08-17-2016 02:36 AM - edited 03-17-2019 07:51 AM
Hi, I testing a new SIP connection from Service Provider, my connection will be ITSP-SIP-VGRouter-SIP-CUCM, The issue I am facing is I'm unable to make call outside to ITSP from my Cisco Phone, however I can receive calls from ITSP. Please find the attached show run and debug from the router. Also please note that I'm unable to give the command 'mode border-element' under 'voice service voip', my IOS on the router is c3845-adventerprisek9_ivs-mz.151-4.M10.bin.
Solved! Go to Solution.
08-18-2016 02:13 AM
Iam connecting xlite directly with the SIP connection from ITSP, which is not touching the VG, so i can't do the debug with xlite, I am attaching another set of debug logs with Cisco phone, inbound from ITSP which is working and also outbound to ITSP which is not working, also attaching the VG-backup, please check.
08-17-2016 02:52 AM
can you enable following debugs
- debug ccsip message
- debug voice ccapi inout
and make a sample call.
Mohammed Noor
08-17-2016 03:32 AM
Hi MOhammed,
I have attached the debug logs already, please find the call details below
Calling number - 7067333 (Cisco IP Phone)
Called number - 026589000
08-17-2016 04:08 AM
Aug 17 08:37:24.871: //5784/BDBB6F800002/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
Via: SIP/2.0/UDP 10.1.1.7:5060;branch=z9hG4bK5032256
To: <sip:026589000@10.1.1.6>;tag=y6sqtpp7
Call-ID: 9504FA90-638C11E6-9750F86F-EF5B01D8@10.1.1.7
CSeq: 101 INVITE
Timestamp: 1471423012
Warning: 399 SoftX3000 "SS010000F00156L00373[0000] Cancel received from network"
Content-Length: 0
Telco issue.Contact your service provider.
08-17-2016 03:32 AM
I saw that the call is terminated by your operator.
Received: SIP/2.0 487 Request TerminatedVia: SIP/2.0/UDP 10.1.1.7:5060;branch=z9hG4bK5032256From: <sip:7067333@10.1.1.7>;tag=82474C8-2617To: <sip:026589000@10.1.1.6>;tag=y6sqtpp7Call-ID: 9504FA90-638C11E6-9750F86F-EF5B01D8@10.1.1.7CSeq: 101 INVITETimestamp: 1471423012Warning: 399 SoftX3000 "SS010000F00156L00373[0000] Cancel received from network"Content-Length: 0
You are sending G711ulaw/alaw to your operator. Can you confirm if they are happy with it. Also, open a ticket with them to find out why they are rejecting the call.
08-17-2016 04:13 AM
Thanks for the reply, do i need to enable 'mode border element' for this scenario and why I am not able to put this command even though the IOS supports (c3845-adventerprisek9_ivs-mz.151-4.M10.bin), also please note that I have a transcoder configured and registered with the CUCM, can this help to rectify our issue here ??
08-17-2016 04:25 AM
This command is supported in universal packets. You won't be able to put it in your image.
Don't worry about it. Its for licensing purpose but won't impact the functionality
08-17-2016 01:35 PM
When I configure SIP Xlite on my laptop and connect directly to the ITSP SIP interface, the xlite works fine inbound and outbound without any issue, TELCO technician just test in this way and says that there is no issue from their side, we have to correct this from our side :-(
08-17-2016 03:57 PM
Ris,
Enable debug ccsip message and debug voice ccapi inout and make two test, one using the SIP Xlite and the other one using the Cisco IP Phone so we can compare how devices are negotiating.
08-18-2016 02:13 AM
08-19-2016 11:31 PM
Ris,
What I can see from your output is that definitely the session is terminating from the side of your ITSP:
SIP/2.0 487 Request TerminatedVia: SIP/2.0/UDP 10.1.1.7:5060;branch=z9hG4bK7F311C9From: <sip:7067333@10.1.1.7>;tag=D552984-1959To: <sip:026589300@10.1.1.6>;tag=s837krtpCall-ID: 55044E52-645711E6-A60CF86F-EF5B01D8@10.1.1.7CSeq: 101 INVITETimestamp: 1471510093Warning: 399 SoftX3000 "SS010000F00156L00373[0000] Cancel received from network"Content-Length: 0 Aug 18 08:48:45.316: //9454/7E0D8A000002/CCAPI/cc_api_call_disconnected:
In addition we can see that unlike the other call working OK, here there are some t38 media exchanges in the ITSP side.
SIP/2.0 200 OKVia: SIP/2.0/UDP 10.1.1.6:5060;branch=z9hG4bKqnf6lv004gcgj4rmk2t1From: <sip:ping@10.1.1.6>;tag=49ce0a8af6b286d5217997b5e4f3dfdc0002vn1To: sip:ping@27067333.serviceprovider;tag=D55C1DC-7A6Date: Thu, 18 Aug 2016 08:48:52 GMTCall-ID: 3d187f50fa1379a90b6069a3785941890002vn1@10.1.1.6Server: Cisco-SIPGateway/IOS-12.xCSeq: 61807 OPTIONSAllow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTERAllow-Events: telephone-eventAccept: application/sdpSupported: 100rel,timer,resource-priority,replaces,sdp-anatContent-Type: application/sdpContent-Length: 450v=0o=CiscoSystemsSIP-GW-UserAgent 2035 6339 IN IP4 192.168.75.220s=SIP Callc=IN IP4 10.1.1.7t=0 0m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3c=IN IP4 10.1.1.7m=image 0 udptl t38c=IN IP4 10.1.1.7a=T38FaxVersion:0a=T38MaxBitRate:9600a=T38FaxFillBitRemoval:0a=T38FaxTranscodingMMR:0a=T38FaxTranscodingJBIG:0a=T38FaxRateManagement:transferredTCFa=T38FaxMaxBuffer:200a=T38FaxMaxDatagram:320a=T38FaxUdpEC:t38UDPRedundancy
Is this a new setup? Is faxing working OK?
To determine what exactly is failing we really need take a look at the logs from the ITSP side since it seems like some capabilities that you are sending are not of the liking of them.
Please test disabling the line:
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
from the voice service voip and configure it at dialpeer level (create a new dialpeer for faxing purposes) and leaving your dial-peer 104 as it is.
Enable debug ccapi inout and debug ccsip messages and attach the new debug output.
08-20-2016 02:24 AM
09-06-2016 04:47 PM
OK, Ris,
The same error but we are narrowing down the possible causes. Discarding media issues, I suspect that you are sending the incorrect user-id portion in identify headers so apply your voice-class sip profile this way:
First turn on the inbound SIP Profile feature as shown below:
voice service voip sip sip-profiles inbound
Apply your voice-class sip profile 100 to the incoming dial-peer voice 104 as shown below:
dial-peer voice 104 voip description ## CUCM Incoming Calls ##
voice-class sip profiles 100 inbound
It will look like this:
dial-peer voice 104 voip description ## CUCM Incoming Calls ## preference 1 session protocol sipv2 session target ipv4:192.168.75.202 session transport udp
voice-class sip profiles 100 inbound incoming called-number 8T voice-class codec 1 dtmf-relay rtp-nte no vad
Now make a test and please perfom the same procedure for retrieving logs and attach them. If it doesn't work then you will need to engage with your ITSP to ask for the correct user-id portion and alternatively ask for them to verify why they are disconnecting your call.
