08-23-2019 07:20 AM
Hi all
i have some troubles with SIP Trunk registration to a local provider.
Options ping is enabled on the CUBE and SP answers with a SIP/2.0 403 not registered message to the opption ping.
Normally i would think next step should be a REGISTER message without authorization header following by an authorization request SIP/2.0 401 Unauthorized from SP.
Unfortunately CUBE directly sends an Authorization header but with blank nonce which the SP switch does not accept leading to a failed attempt.
Is there a way to configure CUBE to send Authorization header only when prompted from SP or to at least remove it from first REGISTER message?
Aug 23 12:37:16.934: //740632/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: CFBDFBE0-C4C811E9-82F39227-303A6B83@55.55.55.66
CSeq: 101 OPTIONS
To: <sip:55.55.55.55>;tag=03-32766-0099419f-60c9fd227
Via: SIP/2.0/UDP 55.55.55.66:5060;received=55.55.55.66;branch=z9hG4bK3D70E1F30
Content-Length: 0
Aug 23 12:37:31.539: //740639/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:55.55.55.55:5060 SIP/2.0
Via: SIP/2.0/UDP 55.55.55.66:5060;branch=z9hG4bK3D70F1F90
To: <sip:0551999666@55.55.55.55>
Date: Fri, 23 Aug 2019 10:37:31 GMT
Call-ID: E4E1E9D2-B9AF11E9-99E89227-303A6B83
User-Agent: Cisco-SIPGateway/IOS-15.6.3.M6a
Max-Forwards: 70
Timestamp: 1566556651
CSeq: 10170 REGISTER
Contact: <sip:55.55.55.66:5060;bnc>
Expires: 240
Supported: path
Authorization: Digest username="0551999666",realm="Provider.FQDN",uri="sip:55.55.55.55:5060",response="",nonce=""
Content-Length: 0
Received:
SIP/2.0 100 Trying
From: <sip:0551999666@55.55.55.55>;tag=6B9D0134-AB1
Via: SIP/2.0/UDP 55.55.55.66:5060;received=55.55.55.66;branch=z9hG4bK3D70F1F90
Content-Length: 0
Received:
SIP/2.0 404 Domain not bound
To: <sip:0551999666@55.55.55.55>;tag=00-08190-00b2b4ef-463e43123
Server: Cirpack/v4.76 (gw_sip)
Content-Length: 0
08-26-2019 07:43 AM
08-26-2019 07:55 AM
08-26-2019 08:22 AM
Yeah sure but should there not be a way to correct this behavior without a bunch of sip-profile manipulations? It is only the first REGISTER that should not include Authorization
Looking into the screenshot above taken from IOS 15 SIP Configuration guide there should be no Authorization Header in initial REGISTER and i hoped there was a simple solution just to get it to work like it should and is described
08-26-2019 08:44 AM
CWD
Not sure if you have taken this screen shots from IOS 15 solution guide but I have seen this scenario for third party SIP phones and when we have Digest Credentials enable. So whenever Digest credentials comes into the picture UAS (SIP Server) rejects the first register message from UAC as per RFC guide [RFC3261]
Basically UAS is challenging the authenticity of the register messages and in the second register message Digest user creds and MD5 algorithm is exchanged. You can try decoding the first register and second register message you will see the difference and it seems to be as per SIP RFC. This is working as design when you enable the authorization.
In order to make it work your provider need to be aware of the same which is not quite easy here in case of provider.
