards CUCM is using SIP protocol....I assume its using SIP protocol.
can you make a test call and collect logs of debug ccsip messages from SIP gateway
02-26-2017 08:09 AM
Make sure the Calling Search Space applied to the SIP trunk lists the partition assigned not only the CTI Route Point pointing to the application, but also your CTI ports used by CCX.
