02-25-2013 05:27 AM - edited 03-16-2019 03:55 PM
I am having trouble configuring a SIP trunk, i am able to make call into the cube and call manager, however when it comes to make out bound calls the calls appear to drop off and fail to resume. I have been looking around and have been unable to see any issues. currently i am testing the sip connection on the secondary back up cube that is 10.70.13.10. the primary cucm is 10.60.3.20 and the subscriber is 10.70.13.20.
I am currently using Call Manager 9.0 for CUCM
I am using using a 2921 with version 15.1(4)M4 for the Cube.
in the example i am trying to call the 0444888333 number from an internal phone.
on the sip trunk i have set the displayed number as 625058000
INVITE sip:0444888333@10.70.13.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.60.3.20:5060;branch=z9hG4bK4f173d46d8
Remote-Party-ID: "The Client" <sip:10.60.3.20>;party=calling;screen=yes;privacy=off
From: "The Client" <sip:62505800@10.60.3.20>;tag=129~a928f5a0-237e-4cbd-9716-954b915b4a58-24190856
To: <sip:0444888333@10.70.13.10>
Date: Mon, 25 Feb 2013 04:21:42 GMT
Call-ID: da0e1480-12a1e6d6-4d-14033c0a@10.60.3.20
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM9.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 3658355840-0000065536-0000000065-0335756298
Session-Expires: 1800
Contact: <sip:62505800@10.60.3.20:5060>;video;audio
Max-Forwards: 70
Content-Length: 0
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x2AE096C0) with key=[4433] to table
Feb 25 04:21:42.139: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Feb 25 04:21:42.139: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Feb 25 04:21:42.139: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Feb 25 04:21:42.139: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.60.3.20,Port 5060, Transport 1, SentBy Port 5060
Feb 25 04:21:42.139: //-1/000000000000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.70.13.10
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/State/sipSPIChangeState: 0x2AE096C0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone AWST to SIP default timezone = GMT
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.70.13.10
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=0444888333, Called Number=0444888333, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=0444888333
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=0444888333, Expanded String=0444888333, Calling Number=0444888333T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=33 Is Matched
Result=Success(0) after DP_MATCH_DEST
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=0444888333, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=33
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x29A73BC4) found for sip_user: 0444888333
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: The Client, current remote number:
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
Feb 25 04:21:42.139: //-1/DA0E14800000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x2AE096C0 key=da0e1480-12a1e6d6-4d-14033c0a@10.60.3.200444888333
Feb 25 04:21:42.139: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=62505800, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Match Rule=DP_MATCH_ANSWER; Calling Number=62505800
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=62505800T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=62505800
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=33 Is Matched
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=33
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 0444888333
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 62505800
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name The Client, number 62505800, Calling oct3 0x00, oct_3a 0x81, Called number 0444888333
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:10.60.3.20:5060, Host:10.60.3.20
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 62505800
Result=-1
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpAssociateIncomingPeerCore:
Calling Number=62505800, Called Number=0444888333, Voice-Interface=0x0,
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.60.3.20:5060
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpMatchPeertype:
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpMatchCore:
Result=-1
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpMatchPeertype:exit@5985
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:0444888333@10.70.13.10:5060
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:0444888333@10.70.13.10
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:62505800@10.60.3.20
Result=-1
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=0444888333
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=65 Is Matched
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=65
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpMatchSafModulePlugin:
Feb 25 04:21:42.143: //-1/DA0E14800000/DPM/dpAssociateIncomingPeerSPI:exit@6564
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: Peer tag 65 matched for incoming call
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 10.70.13.10
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-AROUND
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_AROUND
Feb 25 04:21:42.143: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 100
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 10 and offer-all is = FALSE
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIContinueNewMsgInvite: Calling name The Client, number 62505800, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 0444888333, oct3 0x00
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIValidateRequestUri: Not Enabled
Feb 25 04:21:42.143: //-1/DA0E14800000/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled: - 0
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:2BB80514
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: none
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLExtractMinSEHdr: Min-SE Duration: 1800
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLInitialSRReqPeerEventGen: sending received session expires to the peer leg
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:none, Min-SE Value:1800, flags:2001
Feb 25 04:21:42.143: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIDoQoSNegotiationWithNoMediaLine: Local Precondition: 1, Remote Precondition: 1
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIDoQoSNegotiationWithNoMediaLine: MEDIA FLOW-AROUND CALL
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sip_iwf_def_copy_sdp_to_channelInfo:
CallID 4429, sdp 0x31693660 channels 0x2AE0AD14
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Delayed media case...creating new stream
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.70.13.10
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_set_flw_around_media: IP-IP flow-around mode configured: replace media addr with peer's
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Media/sipSPI_ipip_set_flw_around_media: Flow-around media src addr for stream 1: src_addr = 10.70.13.10 : port = 0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = da0e1480-12a1e6d6-4d-14033c0a@10.60.3.20
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 24
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_store_channel_info: negotiated dtmf not available, using dialpeer config dtmf = 6
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_IDLE (1)
Stream address type : 1
Callid : -1
Peer Callid : -1
RTP/SRTP Negotiated : 0
Negotiated Codec : No Codec , bytes
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated DTMF relay : inband-voice
Negotiated NTE payload : 0 (tx), 0 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [10.70.13.10]:0
Media Dest Addr/Port : [ - ]:0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_calculate_channel_count: Number of streams to report = 0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPI_ipip_store_channel_info: Setting CHANNEL_COUNT = 0 for callid 4429
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIShrlCall: Check peer: 65 for Shared-Line call, callid: 4429
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/ccsip_set_bearer_capability:
Bearer Capability: Speech (0x00)
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS_DELAYED_MEDIA
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 114D to table
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIUpdateCallEntry:
Call 4429 set InfoType to SPEECH
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:2BB81644
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPISendInviteResponse: Associated container=0x2BB81644 to Invite Response 100
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: msg=0x313C83B0, addr=10.60.3.20, port=5060, sentBy_port=5060, local_addr=10.70.13.10, is_req=0, transport=1, switch=0, callBack=0x0
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportLogicSendMsg: connection-reuse configured, listen conn-id : 2
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x313C83B0, addr=10.60.3.20, port=5060, local_addr=10.70.13.10, connId=2 for UDP
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/State/sipSPIChangeState: 0x2AE096C0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_RECD_INVITE, SUBSTATE_NONE)
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.60.3.20:5060
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0444888333, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=0444888333, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Feb 25 04:21:42.147: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=33
Feb 25 04:21:42.147: //4429/DA0E14800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Feb 25 04:21:42.151: //-1/DA0E14800000/DPM/dpMatchPeersCore:
Feb 25 04:21:42.151: //-1/DA0E14800000/DPM/dpMatchCore:
Feb 25 04:21:42.151: //-1/DA0E14800000/DPM/MatchNextPeer:
Feb 25 04:21:42.151: //-1/DA0E14800000/DPM/dpMatchSafModulePlugin:
Feb 25 04:21:42.151: //-1/DA0E14800000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=33
Result=SUCCESS(0)
1: Dial-peer Tag=33
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=33
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=0444888333, Called Number=, Voice-Interface=0x0,
Match Rule=DP_MATCH_ANSWER; Calling Number=0444888333
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Dial String=, Expanded String=, Calling Number=0444888333T
Result=-1
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
Match Rule=DP_MATCH_ORIGINATE; Calling Number=0444888333
Feb 25 04:21:42.151: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
Result=-1
Match Rule=DP_MATCH_DEST; Called Number=04448883335840-0000065536-0000000065-0335756298
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1361766102
Contact: <sip:62505800@10.70.13.10:5060>
Expires: 300
Max-Forwards: 69
Content-Length: 0
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length: Could not get Content-length
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [203.52.2.164]:5060, local_address:[10.70.13.10]
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone AWST to SIP default timezone = GMT
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sipSPISendInvite: Associated container=0x2BB810C4 to Invite
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: msg=0x313C83B0, addr=203.52.2.164, port=5060, sentBy_port=0, local_addr=10.70.13.10, is_req=1, transport=1, switch=0, callBack=0x0
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header before modification : Remote-Party-ID: "The Client" <sip:62505800@10.70.13.10>;party=calling;screen=yes;privacy=off
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : \
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 1TheClient.com.au>\2
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : \1TheClient.com.au>\
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 2
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header after modification : Remote-Party-ID: "The Client" <sip:62505800@TheClient.com.au>;party=calling;screen=yes;privacy=off
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportLogicSendMsg: connection-reuse configured, listen conn-id : 2
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x313C83B0, addr=203.52.2.164, port=5060, local_addr=10.70.13.10, connId=2 for UDP
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Feb 25 04:21:42.731: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.70.13.10:5060;branch=z9hG4bK524A05
From: "The Client" <sip:62505800@TheClient.com.au>;tag=47ACDA70-21B4
To: <sip:0444888333@TheClient.com.au>
Call-ID: B0F41AE0-7E3911E2-82D98DD1-6EB45A6B@10.70.13.10
CSeq: 101 INVITE
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Feb 25 04:21:42.731: //4430/DA0E14800000/SIP/State/sipSPIChangeState: 0x2ADF2F00 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Feb 25 04:21:42.739: //4430/DA0E14800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0444888333@TheClient.com.au:5060 SIP/2.0
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
CSeq: 101 INVITE
Expies: 300
Max-Forwards: 69
Content-Length: 0
Feb 25 04:21:42.739: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [203.52.2.164]:5060, local_address:[10.70.13.10]
Feb 25 04:21:42.739: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 25 04:21:42.739: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Feb 25 04:21:42.739: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not found
To: <sip:0444888333@TheClient.com.au>;tag=1115929120-1361766102231
CSeq: 101 INVITE
Content-Length: 0
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Feb 25 04:21:42.743: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_handle_call_active:
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_process_event:
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_DIALOG_ESTD
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Info/sipSPISendAck: Associated container=0x2BB80BF4 to Ack
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 25 04:21:42.743: //4430/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: msg=0x313C83B0, addr=203.52.2.164, port=5060, sentBy_port=0, local_addr=10.70.13.10, is_req=1, transport=1, switch=0, callBack=0x0
Feb 25 04:21:42.743: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_get_complete_header: No holder for this header
Feb 25 04:21:42.743: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Unable to get header from stack
Feb 25 04:21:42.819: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[4433]
Feb 25 04:21:43.751: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [203.52.2.164]:5060, local_address:[10.70.13.10]
Feb 25 04:21:43.751: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Feb 25 04:21:43.751: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Feb 25 04:21:43.751: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Feb 25 04:21:43.751: //4430/DA0E14800000/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_handle_call_active:
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_process_event:
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_DIALOG_ESTD
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Info/sipSPISendAck: Associated container=0x2BB7F964 to Ack
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: msg=0x313C83B0, addr=203.52.2.164, port=5060, sentBy_port=0, local_addr=10.70.13.10, is_req=1, transport=1, switch=0, callBack=0x0
Feb 25 04:21:43.755: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_get_complete_header: No holder for this header
Feb 25 04:21:43.755: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Unable to get header from stack
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Feb 25 04:21:43.755: //4430/DA0E14800000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Feb 25 04:21:43.755: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportLogicSendMsg: connection-reuse configured, listen conn-id : 2
Feb 25 04:21:43.755: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x313C83B0, addr=203.52.2.164, port=5060, local_addr=10.70.13.10, connId=2 for UDP
Feb 25 04:21:43.755: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0444888333@TheClient.com.au:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Reason: Q.850;cause=1
Content-Length: 0
Solved! Go to Solution.
02-25-2013 05:34 PM
Hi - Can you also make another test call and post the output of debug ccsip messages ?
Also if you can do the following before making call:
voice service voip
no ip address trusted authenticate
(I am seeing your CUBE talk to 203.52.2.164 which is not in your trusted list)
Terry
02-25-2013 03:25 PM
You are receiving:
Received:
and
The above messages mean Unallocated number or the remote party was unable to find a match for your dialed number.
Before looking any further can you confirm:
- 0444888333 is dialable number? Can you dial this number from your mobile?
- The calling id you are sending to your provider is correct - they may reject call if its incorrect
- Lastly if above both are good, then you may need to look into the config
Terry
02-25-2013 03:35 PM
The Dialed by number is my mobile and i am unable to dial it.
The calling ID is the start of the range that is provided by the SIP service.
I can see the dial-peer rules being matchd then they get dropped.
02-25-2013 04:03 PM
To confirm your topology, are you using SIP trunk from CUCM to CUBE:
CUCM -(SIP Trunk?) - CUBE - SIP Trunk -ITSP
Can you post the following:
sh run | s voice service voip
sh run | s dial-peer
Make another call - and capture and post the output of debug ccsip messages.
Is your ITSP Telstra by any chance?
Terry
02-25-2013 04:42 PM
Hi Terry,
That is correct i have 2 cucm services. 1 is a publisher the other is a subscriber. Both services have their own SIP trunk connecting to their respective Cube and from the cube each device has its own respective SIP connection to the SIP provider (Telstra).
voice service voip
ip address trusted list
ipv4 x.x.x.x 255.255.255.255 <-- Primary CUCM
ipv4 x.x.x.x 255.255.255.255 <-- Secondary CUCM
ipv4 203.52.0.160 255.255.255.240
ipv4 203.52.1.221 <--- SIP Service Provider
ipv4 203.52.1.222 <-- SIP Service Provider
address-hiding
allow-connections sip to sip
fax protocol none
sip
bind control source-interface Port-channel1.63
bind media source-interface Port-channel1.63
outbound-proxy dns:sbc-wa.nipt.telstra.com
midcall-signaling passthru
sip-profiles 100
dial-peer voice 30 voip
description ## outgoing cucm 1 ##
preference 2
destination-pattern 893383[12]..
session protocol sipv2
session target ipv4:10.60.3.20
voice-class codec 10
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
fax protocol none
no vad
dial-peer voice 31 voip
description ## outgoing cucm 2 ##
preference 1
session target ipv4:10.70.13.20
dtmf-relay rtp-nte
fax protocol none
no vad
dial-peer voice 35 voip
description ## incoming cucm ##
session target sip-server
incoming called-number .T
dtmf-relay rtp-nte
fax protocol none
dial-peer voice 60 voip
description ## outgoing tipt ##
destination-pattern .T
voice-class sip profiles 1
dtmf-relay rtp-nte
fax protocol none
dial-peer voice 65 voip
description ## incoming tipt ##
rtp payload-type nse 99
incoming called-number 893383[12]..
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax protocol none
02-25-2013 05:34 PM
voice service voip
Terry
02-25-2013 06:36 PM
Hi Terry,
I have obscured the numbers for privacy but they are matching on the dial-peeers
INVITE sip:862550000@10.70.13.10:5060 SIP/2.0
Via: SIP/2.0/UDP 203.52.2.164:5060;branch=z9hG4bKkud3lf30eg9104tfi141.1
From: <892224433>;tag=1313379916-1361845589158-892224433>
To: "862550000 862550000"<>>862550000@TheClient.com,au.com.au;url-cookie=VNWEHA1-lj1dn3k5t840e>
Call-ID: BW132629158260213-981171764@10.83.154.147
CSeq: 170478164 INVITE
Contact: <892224433>892224433>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: application/media_control+xml,application/sdp,multipart/mixed
Supported:
Max-Forwards: 29
Content-Type: application/sdp
Content-Length: 422
v=0
o=BroadWorks 943513346 1 IN IP4 203.52.2.164
s=-
c=IN IP4 203.52.2.164
t=0 0
a=media-release:hngl5rp9pujvivh05pvumib1j8jovg8o6u7k8gsnmkmj2844l4v1004042
a=media-release-con-addr:d6v1k1hvmhvh1081o9j0
m=audio 19354 RTP/AVP 8 18 0 101
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=silenceSupp:off - - - -
Feb 26 02:26:29.172: //52/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 26 Feb 2013 02:26:29 GMT
Content-Length: 0
Feb 26 02:26:29.172: //53/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:862550000@10.60.3.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.70.13.10:5060;branch=z9hG4bK2BCD
Remote-Party-ID: <892224433>;party=calling;screen=no;privacy=off892224433>
From: <>>892224433@TheClient.com,au.com.au>;tag=324738-FE3
To: <862550000>862550000>
Call-ID: C2E837FA-7EF211E2-808C9BC5-9698E19A@10.70.13.10
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3269958610-2129793506-2156305349-2526601626
CSeq: 101 INVITE
Timestamp: 1361845589
Expires: 300
Max-Forwards: 28
Content-Disposition: session;handling=required
Content-Length: 305
v=0
o=CiscoSystemsSIP-GW-UserAgent 2495 8249 IN IP4 10.70.13.10
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 26 02:26:29.176: //53/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Feb 26 02:26:29.188: //53/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <862550000>;tag=181~a928f5a0-237e-4cbd-9716-954b915b4a58-24191169862550000>
CSeq: 101 INVITE
Supported: Geolocation
Contact: <862550000>862550000>
Content-Length: 0
Feb 26 02:26:29.192: //52/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "862550000 862550000"<>>862550000@TheClient.com,au.com.au;url-cookie=VNWEHA1-lj1dn3k5t840e>;tag=324748-10F9
Remote-Party-ID: <862550000>;party=called;screen=no;privacy=off862550000>
Content-Length: 0
Feb 26 02:26:29.260: //53/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
CSeq: 101 INVITE
Reason: Q.850;cause=47
Content-Length: 0
Feb 26 02:26:29.264: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:862550000@10.60.3.20:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 26 02:26:29.264: //54/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:862550000@10.70.3.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.70.13.10:5060;branch=z9hG4bK2C20AC
From: <>>892224433@TheClient.com,au.com.au>;tag=324794-84D
Call-ID: C2F6415B-7EF211E2-808E9BC5-9698E19A@10.70.13.10
Min-SE: 1800
CSeq: 101 INVITE
Expires: 300
Max-Forwards: 28
Content-Length: 305
v=0
o=CiscoSystemsSIP-GW-UserAgent 4733 6824 IN IP4 10.70.13.10
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 26 02:26:29.764: //54/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 1800
CSeq: 101 INVITE
Expires: 300
Max-Forwards: 28
Content-Length: 305
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 26 02:26:30.764: //54/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Tue, 26 Feb 2013 02:26:30 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1361845590
Expires: 300
Max-Forwards: 28
Content-Length: 305
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 26 02:26:32.764: //55/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:862550000@TheClient.com,au.com.au:5060 SIP/2.0
Via: SIP/2.0/UDP 10.70.13.10:5060;branch=z9hG4bK2D18F4
Remote-Party-ID: <>>892224433@TheClient.com,au.com.au>;party=calling;screen=no;privacy=off
From: <>>892224433@TheClient.com,au.com.au>;tag=325540-201E
To: <>>862550000@TheClient.com,au.com.au>
Date: Tue, 26 Feb 2013 02:26:32 GMT
Call-ID: C50C517B-7EF211E2-80909BC5-9698E19A@10.70.13.10
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1361845592
Expires: 300
Max-Forwards: 28
Content-Length: 329
v=0
o=CiscoSystemsSIP-GW-UserAgent 4725 4003 IN IP4 10.70.13.10
s=SIP Call
t=0 0
m=audio 19354 RTP/AVP 8 18 0 101 19
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
Feb 26 02:26:32.772: //55/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Feb 26 02:26:32.832: //55/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>>862550000@TheClient.com,au.com.au>;tag=227600251-1361845592821
CSeq: 101 INVITE
Content-Length: 0
Feb 26 02:26:32.832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:862550000@TheClient.com,au.com.au:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 26 02:26:32.832: //52/C2E79BD28086/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
Content-Length: 0
Feb 26 02:26:32.836: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:862550000@10.70.13.10:5060 SIP/2.0
CSeq: 170478164 ACK
Max-Forwards: 29
Content-Length: 0
02-25-2013 08:04 PM
Luke - I will look into the logs as soon as I can - Can you confirm one more thing, are you binding the SIP to correct interface/ip address? Is it the same ip address what you specified in CUCM SIP trunk destination?
02-25-2013 08:07 PM
I have just resolved this issuse.
It appears that an incorrect configuration was sent to me by the SIP provider. I am able to make calls in out and know i can recieve audio.
Thankyou for you help Terry
02-25-2013 08:18 PM
Great - Not a problem - Can you share what needed correction - was it the wrong trust list address?
By the way you were getting:
Received:
SIP/2.0 503 Service Unavailable <<<<<
After that SIP invite was being re-sent and ended up getting:
Received:
Terry
02-25-2013 08:32 PM
Hi Terry,
I amended the ipv4 trusted listed to add my states local sip service
I removed the media flow-through command under voice service voip.
The 503 message was due to the test IP Phone not being pluged in, this was not the issue at the other time of testing.
02-25-2013 08:41 PM
Cool - Glad everything is working! See you around.
Terry
