SIP Trunk Problem
scr.sybex1
Dear,
I have cucm 11.5
I have problem with configuring sip on cube, my scenario is like below:
ITSP---------CUBE----------CUCM-----------IP Phone
I have no incoming and outgoing call.
the problem is that when i call the sip number from PSTN or my cellphone. the ip phone ring and answer the phone but i haven't any ring back or voice from the ip phone. and the call disconnect after exactly 20 seconds.
as i see debug ccsip message it disconnect SIP 2.0 504 gateway timeout with cause=102.
I attach debug ccsip message and ccapi inout and cube configuration.
i configure the CUCM side with All default parameter(1.standar sip profile 2.non secure sip trunk security profile 3.MTP required is Checked 4.Correct MRGL 5.g711alaw 6.change min-se to 90 and sip session timer to 300)
i appreciate if someone could help me.
thanks
23 Replies 23
From the logs that you added, I don't see where is the CUBE receiving the 180 from ? It does not have an SDP so does not make sense to have it reliably ack'ed, the reason why your ITSP might not be PRACK'ing it.
Can you take another log for the debugs, copy it in a text file and attach it ?
Also, I won't disable "rel1xx" globally on the CUBE if I were you. It might break early media related things like ring back, IVR etc when calling out to your ITSP.
SIP Call messages tracing is enabled
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
012570: Mar 5 13:53:15.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.198.21.82:5060 SIP/2.0
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKluv4jhlvi7jl9g36ogl9v4u79;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 4l4vvx4u66elhoxv9ljhhh7uh67e5ge4@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Contact: <10.153.101.165:36616>;expires=65535
Accept: application/sdp
Max-Forwards: 70
Content-Length: 0
012571: Mar 5 13:53:15.246: //121532/6288D443B8B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A49564-176C
Date: Mon, 05 Mar 2018 13:53:15 GMT
Server: Cisco-SIPGateway/IOS-15.5.1.T1
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: applic
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#ation/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 1533 6774 IN IP4 10.198.21.82
s=SIP Call
c=IN IP4 10.198.21.82
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
012572: Mar 5 13:53:16.250: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012573: Mar 5 13:53:16.250: //121532/6288D443B8B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:16 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
RTSF-T-01-04A-1#
012574: Mar 5 13:53:18.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012575: Mar 5 13:53:18.242: //121532/6288D443B8B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:18 GMT
CSeq: 1 OPTIONS
Accept: applic
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
RTSF-T-01-04A-1#
012576: Mar 5 13:53:22.762: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bK9gx9ih4ehigglogveov4ei3xi;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 9eo33xvil5535g73o7963uuu9igggvuj@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012577: Mar 5 13:53:22.766: //121535/674EC25DB8B3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A4B4A8-4AC
Date: Mon, 05 Mar 2018 13:53:22 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5220 1068 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012578: Mar 5 13:53:23.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012579: Mar 5 13:53:23.254: //121535/674EC25DB8B3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:23 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012580: Mar 5 13:53:24.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012581: Mar 5 13:53:24.262: //121535/674EC25DB8B3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:24 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012582: Mar 5 13:53:26.202: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:42403000@10.198.21.82:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKls9s4m7ra466765lsglas41mm;Role=3;Hpt=8e58_16
Record-Route: <10.153.101.165:5060>
Call-ID: isbcc6vj0abeebx9cabw1jd61j0exbdjjaja@UAC
To: <42403000>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Contact: <77622027>
Max-Forwards: 69
User-Agent: Huawei SoftX3000 V600R013
Session-Expires: 300
Min-SE: 90
Content-Length: 340
v=0
o=- 6077869 6077869 IN IP4 10.153.101.165
s=SBC call
c=IN IP4 10.153.101.165
t=0 0
m=audio 16976 RTP/AVP 8 0 18 3 97 96
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 telephone-event/8000
a=rtpmap:96 RED/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012583: Mar 5 13:53:26.210: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <42403000>
Date: Mon, 05 Mar 2018 13:53:26 GMT
CSeq: 1 INVITE
Content-Length: 0
012584: Mar 5 13:53:26.210: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7777@172.16.50.20:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.47.1:5060;branch=z9hG4bK7D0815
Remote-Party-ID: <77622027>;party=calling;screen=no;privacy=off
To: <7777>
Call-ID: 695C47F0-1FB311E8-B8BAD287-199A1C11@172.16.47.1
Min-SE: 300
Cisco-Guid: 1767615279-0531829224-3098858119-0429530129
User-Agent: Cisco-SIPGateway/IOS-15.5.1.T1
CSeq: 101 INVITE
Timestamp: 1520258006
Contact: <77622027>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 7175 9770 IN IP4 172.16.47.1
s=SIP Call
c=IN IP4 172.16.47.1
t=0 0
m=audio 18064 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
012585: Mar 5 13:53:26.214: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <7777>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
012586: Mar 5 13:53:26.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012587: Mar 5 13:53:26.254: //121535/674EC25DB8B3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012588: Mar 5 13:53:26.322: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <7777>;tag=945469~df49f916-efd4-44db-87ad-33d27562197c-18637653
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM11.5
Call-Info: ;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 0000704600105000a00000059a3c7a00;remote=b8088bf3f3e7b3cd6cbe7010ab945469
P-Asserted-Identity: <7777>
Remote-Party-ID: <7777>;party=called;screen=yes;privacy=off
Contact: <7777>;+u.sip!devicename.ccm.cisco.com="CSFWTEST1";video;bfcp
Content-Length: 0
012589: Mar 5 13:53:26.322: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <42403000>;tag=57A4C290-1FCB
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012590: Mar 5 13:53:26.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012591: Mar 5 13:53:26.686: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012592: Mar 5 13:53:26.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012593: Mar 5 13:53:27.694: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012594: Mar 5 13:53:27.694: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Mon, 05 Mar 2018 13:53:27 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012595: Mar 5 13:53:27.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012596: Mar 5 13:53:29.694: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012597: Mar 5 13:53:29.694: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Mon, 05 Mar 2018 13:53:29 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012598: Mar 5 13:53:29.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012599: Mar 5 13:53:30.770: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKgghhg3e9i3u63v4ox37356v3l;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 4glgvghxu9uioi9ix3u3gghve4uej9e9@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012600: Mar 5 13:53:30.770: //121538/6C14B10FB8BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A4D3F0-141E
Date: Mon, 05 Mar 2018 13:53:30 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 9017 4391 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012601: Mar 5 13:53:31.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012602: Mar 5 13:53:31.254: //121538/6C14B10FB8BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:31 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012603: Mar 5 13:53:32.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012604: Mar 5 13:53:32.262: //121538/6C14B10FB8BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:32 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012605: Mar 5 13:53:33.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012606: Mar 5 13:53:33.690: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Mon, 05 Mar 2018 13:53:33 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012607: Mar 5 13:53:33.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012608: Mar 5 13:53:34.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012609: Mar 5 13:53:34.254: //121538/6C14B10FB8BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:34 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012610: Mar 5 13:53:37.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012611: Mar 5 13:53:38.774: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bK6l39ii5illui9j7ihog43l9xu;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: 7574vge4x5x4j5o5h6e7xx99oohe5uoe@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012612: Mar 5 13:53:38.778: //121541/70DA0301B8BE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A4F334-C08
Date: Mon, 05 Mar 2018 13:53:38 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7726 4201 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012613: Mar 5 13:53:39.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012614: Mar 5 13:53:39.266: //121541/70DA0301B8BE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:39 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012615: Mar 5 13:53:40.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012616: Mar 5 13:53:40.270: //121541/70DA0301B8BE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:40 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012617: Mar 5 13:53:41.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <42403000>
CSeq: 1 INVITE
Contact: <77622027>
Max-Forwards: 69
Min-SE: 90
Content-Length: 340
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
a=fmtp:18 annexb=no
012618: Mar 5 13:53:41.686: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Mon, 05 Mar 2018 13:53:41 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012619: Mar 5 13:53:41.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 6888
Contact: <42403000>
Content-Length: 0
012620: Mar 5 13:53:42.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012621: Mar 5 13:53:42.274: //121541/70DA0301B8BE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:42 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012622: Mar 5 13:53:45.822: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 504 Gateway Timeout
CSeq: 1 INVITE
Reason: Q.850;cause=102
Content-Length: 0
012623: Mar 5 13:53:45.822: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:7777@172.16.50.20:5060 SIP/2.0
To: <7777>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1520258025
Content-Length: 0
012624: Mar 5 13:53:45.822: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <7777>
Date: Mon, 05 Mar 2018 13:53:45 GMT
CSeq: 101 CANCEL
Content-Length: 0
012625: Mar 5 13:53:45.826: //121537/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
012626: Mar 5 13:53:45.826: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:7777@172.16.50.20:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
012627: Mar 5 13:53:46.322: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
012628: Mar 5 13:53:46.766: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bKuxx97ul39jh9joju9le995u9h;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: je753uxv7o97o639l77e763977v7ve47@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012629: Mar 5 13:53:46.770: //121542/759D7FE2B8BF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A5126C-CF2
Date: Mon, 05 Mar 2018 13:53:46 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 5883 2565 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012630: Mar 5 13:53:47.254: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012631: Mar 5 13:53:47.254: //121542/759D7FE2B8BF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:47 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012632: Mar 5 13:53:47.322: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
012633: Mar 5 13:53:48.258: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012634: Mar 5 13:53:48.258: //121542/759D7FE2B8BF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:48 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
012635: Mar 5 13:53:49.322: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
012636: Mar 5 13:53:50.262: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012637: Mar 5 13:53:50.262: //121542/759D7FE2B8BF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 05 Mar 2018 13:53:50 GMT
CSeq: 1 OPTIONS
Content-Length: 371
v=0
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#u all
All possible debugging has been turned off
RTSF-T-01-04A-1#
012638: Mar 5 13:53:53.322: //121536/695BAB2FB8B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
012639: Mar 5 13:53:54.754: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.153.101.165:5060;branch=z9hG4bK9u534ixihx9h6o9v37x35x7ej;Role=3;Hpt=8f08_16;pth=0;X-HwDim=4
Call-ID: g7oh4iolli75j5hx7jllo74vj5i6xolv@165.101.153.10
To: <10.198.21.82>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
012640: Mar 5 13:53:54.758: //121543/7A606134B8C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.198.21.82>;tag=57A531A0-11A8
Date: Mon, 05 Mar 2018 13:53:54 GMT
CSeq: 1 OPTIONS
Accept: applic
RTSF-T-01-04A-1#
RTSF-T-01-04A-1#
Content-Length: 371
v=0
o=CiscoSystemsSIP-GW-UserAgent 7761 6468 IN IP4 10.198.21.82
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Calling/called numbers ?
I called 42403000 from my mobile.
Thank for reply
I attach cucm and cub trace and debug file
The line control is registered on the third node, you gave the traces for only the first one. Please attach traces for all the nodes.
38138435.000 |15:23:23.975 |SdlSig-O |CcSetupReq |NA RemoteSignal |LineControl(3,100,178,1172) |Cdcc(1,100,224,21714) |1,100,10,1.42223^172.16.49.2^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=18616037
Also regarding ringback like Saurabh said check with your provider or disable 100 rel and test.
https://www.cisco.com/c/en/us/support/docs/voice/session-initiation-protocol-sip/116086-configure-cube-cucm-sip-00.html#anc6
Please rate if found helpful
Aeby
Please rate if you find this helpful.
Aeby
I am having a similar issue.
CUBE sits behind our firewall, NAT is configured. We are able to make two voice communication  with twilio elastic trunk however the call disconnect each time after 20 sec. I suspect the ACK is being sent back to the private IP. What is a possible fix for this
allahverdiyev
did you resolve the issue?
