Sip Trunk Stopped Working
dan.letkeman
Level 4
Level 4
For the life of me I cannot figure out why my sip trunk stopped working.  If I look at the debugs these are the errors that I keep getting:
2811voice#REGISTER sip:did.voip.les.net:5060 SIP/2.0
Via: SIP/2.0/UDP 216.88.54.55:5060;branch=z9hG4bK18A1C84
From: <sip:2279854920@did.voip.les.net>;tag=3197250-C7F
To: <sip:2279854920@did.voip.les.net>
Date: Thu, 12 May 2011 17:53:13 GMT
Call-ID: 86135A3E-7BF711E0-8003DD75-791FFF66
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1305222793
CSeq: 2 REGISTER
Contact: <sip:2279854920@216.88.54.55:5060>
Expires:  200
Supported: path
Content-Length: 0
2811voice#
047832: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/act_sent_register_wait_100: act_sent_regist
er_wait_100: Out of retries
047833: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDecrementOverloadCount: Count:Local 0 G
lobal 0
047834: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code
Class 4xx Method Code 100 received for REGISTER
047835: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_free_rcb: Freeing rcb [0x4
AE6F5E4]
047836: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTE
R:: registrar 0 DNS resolved addr reset
047837: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/ccsip_api_register_result_ind: SIP Registra
tion Retries Exhausted
047838: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIRegPthruProcessResponse: Processing re
sponse w/ resp code == 408
047839: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetRPCBFromRCB: Retreiving RCB [0x4ACC0
400] from RPCB [0x0]
047840: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPC
B
047841: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartRCBTimer: Starting timer fo
r pattern 2279854920 for 120 seconds
047842: May 12 12:53:17.535 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key
=[396] removed.
047843: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting f
rom UAC table.
047844: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from tab
le. ccb=0x4A5EC5E8 key=86135A3E-7BF711E0-8003DD75-791FFF66
047845: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 eve
nts on the internal queue that are going to be free'd
047846: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profil
es Freed
2811voice#
047847: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/ccsip_offer_ans_delete:
047848: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/ccsip_iwf_delete:
047849: May 12 12:53:17.535 CDT: //395/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4A5EC5E8
2811voice#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
2279854920                       -1         114          no
Any ideas on why this could be happening?  I was running version 15.1(3)M and upgraded to 15.1(4)M, but still the problem persists.
Dan.
13 Replies 13
Mike Lydick
are you using DNS to resolve the SIP SBC host name? Did IP address change?
408 usually means request timeout.
sipSPIRegPthruProcessResponse: Processing response w/ resp code == 408
Yes, I am using dns, and it was working....
So I just changed everything from dns:did.voip.les.net to ipv4:64.34.181.47, and I still have the same error messages.
Dan.
No changes, then the provider changes something. Maybe upgraded their cisco router from 12.4.x  to 15.1.3 and forgot to trust your network .
Do you want to post your redacted config so the forum can review?
mike
BTW I assume that SBC address is in your IP trust list?
mike
No changes on my end happened....
voice service voip
ip address trusted list
  ipv4 10.1.1.11 255.255.255.255
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 250 min 200
sip-ua
credentials username 2279851457 password 7 12345 realm 64.34.181.47
authentication username 2279851457 password 7 12345 realm 64.34.181.47
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers trying 1000
timers connect 100
timers register 250
registrar ipv4:64.34.181.47 expires 200
sip-server ipv4:64.34.181.47
Try adding their address to your IP trust list.
Still no go with this:
voice service voip
  ipv4 64.34.181.47 255.255.255.255
sip
voice class h323 1
  h225 timeout tcp establish 3
Docs on the IP trust feature...
https://supportforums.cisco.com/docs/DOC-12228
I had to do that in order to let the Call Manager to route calls too it, that is why there is the ip :  10.1.1.11 in the list.
But still no sip trunk connection...
What is this:
072468: May 12 20:03:50.935 CDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetRPCBFromRCB: Retreiving RCB [0x4ABB1098] from RPCB [0x0]
072469: May 12 20:03:50.935 CDT: //592/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
Cannot see from the supplied log that they are responding.
Maybe turn on additional sip debugging will give more insight or a local packet capture off the SBC will get plenty of information.
Either way I believe I would be contacting the carrier with questions about what changed. They will need to help indicate if something is off with their security.
Redacted, great word. Plus 5!
Found out it was my ISP blocking it.
Could you please clarify on what they were blocking?
