ā02-27-2013 05:35 AM - edited ā03-16-2019 03:57 PM
Hello folks
CUCM SW 7.1.5.33900-10. Direct SIP trunk without CUBE.
Can Call Manager use host name in the @ field instead of IP-address on outgoing calls?
I mean instead of:
INVITE sip:400@192.168.0.16:5060 SIP/2.0
to send its hostname
INVITE sip:400@cucm71.smart.net:5060 SIP/2.0?
DNS server in CUCM is configured and works fine.
In System/Server FQDN of CUCM is configured too.
Thanks in advance,
ā02-27-2013 06:12 AM
Absolutely as long DNS can resolve it, in fact you can use SRVs.
HTH,
Chris
ā02-27-2013 10:09 PM
Sorry folks for misleading. Just pasted wrong fields.
Mea culpa...
Of course DNS is working.
I meant whether it is possible to use host name in a "From:" and "Contact:" fields on SIP calls rom CUCM. Now CUCM sends its IP address, like this
From: "Beldy" <208>;tag=72de3cc6-fbcc-4b3a-a10d-b3a049360db6-28842500208>
Is it possible to have
ā02-28-2013 02:32 AM
Yes,
You can use sip profiles...
voice class sip-profiles 1
request INVITE sip-header From modify "<>" "<>1@cucm71.smart.net>">>
request INVITE sip-header Contact modify "<>" "<>1@cucm71.smart.net>">>
Then you need to apply it to the appropriate dial-peer
dial-peer voice 1 voip
voice-class sip profiles 1
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
ā02-28-2013 04:51 AM
Thanks for the info.
Unfortunately it is direct connection from CUCM to another PABX without any router in between.
