Sip Trunk to Samsung PBX
orddie234
Level 7
Level 7
Hi All,
We are trying to send a few calls over to a Samsung PBX.  We are currently pointing CUCM directly to the IP of the samsung PBX and calls are working...  the only issue is that when a cisco phon places the call to a samsung extension, they see an ip address (not the PBX IP..  something different). The samsung PBX does not see any caller ID when the phone is ringing.
However, when a samsung phone calls a cisco phone...  everything works as expected.
9 Replies 9
Can you please post a screenshot of trunk configuration page of CUCM?
Carlo
Please rate all helpful posts "The more you help the more you learn"
my access is through team viewer and the screen shots are not working correctly.  is there anything you need me to check?
Possible to get INVITE message received by Samsung PBX?
im not sure if CUCM debugs would show me this?  there is NO cube in the middle.  it's direct from CUCM PUB to Samsung PBX.
Can't you trace it from Samsung?
no idea.  im a cisco guy.  :)
I guess what i was looking for is someone that may have the same setup of if someone knew of a standard to set CUCM too.
Have you worked with connecting the cucm with the samsung we are having troubles getting the 2 to talk
No, never connect SIP trunk between CUCM and Samgung, but if as long as Samsung implementation matches with RFC 3261, there should not be any issue. Can you share the SIP traces to debug it further?
- Vivek
cbrasfield1
Can you send us a copy of your programming for the Samsung side we are trying to connect the cucm to our Samsung 7400 and have not been able to connect
