sIP trunk inbound transfer to phone then forward to voicemail getting dead air
VON CLAWSON
Level 3
Level 3
Just moved from PRI to sip trunk on a 2851 with CME running IOS 12.4(24)T.  Inbound and outbound calls are working fine as well as direct calls to a phone that forwards to voicemail.  It is only when transferring to a phone and then forwarding to voicemail that I get the dead air. Found this bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtl79911/?referring_site...
But I already have codec g711ulaw on the inbound dial peer.  All call legs are g.711ulaw.  already have no supplementary-services moved-temporarily and no supplementary-services sip refer
Any advice would be greatly appreciated.
Please rate if this helps.
Vaijanath Sonvane
Hi Von,
Please make sure below routes are correct on the router. Especially the one highlighted in RED.
ip default-gateway 192.168.0.1
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 192.168.1.0 255.255.255.0 192.168.0.0
Also, on the router you don't need "ip default-gateway" command as it might cause problems.
Vaijanath S
(Please rate if this is helpful)
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Thanks for the response.  I have removed the route statement and tested again.  But, still get the same results.
