SIP trunk to ITSP not registered
mohamed.nagy1
Hi all,
i have configured a CUBE, but unfortunately, the CUBE does not register to the ITSP.
When i enable the debug ccsip error on the CUBE, i get the following error:
*Aug 30 14:10:09.582: //-1/xxxxxxxxxxxx/SIP/Error/sipConnectionManagerUnregisterCtxtInConnection:
Connection not found for addr=82.100.213.139, port=5060 local_addr=10.225.2.10
000076: *Aug 30 14:10:09.583: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
The sip-ua registrer's status is still not registered.
Could someone help me?
Thanks in Advance!
Mohamed
Rajan
Hi Mohamed,
Can you confirm with provider that all parameters used are correct (username, password and other config) and also to check on their end what is the error they are getting.
Rajan
Pls rate all useful posts
tgaur
hi,
i agree check with the SP, else provide :
debug ccsip messages
debug ccsip event/error
debug voip ccapi inout
with sh run from the CUBE
Tarun
