SIP Trunk One way audio issue
anishktr2005
Dear Team,
      I have a sip trunk between cisco UCM to Huwaei escape PABX,sip trunk between cisco to huwaei is up and call are going,but i am facing one way voice issue,98% calls i an facing the same audio issue.
Huwaei extension can hear my voice from cisco phone,but i cant hear voice from huwaei extension.
Any one please reply
The Cisco CallManager logs are needed: How to Collect Traces for CUCM 9.x, 10.x and 11.x
Georgios
Please rate if you find this helpful.
12 Replies 12
Georgios Fotiadis
Is there a firewall between Cisco IP Phones (or CUCM) and the Huawei PBX? Can you attach SDL logs from CUCM for a specific call?
Georgios
There is no firewall between both system,can you please tell me how to take SDL logs from CUCM
Georgios
i am getting this error while i am tracing
First make a call and then gather CallManager logs for the last xx minutes.
Georgios
here is the sdl log
Please find the attached SDL LOG
Huwaei Extension-7612
Cisco Extension-3466
Thaks for your support
attached sdl log
Hello bro!, are you using a CUBE? it´s just that i see the following
CUCM 10.222.0.11
IP Phone 10.222.0.115
direct INVITE to "213.34.194.102"
Alexis
Dear Alexis,
There is no CUBE in between,this is only connection between CUCM TO Huwaei PBX
Anish
Stan2
Please try to enable MTP (Media Termination Point) checkbox in Trunk Configuration settings on CUCM. This helped me.
