SIP Trunk not showing called party name
fgasimzade
Level 4
Level 4
Hello everyone,
We have a SIP trunk between CUCM and 3CX
The problem is when I call from CUCM to 3CX, I dont see the Display Name of the number I am dialing. In the meantime, 3CX shows my name when I dial from CUCM
Is it possible to receive Display Name of the dialed number through SIP trunk?
2 Accepted Solutions
Yes, it's possible in general in SIP and therefore also in the CUCM SIP trunk.
Yes it is possible. It is a part of the SIP dialog for establishing a call.
Response Signature
b.winter
If 3CX is not sending back the information, then you won't see anything. There is nothing you can do on the CUCM side, because it's a setting on the 3CX side.
So you, or whoever controls the 3CX side, needs to check the settings there.
This is what I thought in the first place, however, the question is if it is technically possible with SIP trunk to send this information from receiving party to originator?
Response Signature
